Previous in Forum: Winding Wire   Next in Forum: Mesuring High voltage (500V)
emergency power generator
01/10/2010 2:16 AM
how to culculate the suitable emergency diesel genrator for a hospital including A/C electric motors ?
Re: emergency power generator
01/10/2010 3:47 AM
For a highly critical life-support application like this, you will need to consult some specialists. It would take many pages to spell all of this out, which is not readily suited for semi-informal forums such as here. Much of the answer will also depend on local code requirements.
01/10/2010 6:02 AM
Hire a qualified electrical contractor. If it's not done right and people die, you can sue him.
01/11/2010 7:34 AM
The emergency diesel generator kva can be calculated by getting the total hospital load which include all hospital ectronic and electrical equipment of which the A/Cs and electric motors are inclusive.
When u get your total load in kw,using kw=√3vicosφ,if by calculation,find your i(current) value,where v is your voltage and √3 is determining factor for a three phase network supply system and cosφ is your power factor.Use kva=√3vi to calculate your emergency diesel generator apparent power rating(KVA) required for the hospital.Further step up this kva value by a 25% margin to take care of unneccessary overloading in the hospital.
Makesure u buy a good emergency diesel generator from well known names like caterpillar,cummins,mitsubishi etc.Also ensure that in the installation,u follow appropriate regulations or local regulations to ensure safety.
If u are not qualified enough to handle the project,get qualified or professional personnel to handle it while u learn from them.
Patrick Whowha
Patrick Whowha
01/11/2010 7:40 AM
I would contact the generator supplier...they will be able to help with sizing by a site survey and probably current electric bills.
Register to Reply 4 comments
lyn (1); Patrick Whowha (1); smartpowergary (1); Tornado (1)
You might be interested in: Emergency Call Systems, Emergency Stop Switches
