Previous in Forum: What Does "Bridle" Mean?   Next in Forum: Boiler MAterial composition
STELLITED VALVE TRIM
01/11/2010 12:32 AM
WHEN STELITTED MATERIAL USED FOR VALVE TRIM?CHOOSING STELLITED MATERIAL IS BASED ON SERVICE TEMPERATURE OR CORROSIVE SERVICE?eg: F6 STELLITED OR 316 STELLITED
Re: STELLITED VALVE TRIM
01/11/2010 3:26 AM
Turn off the all-caps.
01/11/2010 4:16 AM
Stellite alloy is a range of cobalt-chromium alloys designed for wear resistance. It may also contain tungsten or molybdenum and a small but important amount of carbon.
STELLITE® 6 is the most generally useful cobalt alloy, having excellent resistance to many forms of mechanical and chemical degradation over a wide temperature range.
Meaning , Stellite combats multiple service environs such as following:
- Frictional wear/ tear
- Erosion
- Chemical Corrossion
- High Temperature
Stellite maintains its hardness at high temperature . Metal to metal wear is accelarated at higher temperature.Stellite offers good hardness to ressist the efect of high temperature softening.
Hence service temperature shoulbe more important a criterion while selecting the cobalt alloy.While planning for a Hardfacing weldability with the base material would also come into play and many times Hestalloy is considered for this as well as economical purpose.
05/31/2023 5:48 AM
Try a phone call to the local friendly Valves Distributor. Yell.com?
Do turn off Caps Lock before making the call. People don't like to be shouted at.
Register to Reply 3 comments
PWSlack (1); Susui (1); Tornado (1)
