Previous in Forum: about fan   Next in Forum: Thermal Efficiency of a Diesel Engine
8 comments
Piping Elbows and Weld Neck Flanges
01/11/2010 11:42 AM
Hi and thanks in advance for your answer.
in my question i want to know is It acceptable and can we to fit up the elbow 90 degree 4" c.s sch40 to the weldeneck flange PN40 DN100? thk of elbow=6mm od=114.3mm & thk of w.n flange=3.6mm od=114.3mm
Re: piping
01/11/2010 12:41 PM
Directly elbow to flange without a spool?
If your doubt is about the thicknesses, you have to bevel the ID to suit the thicknesses, there are quite a few posts on this, including a recent one.
As per schedule/code acceptability, that depends on your design and the relevant codes whether you are on EPV (PN 40) or ASME (Sch 40)
Re: Piping Elbows and Weld Neck Flanges
01/11/2010 10:27 PM
Yes, if 3.6mm thk is acceptable for your pressure & temperature. Edge preparation of 6mm will be required.
01/12/2010 3:29 AM
Hi ,thank you,
the pressure is=20 bar
temperature=250 degree celsius
01/12/2010 4:06 AM
Noted. Now you have to do the wall thk calculations yourself or arrange it by other professionals. Others can not do it for you !
01/12/2010 12:31 AM
• Yes you can join two different thicknesses together taking into account to do a taper as defined in CR4 Thread: Difference thickness.
• Download the following PDF file: Design_for_Pipes_of_Unequal thicknesses.
01/12/2010 3:13 AM
As per ASME B 31.1,
Internal misalignment (inside wall thickness difference) allowed is upto 2 mm.In this case no need to do tapering of thicker part inside.
For inside wall thickness difference more than 2 mm ,we have to do tapering of thicker part as per ASME B16.25.Same information has given by Mr.Galala.
In above question,inside wall thickness difference is more than 2 mm.So you have to do elbow tapering.
01/12/2010 3:35 AM
Hi ,thank you very much
your information is very useful for me,
the material is carbon steel st37.0 pipe or fitting 4" with thk=3.6mm pressure=20bar
temp=250 degree celsius
this material is good for this pressure and temp?
01/12/2010 3:54 AM
PIPE & ELBOWS THK=6MM
Register to Reply 8 comments
Abdel Halim Galala (1); Anonymous Poster (1); b v rao (2); gapee (3); Lahane82 (1)
You might be interested in: Tube Fittings, Flow Meters, Swivel Joints
