Previous in Forum: HVAC Makeup Water and Condenser Water Flow Rate Savings   Next in Forum: Conical Roof Tank Design
headloss in bypass control valve in hvac
01/12/2010 12:41 AM
i want to know limit of head loss in bypass control valve between cooling tower and chiller unit to find out the flow coefficient and valve selection for economical design
Re: headloss in bypass control valve in hvac
01/12/2010 3:04 AM
It depends upon a lot of things. Here are some of them:
  • The elevation of the cooling tower spray nozzles above the pond
  • The size and length of the cooling water system
  • The amount of tolerable build-up of solids on the insides of the pipes
  • The flowrate in the pipes
  • The temperature of the cooling water
  • Etc.
none of which can be seen from here.
01/12/2010 5:53 AM
thanks Mr. PWSlack its mean i have to do some calculation for friction, static and residual head in future i will be in contact with u
01/12/2010 6:34 AM
Post the data in this thread so that others may help too.
<...Mr...> How abstruse!
01/13/2010 6:16 PM
The ans. all depends on the variables you can supply us with. My suggestion in the valve department for maximum flow: use a single throw "ball "valve that is one pipe size larger than the pipe that flows into and out from it. This gives you less resistance than a "gate" valve which provides the most restriction to the flow of water. Brass or PVC have economic and replacement value considerations to consider. Hope this is a help. If you can give me pipe size's and length of runs between tower and chiller and the height of each unit I can supply further information for you.
Register to Reply 4 comments
Leo3333 (1); manis2k3_knit (1); PWSlack (2)
