Previous in Forum: Alternatives to ISO VG 68 Oil and ISO VG 100 Oil   Next in Forum: GRP Tank Coating Suitable for Sodium Hypochlorite 12%
8 comments
Best Process for Coating Calcium Carbonate
01/13/2010 8:19 AM
We are grinding Calcium Carbonate using a ball mill and classifier for particle size control. We are interested in coating this CaCO3 powder with Stearic Acid.
Is it possible to manage the coating within the existing ball mill and classifier arrangement?
What would be the best (cost efficient / effective) process if we need to furtther reduce the particle size while coating as an additional process after grinding in ball mill.
Pathfinder Tags: COATED CALCIUM CARBONATE
Good Answers: 109
Re: Best Process for Coating Calcium Carbonate
01/14/2010 4:28 AM
Hi,
which particle size of the CaCO3?
Which thickness of the coating?
Which intended use?
Medical purity (GMP) or else?
Allowed residuals of other material in coating?
RHABE
01/14/2010 5:39 AM
CaCO3 ground particle size - 250 mesh to 400 mesh
Particle size required after coating - 500 mesh(97%) and 600 mesh(97%)
If necessary can even start with ground particle size 500 mesh or 600 mesh
Coating Thickness - Approx 5% by weight
Intended Use - Filler for PVC, Rubber, and other similar industries.
Medical Purity is not required.
Allowed Residuals - Provided does not interfere with intended application.
01/19/2010 6:41 AM
The CaCO3 coating can not be made into the ball mill.
Existing solution coating CaCO3 fine particles are using Continuous mixer.
After mixing, the coated particules are made in a 3 mm granules for the transportation to the end users.
waiting your answer to give you more info on the detailled process.
J.P.
03/21/2012 1:08 PM
Can you plz tell me detail the kind of machinery needed for coating of SA on caCO3.
I mean the process.
i would be thankful to you.
Good Answers: 109
01/14/2010 7:16 AM
Hi,
if you can do cryo ball-milling this would be possible but likely too expensive.
I expect that the stearic acid will let all particles stick together so you will get a stearic acid highly filled with carbonate.
But I expect that you will like to have a powder and not a (bad) solid.
First action: have a look to individual particles in a microscope at 500 to 1000x magnification to know what surface is existing, CaC03 - is crystalline is very prone to cleaving, if "solid" is very irregular in grain form and surface structure.
So if you want to put on 5% of coating, this may not be enough to fill the many surface irregularities.
I would try to do wet hot coating by immersion into molten (highest possible temperature) stearic acid, and subsequent hot centrifuging to remove excess fluid.
If the particles are to be finer and finer you will likely need some vacuum processing.
This will include condensation of evaporated stuff onto your particles.
Another approach may be to use a liquid solvent (blow up you factory?), soak and dry again and add some slight ball milling.
Is there any additional wetting agent on the CaCO3? As on glass fibers and silicon wafers?
RHABE
01/14/2010 4:30 PM
Hi Usman,
How much stearic acid will be used? Up to 2% or more?
To coat with this acid, you have to operate above the melting point of the acid, around 70*C, and grind together to the fineness desired.
I already used coated CaCo3, Surfex MM, as a fine particle size, around 1 to 5 micron, to manufacture paints. I am not sure the coating was stearic acid because the supplier/maker never told.
Good luck, Gil.
Just an opinion.
09/12/2012 2:42 AM
Hi, we are just started manufacturing this coated CaCO3. Currently we still don't know the best method to test the quality of the coated powder. At the moment, we just using a bottle filled with water and the powder. then we shake it. If the water and powder saperate well, means the coating is ok. If the solution goes dark, then the coating not good. Is there any other method or parameter to determine this coating is ok or not?
Currently, we set 1.2% coating. How to determine this value in lab?
03/28/2018 12:10 AM
Our company offers Calcium Carbonate Powder (both coated and un-coated with stearic acid) that are manufactured from high-purity limestone by assembly-line HOSOKAWA-ALPINE – Germany technique.
With modern testing equipments in Lab, management system as per ISO 9001-2008 standard, we manufacturer variety of products have wide applications in a lot of industries.
If you are interested in our CaCO3 powder products, contact me at nguyenhau295.tht@gmail.com
Register to Reply 8 comments
Gil Becker (1); J.P. (1); nguyenhautht (1); NurAzhar (1); pranaykodandram (1); RHABE (2); Usman Kausar (1)
You might be interested in: Ball Milling and Grinding Media, Ball Bearings
