Previous in Forum: What's the Best Oil for Turbine Bearings?   Next in Forum: Atlas Copco Compressors
Pipes and Hydrostatic Pressure
01/13/2010 9:21 AM
why hydrostatic pressure is 1.5 times the design preesure
Hobbies - Musician - New Member APIX Pilot Plant Design Project - Member - New Member
Re: piping engineering
01/13/2010 9:27 AM
Basically two types of hydrostatic tests; Tightness: Conducted following maintenance to verify the integrity of the system . . . i.e. the system does not leak after being opened for repair and is thus safe to operate. Integrity: To verify that the system will "never" fail . . . very the structural strength of the system under static load.
A government big enough to give you everything you want, is strong enough to take everything you have.
Re: Pipes and Hydrostatic Pressure
01/14/2010 3:03 AM
.....also, because the engineer/surveyor for the company that is providing burst indemnity insurance requires it to be shown.
pump foumdation design
07/24/2010 8:07 AM
whether static load is greater than dynamic loadin pump foundation design?
Register to Reply 3 comments
nukesub629 (1); PWSlack (1); tariqakhtar (1)
