Previous in Forum: centifugal pump operation   Next in Forum: Force Applied on a Seal
Using a 1200 rpm Fluid Coupling with a 600 rpm Motor
01/14/2010 1:02 PM
Hello, my question is about the use of a fluid coupling. We have one that was used on a 300hp 1200rpm motor to drive a huge drum debarker. We want to use the same coupling but drive it with a 300hp 600rpm motor. That is 50% less rpm and I am not sure if the coupler will fully lock up. Am I asking for trouble or could it work at the lower rpm's?
Thank you,
David Cassano
Re: Using a 1200 rpm fluid coupling with a 600 rpm motor.
01/14/2010 1:30 PM
All else being the same, If you keep the same HP and half the RPM, the torque from the motor is doubled.
I would be very surprised if the fluid coupling would like that at all. Not only are you driving it at a RPM much lower, you are also asking it to handle much more torque. Try to get the input/output characteristics of the coupling from the manufacturer.
Everything I know about opera I learned from Bugs Bunny
Hobbies - Musician - New Member APIX Pilot Plant Design Project - Member - New Member
01/14/2010 2:56 PM
Typical full lock up speed on a fluid coupling is at 10% rated speed . . . however this can be a signficant variable depending on the fluid charge in the coupling.
A government big enough to give you everything you want, is strong enough to take everything you have.
Good Answers: 183
Re: Using a 1200 rpm Fluid Coupling with a 600 rpm Motor
01/15/2010 5:19 AM
If it is a hydrodynamic coupling then it is a pair consisting of a pump and of a turbine.
The torque is proportional to n^2 so that dividing the speed by 2 the torque will be reduced to 1/4. Since for same power at half speed the torque doubles your coupling will only transmit 1/8 of the motor torque.
Register to Reply 3 comments
DaveB (1); nick name (1); nukesub629 (1)
