Hi. I have been given a Dell Latitude to have a look at by a friend, because the backlight for the screen doesn't work. I am not sure whether this is due to the inverter or the backlight not working, and I don't have any way to test them. The laptop will turn on, and if a VGA cable is plugged in, it will output to a monitor just fine. Is there any way to test if the backlight works? I was reading you could input 12v to it, to see. I have had the inverter out, and there is no physical damage to it. I have found a used inverter on ebaY for £10, but don't want to make them pay that if the inverter is actually fine. Is there any way to test it?
