Previous in Forum: Tank Shell Thickness   Next in Forum: Density
Steam Turbine Speed Fluctuation
01/21/2010 11:51 AM
im solo runing a backpressure type steam turbine with 110 barg suply pressure with 5507 RPM min govornor and 8260 RPM max speed.
but it fluctuates at 6200 rpm. ???
Re: Steam Turbine Speed Fluctuation
01/22/2010 3:22 AM
Well, if 5507 is the min and 8260 is the max, then it's within specification. What's the problem?
01/22/2010 5:08 AM
during solo run when speed reaches to 6200 RPM actuator begins to fluctuation and it causes over speed.(I changed its actuator before but the problem didnt solve!)
01/22/2010 9:15 AM
The only reasonable assumption that can be made about your machine is that it is used in some process application on the steam side, if it is some sort of line drive or pumper it sounds like you are letting the back pressure be the one item that you can control. One set of valves can control one function that is a given in governors.
When this excursion to overspeed occurs what exactly happens? It sounds like your controlling valve is hanging up or one of the hydraulic amplifiers has a rough spot. The one thing to keep in mind when troubleshooting governors is that the problem is usually associated with loose or tight linkages or components. The effect is the same, the system tends to wind up and overshoot, this usually culminates in a hunt, when it is so pronounced that you actually go to overspeed you are usually talking about some thing visually obvious.
A little more detail would help.
If you fail to follow through, you will fail.
01/22/2010 9:45 AM
I did solo run again with 60 barg steam supply pressure again and it was successful.
Register to Reply 4 comments
askaripour (2); otha (1); PWSlack (1)
