Previous in Forum: Insulated Ductwork   Next in Forum: Static Pressure
14 comments
Torque Calculation
01/24/2007 11:17 AM
Hi,
I need to calculate the torque on an output shaft (diameter = 10cm) of a gearbox.
The Input is a 15kW, 50 Hz motor, torque 1460Nm
The gearbox is a 90:1 reducing gearbox.
The output shaft rotates at 20rpm
Does anyone know how to do this?
Pathfinder Tags: calculation gear box torque
Re: Torque Calculation
01/24/2007 8:52 PM
I'm just an all rounder amerture, but I reckon multiply by 90.
T figure sems really big already, what sort of motor is it ?
You could compare similar physical sized motors and see what torque others have, or look up specs on the motor from its manufacturers plate.
01/24/2007 11:24 PM
Output Torque = 15X9550/20 = 7162 Nm( Not cosidering eficiency of the gear unit)
01/25/2007 5:20 AM
Sir,
Kindly generallised the above formula.
MOHD. SAEED KHAN
Good Answers: 247
01/25/2007 12:07 AM
Ordinarily, the output torque is equal to the input torque times the gear ratio. So in this case, the first estimate would be 1460 x 90 = 131,400 Nm. In a 90:1 gearbox, however there will be losses due to friction, but even at that high ratio, the gearbox might still be 90% efficient. The gearbox vendor can tell you the efficiency under any running condition.
          • HOWEVER:
I'd expect input torque to be more like 80 Nm for a 15kW motor operating at 1800 rpm -- so something seems wrong here. I'd agree with answer number 2, which provides the amount of torque on a shaft rotating at 20 rpm with 15Kw.
01/25/2007 4:53 AM
I agree with the colleagues. It's just to clarify to you know that, in SI units, the relation between the power and torque is
Power[W] = Torque[N.m] x Angular speed[rad/s]
Note that 1 RPM = 2.pi rad/min = 0.03333.pi rad/s
You are suposed to have 80 Nm in the motor and 7200 Nm in the output shaft.
Humm... suspicious you are...
01/25/2007 6:02 AM
In addition, as it is a resoanable big issue, check the gear efficiency. The efficiency of a gear reduction can drop to less than 80% depending upon the constructive quality and general conditions...
01/25/2007 6:19 AM
Quite. Worm gears are the least efficient of all gear configurations.
Good Answers: 247
01/25/2007 9:25 AM
I am shocked by your tagline. In fact, studies have shown that 86% of all statistics are made up on the spot!
01/25/2007 9:35 AM
Sorry. Consider it changed...
01/25/2007 7:42 AM
50 Hz motors run at 1450 RPM or 2800 RPM (4 poles / 2 poles). If output speed is 20 RPM the gearbox ratio is 72.5. If ratio is 90:1, output speed must be 16 RPM. Please reconsider calculations.
Good Answers: 247
01/25/2007 9:45 AM
Using the formula (120 x freq) / # poles, you get 1500 or 3000 for standard speeds. Perhaps, in this motor, slip is 3%, and the 1460 is actually an rpm rather than a torque. (Maybe the nameplate reads rpm at max torque: 1460, and the person reading it saw only the torque: 1460 part) Who knows? No matter how one does the calculations, something does not fit. Maybe the 20 rpm was hand clocked -- or even done by counting seconds: one one thousand, two one thousand... ? If 20rpm is real, and 90:1 is real, then the motor rpm is 1800, and the motor is running at 60 Hz (perhaps driven by a variable frequency drive, or in a country where 60Hz is the line freq.) Puzzling.
01/25/2007 10:42 AM
Your figures for the Inpit Power and Input Torque are not consistent. The formula that connects these quantities is;
Power (W) = 2xpi x Torque (N.m) x Rotational speed (rps)
The value of Rotational speed is 20 x 90 /60 = 30 rps
Therefore Power (W) = 2 x pi x 1460 x 30 = 275 kW !!!!
01/25/2007 11:24 AM
Indeed, it agrees with the above comments that the motor should be running at 1800 RPM and, if the motor has indeed 15KW,
output shaft speed 20 rpm -> input shaft speed = 1800 RPM (20 x 90)
Normally it is obtained with 60 Hz...
15000 [W] = Torque[Nm] x 2.pi/60 x 1800 resulting a torque in the motor of 80 Nm.
output torque would be then 80 x 90 = 7200 Nm
and the output power calculation is:
Power [W] = 7200 [Nm] x 2.pi.20/60 [rad/s] = aprox. 15079 [W] (a lot of rounding values here)
One of the initial values ( input speed, input power, output speed, or gear reduction) is wrong. AND: take in count the gearbox efficiency.
Good Answers: 137
01/29/2007 5:46 AM
As various posters have said, there are some inconsistencies here. 20rpm x gearbox ratio 90 gives 1800rpm, but it says 50Hz.
1460Nm @ 20rpm gives 3.1kW, so at say 80% gearbox efficiency 3.8kW input. So this could be the situation, the kit running light.
Also 100mm dia. shaft has torsional Z-value 0.5*pi*503 mm3 so stress at 1460Nm = 7.4MPa, again on low side, but torque 90 x 1460Nm gives stress 669MPa which is far too high. If it is running light, at design condition stress is ~ 7.4*15/3.8 = 29MPa, which sounds reasonable.
Anonymous Poster (4); bhrescobar (3); Blink (3); Codemaster (1); Langdom (1); PWSlack (2)
