Previous in Forum: Confronting a Paradigm?   Next in Forum: Idea for small home business
Volume of Material Removal in Cylindrical Grinding
01/22/2010 12:01 AM
Dear Sir, 22nd January,2010
I am P.Gangadharan, from Bangalore, India, a Mech.Engr. and a Consultant on Manufacturing having 40 years of Shop experience.I have specialised in Grinding but still am interested in Productivity and I shall be grateful if you please suggest a proper cylundrical grinding wheel for the details given below.
Details of the cylindrical grinding of a piston rod used in hydraulic cylinders of earth moving machines like excavators, bulldozers ctc.,
Piston rod: Rough Grinding vvv to 0.8 umRa with a circularity of 0.03 mm
Material--------------------------------------------------------45-C8 / IS 5517
Condition-Induction Hardened to HRC 52-60 with a case depth 1.5—3.00 mm
Straightness after Induction Hardening----------0.15 mm over 1045 mm long
Cylidrical grinding m/c---------------------------------HMT G22-Olivetti design(Italy)
Cast iron bed guideways-scraped-----------------Wheel Head Power---7.5 HP
Grinding wheel Dia,500x65x254 with a recess of dia.325x10 mm
Grinding wheel make-CUMI (Carburandum universal)
Grit & Grade---A 463 K5 V10------Surface speed used is 30 Meters per second
Wet grinding with Magnetic separator------Coolant used I Pol cut 60
Dressing diamond-----Multi point
Ground in between dead carbide centers without steady rest support
Diameter before grinding 70.80 mm and to be ground to dia. 69.98 mm x1045 mm long
Job RPM-N 110---with the following steps:
1- From diameter 70.80 mm up to diameter 70.02 mm
2- Depth infeed-0.05 mm on dia. per single traverse ie 0.05 mm from tailstock to work head.
Again 0.05 mm from work head to tailstock and this depth is given with a table traverse of 30 mm per
one revolution of the job.till dia.70.02 mm.
3-The floor to floor time is 20.5 minutes which includes 2 minutes of 3 wheel dressings and job checking
time of 1minute.So the actual grinding time comes to 17.5 minutes.
4-The material removal is 98 Cubic Centimeters in 17.5 minutes giving a material removal figure of
5.25 Cubic Centimeters per minute.
Our requirement:-
1- Achieve floor to floor time of 10 mts per piece through higher Material Rate of
9.00 CCM (approximately) per minute.
< To achieve this, Can You please suggest the suitable grit and grade of Vitrified Aluminium oxide wheel
2- Alternatively to achieve this MRR , can we use CBN Wheels and if so, what are the basics required please.
Thanking You,
With Regards,
Yours truly,
P.Gangadharan -----
Re: Volume of Material Removal in Cylindrical Grinding
01/22/2010 3:25 AM
http://cr4.globalspec.com/thread/45769/Why-You-Shouldn-t-List-Your-Email-Address
Plus, it denies others an opportunity to learn from what other posters write.
01/22/2010 2:40 PM
Check these sites, send them your wheel requirements. They will help if they think you'll buy their product (This is not an endorsement):
  1. Cylindrical Grinding Wheels
  2. Radiac Abrasives - Cylindrical Grinding
  3. Georgia Grinding Wheel
01/30/2010 1:55 AM
To P.Gangadharan Ji
Respected sir, i read ur query and realise u may help me in my problem.
My name is durga prasad and i have finished my b tech (mechanical) last yr
and now in job. My father has a sall workshop of making small chains(used in cycles)
etc. Now i though side by side i should help him to increase his product base.
So i thought started making a bushing ok 8620 used in cranes.i wan tto know
which other material i can choose, any toher cumments, need a bit discussio with u.
If u can reply plz send an email to dpaggarwal@gmail.com and i will send u my other questions.
Thanx in advance sir
regards
Durga Prasad
dpaggarwal (1); lyn (1); PWSlack (1)
