Previous in Forum: Volume of Material Removal in Cylindrical Grinding   Next in Forum: Trying to Build an Air Boat for Phil Marshes
46 comments
Idea for small home business
01/23/2010 9:28 PM
I need to design a machine that will drop powder into small 1/4 oz jars or medical pots for retail sale. I have decided to cheap fabricate something out of pvc and have a few ideas how the spill port should work. It will be manual first, then automated later if order demand is high.
I am unclear as to how the product will seal beyond a twist tight lid, and unclear how to cheaply build a device to automate the application of the lids. For now it is going to be by hand.
I am capable of performing calculations of the chamber sizes verses fill and runtimes, produce the standardized work instructions, and step time the process to run as an iso environment. ( I have a production background. )
I also am aware that powder can be absorbed in the lung so I am intending to build the station in a vented vacumn chamber to eliminate powder in the air, and also provide a vent near the fill port to absorb residual powder for protection of the operator.
Also I am a bit vague on how to package this one, I know its a production issue, but I am also collecting freight costing info packaging materials info, and will be speaking to wholesale brokers with regard to marketing this item which is intended to be point of sale near the register. Rather than sell one box of 18 (if thats the number of efficiency) I am looking to market so many cases to a store chain. Need a starting point so I can begin to do product costing.
I thank you in advance for any ideas. This buisness is not in existance, it is still in my mind so it is fantasy. There is no building, there is no machine, and there are no components. I have not dedicated capital. I am still working datails in my head, and desiging the concept of the machines, while checking the packaging, freight, and potential purchasers. I already have one stipulated customer that is part of a small to medium retail chain. I think if I can get it built and running, I can employ many, the market is potentially 25% of the population.
Re: Idea for small home business
01/24/2010 10:43 AM
We get endless mech' eng' students asking for project ideas.
If you scan back over the last week or so there were at least 3.
Maybe you could ask one of them to work on your problem?
01/24/2010 1:49 PM
Well this application is very common in the packaging industry. A good place to start would be an internet search of "container filler" or similar to have a look at how it is done and what professional equipment is available (no use reinventing the wheel). From there you can get a better idea of what works and then design something around existing machinery and principles based on your application, scale of packaging quantity, level of experience and budget.
Also look at powder filling equipment manufacturers for more ideas and application notes on working with powder and powder-handling equipment.
Good Answers: 146
01/24/2010 6:34 PM
You say "medical pots". If the powder is food, medicine, or cosmetic, check out the regulations first. There's a lot of red tape out there.
Also check out the tamper evident packaging you will need in that case. The companies that supply jars and tamper evident lids probably can tell you whether there's equipment available to automate the lid application, or whether you need to design one yourself.
As for alternatives to jars, that depends on the product. What is it for, and how does the package relate to the consumer use of it. Powdered spices, for example, do just as well in a heat sealed plastic package with a reclose zip inside. Tamper evident, less expensive, and cheaper to ship. Again, I would talk to the packaging suppliers first before designing the machine, as they would know about similar or available equipment.
incus opella
Good Answers: 42
01/24/2010 10:59 PM
Often second hand equipment is far more cost effective.
I helped a fellow with an old fashon apple cider press on a farm. The customers used to bring their own jugs.
He bought an old milk bag machine that we refurbished. The farm only had single phase so we used a small VFD to provide the 3 phase 60Hz.
Totally packaging system was less than $5000 Canadian.
01/24/2010 11:41 PM
The amount of toxicity or volatility involved with the powder in question would determine, in large part, which kinds of dispensing environments and techniques you might want to employ. The means by which the container is sealed could best be determined by whether or not this vessel will see multiple openings and closings or not. As for filling the container, supply company catalogs offer an array of small sensors that can be actuated by weight, passage of, or interuption of passage of, light, proximity, etc. Faster threading could be achieved with what are known as double leads-(I suspect that given the kinds of volumes we're talking about, triple leads are out of the question). These essentially allow you to double (or triple) the speed at which screwing- or unscrewing a lid is accomplished- with no sacrifice to strength of seal. On a double lead for instance, 2 threads are started from the top of vessel 180 degrees apart. The screws pitch is such that the 2 threads run between each other. There are also snap threads. These employ the absence of threaded portions that run up and down the threads enabling an assembly that interfaces threaded portions of lid diameter with un-threaded portions of containment vessel, pushing lid down (with some small resistance) and finally- screwing tight. These are both commonly used techniques in production facilities.
Good Answers: 58
01/24/2010 11:49 PM
You might want to look at the equipment sold for re-loading ammunition. It is designed to drop small, measured amounts of powder and is relatively inexpensive. They come in both manual and semi-automated versions.
Hobbies - Fishing - Zoomer
01/25/2010 11:14 AM
A plus for using gun powder dispensing equipment is that they are made out of static dissipative materials. If you use PVC pipe or similar plastics, the equipment can build up quite a static charge and cause considerable variation in dispensing. Static dissipative equipment will reduce this variable.
When in doubt, do it the right way.
01/24/2010 11:54 PM
How about using a gun powder drop system used to reload shotgun shells or bullets...
You can used different bushing to increase or decrease the amount needed.... You might be able to use a progressive shotshell reloader to do the whole process.
Good Luck
Good Answers: 213
01/25/2010 1:32 AM
As far as sealing your jars, if your product can stand the heat, take a lesson from your grandmother (or great-grandmother, depending on your age). People who used to do their own canning would fill the jars with hot product and screw the lid on while the product was still hot. As the product cooled, a natural vacuum was created. Many products on the market today (i.e., baby foods) still use this basic technique. You could possibly fill the jars, heat them, then screw the top on while they are still hot...
Good Answers: 42
01/25/2010 2:05 AM
Not knowing what your product is, most of the home businesses in our fair city that would require dust control etc are associated with illegal substances. Especially in those 1/4 oz sizes.
01/25/2010 3:48 AM
Firstly PVC is not suited for delivering medical or food contact materials according to regulations currently in force in most countries.
We had deviced a volumetric dispenser using a simple shuttle valve at the base of a hopper for food pellets. 0.25 oz is a very small quantity (probably a little more than a teaspoon). Unless the powder is very free flowing and fine enough the shuttle valve may not work. If found suitable a manual system can be built for very low cost. I f one is looking for a virtually no cost solution there is a bottle cap 'peg measure' that s used on sugar containers that delivers about one tea spoon every time it is turned upside down. This operation lends itself to low cost mechanization.
bioramani
01/25/2010 9:42 AM
If you are running a home business there are drastically different requirements than if you are looking to supply 1/4 of the population. Doing everything by hand is what home businesses are best suited for, and you can use a measuring spoon set and good measuring practices in that case. Maybe even step up to the gunpowder measure, though that is probably not considered sanitary enough for pharmaceuticals. Don't get caught doing that by the authorities!
If you are looking at supplying 1/4 of the population - or even 10,000 units per day with several employees, you are better off to approach a packaging engineering firm to design you a plant. We have all the information you are requiring, and we will set you up with the greatest throughput for the number of employees you have available to you in the space you must work in. There are thousands of variables that need to be ascertained to come up with the best system for you and your product. Your product should be first consideration, anticipated production the second, and your budget third. You can always work with used equipment or "make due", but good plant design is more important to your budget than cost of equipment. If the system allows you to work with less people, you will always be able to pay off the loans by that amount ($40,000 to $50,000) per body per year.
If I had a dime for all of the "wrong" equipment I have had to install, then hear the complaints of "it is not working out the way I had hoped it would." - I would be a rich man. Right from the start is your best and cheapest opportunity to step up to the plate and knock the ball right out of the park. Have a plan and execute the dream. If the budget limits you, then do what you can afford - right now. Add on later when you have more cash available. Doing things in small well-planned steps is a much wiser business plan than to borrow 50 million on a dream, then find out there is no market or you need 75 mil to actually realize it.
That being said, there is a plethora of fillers out there for you to be thinking about. They are all better at filling different products with different consistencies. Again, we can't help you much if we don't know what you are doing. What you can do is search powder fillers to get an idea. Bottle fillers are available, and would work well for most hard packaging options. Pouchers are as well a great option, but maybe the waste that is left behind is worth too much for that approach. Fill-Form-Seal machines that do small catchup sized pouches are a dime a dozen on the used markets, and when paired with the right screw feeder, will provide very FAST accurate results - exceeding 120 packages per minute. If you are dealing with corn flour, then search "corn flour filling" and you will find out what the industry is doing. If your product is truly "new and revolutionary", then pick a product that you observe to be most like yours in behavior.
If immediate need is not that great, then buy a system that sits in a corner and runs at a slow rate all day. Most filling equipment is better off running all day, then it is running hard for 15 minutes then sitting for 23.75 hrs. Start-up and shut down usually result in a few minutes of "wasted" production. If that is 4 bottles it is better than if it is 4000 if the price per unit is $1000, and you only need 10,000 per day.
A search for "cappers" will yield more results than you can shake a stick at. However, "small bottle cappers" might be better. If you use something round, note that the best way to skin the cat is to spin the bottle as it goes by and hold the cap still (less moving parts and they are bigger). You will want labelers, case erectors and fillers, shrink wrappers and many more additional gadgets. A well engineered system can run staggering amounts of product with skeleton crews, and I have seen people do mediochre rates with TONS of people that walk around in circles and trip over each other.
Remember, that the largest cost to most companies is payroll, and those jobs are not lost if you replace them with equipment. You actually free people up to do work that is more suited to humans, and they more enjoy doing. Truck drivers are happier people than bottle slingers, and shipping product is more fun than sweeping it up off the floor. If your company starts with a small dedicated crew and you grow exponentially while the crew has slow planned expansion no one lost their job, you can afford to pay them more (which you have an obligation to do), and your profit margin is higher while knowing the people who work for you are truly looking out for you and your interests every day!
Good Answers: 117
01/25/2010 9:56 AM
Every business has five components.
Marketing
Manufacturing
Distribution
Financing
Retailing
They don't all have equal weight. For instance, manufacturing is normally the least important of the five. Yet, in the globalized world out there, there is a massive surplus of manufacturing capability. Surpluses drive prices down and causes manufacturers to compete among themselves, with a resultant loss of quality.
The most important one is financing. With enough money you can do anything, and of course, right now, money is inexpensive to borrow. Distribution is normally the deal breaker, and it is more important than you realize during the start up phase. Marketing is a war zone. Many people put retailing in there with marketing....the two items are totally different. Marketing is the advertising, retailing involves getting paid for your efforts.
Good luck. I certainly would not go into manufacturing of any product in this day and age without control of distribution and retail sales. However, this does not really answer your question though does it. If you are convinced that you want to make the product, do not waste any more time with home made whatzits...get a professional machine. Factory equipment is a glut on the market and is available for pennies on the dollar from professional liquidators.
A quick google search of machinery auction houses reveals several thousand listings. (did I mention that manufacturing is very competitive?) Lab equipment is fairly common.
http://www.labx.com/
http://www.labbay.com/?a_aid=fc3fb9ed
are portals to companies which have machinery like what you described gathering dust in their showrooms.
Another option is to limit your upfront expenses. Lease to own, rent, or lease your equipment first. Big advantages to renting are fixed manufacturing costs (banks "like" fixed costs) and you don't get stuck with a machine you can't return which doesn't quite do the job.
Any bank or venture capitalist will assist you in your endeavor. You will need to prove that you have a distribution contract, a patented or proprietory product, and that you meet all applicable regulations for sale to the pubic (you can't even make apple pies here in Canada for sale without a food inspector checking out your kitchen! A lot of people who once made pin money at farmer's markets are still raising hell about that!)
Good luck. You will need it.
Good Answers: 204
01/25/2010 12:37 PM
GA.
01/25/2010 1:38 PM
Hi Yusef1,
Thanks for your comment, very instructive. However, I disaggree on one thing, about "the most important one is financing". You are billionair and you have no idea, you use your money to live. You are without money but you have excellent idea, the world is open to you, and you will live with/from your idea.
In business, beancounters come at the end of everything and they want to tell people who created their affair, what and how to do everything. I worked and collaborated in a very profitable company without or very little accounting. When the business turned hands, within months the accounting destroyed the company by imposing too much control and they started budgeting.
See the actual economic disaster, which was created by Wall Street and "accounting experts".
For me as an opinion, research and development, manufacturing and marketing, which includes sales, are important, probably in this order. Finally, let accounting put the numbers together. So, revise the importance and the position of financing.
Remember about lack of money: Wozniack and Job don't have money. Markulla was interested about the idea and supplied the founds, isn't it? Oh, I talk about Apple!
Get a customer with a problem! Create a product or service to solve the problem! You will find the money to supply the solution! Believe me and my name is Gil.
Just an opinion.
Good Answers: 117
01/25/2010 6:15 PM
Ideas are the cheapest currency in the rough and tumble world of business. a handfull of "Popular Mechanics" and "Popular Science" magazines will show that.
You put Research and Development ahead of financing and marketing? Interesting. I would not put it in such a prominent position.
That company that was doing so well before the accountants started running it. It sounds like you have a problem with accountants....grin! You know, accountants don't "run" anything, they merely show the whole world that the company has dirty underwear.
On a not very closely related note, (only because you brought it up) it was not accounting experts which caused the Wall Street disaster, it was a few criminals who happened to be bankers who were riding a housing bubble which popped. They did it with full knowledge that the mortgages they were bundling and using as collateral were pretty much worthless. Worthless collateral resulted in worthless loans, which resulted in banks ending up on the ropes, and the companies who depended on them going under.
But, I think this whole discussion is off topic...the guy only wanted to make a machine to fill his pill bottles....
Your name is Gil and I believe you....
01/26/2010 10:40 AM
Hello Yusef1,
I don't read the magazines you mentinned. I prefer to listen to people with some problems, mainly around their houses, and try to satisfy them with a valuable solution for both parties. They need to be happy with the result and I have to make some profit to do the next move. To do that, I have to experiment, test, etc..., and finally create a product or a service for the final solution. At that moment I become an accountant? Probably not! I am not an accountant. But I can calculate what will be the selling price of my solution, including some profits.
As I mentionned, marketing, fulfillment, and production are the business, which produce the profits to survive and maintain afloat everything to the next customer. Accounting starts when I deposit money in the bank. They ask: How we can increase to profit for the next time? How we can sell more? And, that moment the company start to be controlled by the accounting department. Like in the past, in a billion dollar company, accounting defined who buy the raw materials at the cheapest price to make the products. The lowest price was all the time the winner, which created replacing one by another, creating variations! I quit around 20 years ago, and I never worked again for a corporation. The billion dollar business has constant quality problems, non profitable, and sold out. They are bigger than many other companies making the same products but the smallers produce better quality.
R&D is important to create solutions, and accounting and financial problems come after marketing and sales, product creation, and supply, never before. Today, many businesses start with R&D alone. The future "green" works today only in the labs.
In the Wall Street's catastroph, the few criminals are probably all accountants or close by using the same theories. Who knows the tricks? Yes, you have! The accountants know what and how to do it! In banks there are all accountants, and banks landed the wothless loans to people.
After my opinion, this was a good effort to show to eventual business people that other things are more important than accounting like many suggest. The "guy" only want to make a machine to fill his pill bottles, I agree but do first the pills and count the cents after, Gil.
Just an opinion.
Good Answers: 117
01/26/2010 11:57 AM
I think you and I might have different definitions of what an accountant is...I regard an account as an asset. The score keeper. The guy that fills in the tax forms and profit-loss statments. You say that accounting only starts when you put the money in the bank. Well, you have to get the money into the bank. Thats WHY you are in business. I think the people you call the "accoutants" are actually the owners and stakeholders in your business. Often they give themselves names and titles like CEO, or "Owner" or "stockholder". Makes sense I guess, If I put money into your business, I don't care how you get the money to pay me back, just do it, and get me a profit.
To use your example of poor sourcing resulting in inferior and unsaleable product.
The accountant will not recommend a cheaper source for your raw material...the purchasing department will do that, the engineer will approve it, the ceo will approve it, the marketing director will sell the cheaper product to the customer and the cfo (that would be the accountant...;)) will determine if sufficient profit results from that decision to pay back the investors with a nice bonus. Note that any of those people have the power to refuse to sign their name to the bottom of the purchase order EXCEPT the accountant. They all take responsibility. The accountant just makes sure that the right people get paid. If you have a really small business (one person) then that person will be the one who takes responsibility. But if the bank gives you the money to start up, you will have to take time to build a profit-loss statment to satisfy the bank, and you will have to fill in the tax forms to satisfy the government. I personally employ an accountant to do that, which allows me to get on with running my business.
So we are agreed on everything....except possibly the names we give to the different jobs we all know need to be done. And that is easily remedied.
I like your attitude. You and I have clearly been to the university of hard knocks. I have seen many businesses start up and then fail. We learn more from the failure than we would ever learn from the success. I especially like the way you communicate with the customer and find a need and fill it. One forgets in the hurly burly of machinery purchasing, bank loans and zoning regulations that in fact it always comes down to convincing people to open their wallet and buy your product. Without that, nothing else matters.
Many factors can result in success. A positive attitude won't pay the rent or fill a single jar. But a positive attitude WILL get you out of bed, on the road, talking to customers, meeting problems head on and solving them. You need a positive attitude to deal with machines which don't perform as well as you would like, with employees who slack off and are dishonest, with power tripping bankers and customers who don't pay. In fact, upon thinking about it, I might add "positive attitude" as the sixth leg which holds up a successful business. For that alone, I salute you.
Regards. Now I have to get back to my own business....
Good Answers: 204
01/26/2010 2:19 PM
well said. GA.
01/27/2010 10:11 AM
Hello Yusef1,
Today, I would like to add something valuable to my previous explanations: Who makes money and about accountants and their value in a business, small or big. I quote: "How can we improve the ability of a company to make more money? The theory of Constraints clearly states...; there are only three avenues open to increase money making. The three avenues are: (1) to increase Throughput, (2) to decrease Inventory, (3) to decrease Operating Expense. The following formula explains it:
ROI = (T - OE)/I and NP = T- OE
Where ROI = return on investment, T = throughput, OE = operating expense, I = inventory, and NP = net profit.
My personal remark: Toyota, Hyundai, and many others work on inventory and throughput, Chineses and Indians work on operating expenses, Nissan works on return on investment. All of them produce profits in the factory by making sellable things.
Engineers, scientific, and working people elaborate processes, create machines, instruct, teach, and correct working individuals, which give the companies the ability to produce what they sell as fast and as a low cost as possible. This is the only way a company makes profit, and counted by accountants. Cost accounting is the job for accountants. Bravo to all people and get compensation to the merit.
"E. M. Goldratt: Theory of Constraints" is the book to read.
No more argument, no more disconfort from me. Wish you a happy day, Gil.
Just an opinion.
01/25/2010 11:09 AM
You might look into a custom packaging shop. Let someone else who has already spent the money on their equipment do the packaging for you. The per piece price will be a little higher but you will not be out the expense of your own package line at the start. You can spend your money on building your business and marketing your product line. After you have established your market you can then start looking into in house packaging to lower your costs.
01/25/2010 11:49 AM
Happy New Year GARRS,
Start your small packaging business with the hand filled system! Your success come from the SALES of your small jars containing the medicinal powder. At the beginning of a business, never or very rarely comes from the process or the machine does the packaging. The product does the miracle!
When the volume of production will become problematic, hard to fill orders, ask someone else to package your medicinal powder.
When really, your volume of sales are really high, be ready to copy what someone else does already for you. Don't forget to open your eyes, all the time! Copying and improving is the way to work in the past, today, and I am sure in the future. You will be a happy person to be able to improve the old fashion machine or/and process to fill small bottles with powder. If you cannot do, ask someone else.
Before you reach the stage of what you really want, start to pack the first small jar, and you have the time to think about automation and during this period of time, you can get information about everything you want. The world is open to everyone but you have to do something before. There is no compensation without work, Gil.
Just an opinion.
Good Answers: 204
01/25/2010 1:02 PM
If this is a small home business as you say, and (are looking for something really cheap)
If you are looking for a way for one person to fill thousands of bottles per shift, and
if you have a hopper of the powdered material available,
I suggest an indexed wheel with 'buckets' on it.. (say the size of a bicycle wheel, but you will have to experiment to get the size)
each 'bucket' will be a small scoop that self-levels to the correct amount of powder.
The hopper might have to be vibrating to keep the powder moving to the centre.
the operator can index the wheel by hand. Their operation would be to hold the receiving bottle under the scoop about to empty, and move the wheel one arc-position, which will pour the powder into the bottle. The operator then caps the bottle and repeats the process, or hands the full bottle off to the next stage in the process.
might be worth a try, but expensive if you have to make it all out of stainless.. mock it up first with available materials, (bicycle wheel) and try with sugar or something... see if it works..
Chris
01/25/2010 1:41 PM
Hi Chrisq288,
Excellent! It's a real change from your GA! Bravo!! Continue that way, Gil.
Just an opinion.
Good Answers: 204
01/25/2010 1:51 PM
It occurs to me that if you design the scoops just so, that you will be able to put the bottle up to the scoop before it starts to pour, and have almost zero spillage, and be able to fill bottles almost as fast as you can handle them... easily filling thousands per shift. five seconds per bottle should be do-able.
PS... so do I get a GA rating from you?
I didn't change my thoughts... what I am proposing for you is the 'low end' solution. I still think Yusef's (among others) comments are highly constructive and knowledgeable.
thank you
Chris
01/25/2010 4:21 PM
Hello Chrisq228,
Don't ask, I give you the "GA"! Your idea, as already mentionned, excellent, and we can seat down and talk, modify, and finally create something very interesting but we have to wait and get some words from the person who needs the help. Many blog is just a question and lots of answers but no one knows what's the final result?
Concerning your first GA, I already gave my opinion on financing.
Again, after me, in business must be structured around the market and never the product. We have three things in a business;
1) Marketing, which is identifying the market, learning how to communicate with it, and maintaining it with effective sales and customer service. Marketing earns money by communicating with customers so they are encouraged to buy.
2) Fulfillment, which is getting the product or service to the market that are distribution and delivery. Distribution should allow to reach as many different customer bases as possible. Delivery is the way products are physically moved to the customer. Fulfillment service earns money through distribution and delivery of product.
3) Production, which includes that someone has to make whatever was planned to sell. In production we have "raw materials", "Processing", and "Finished products". Production earns money by creating the product marketing sells.
My difference with the importance of financing mentionned, financing is an operation, and operations, "legal", and "financial", never produce money, they are only cost money. The value-added to a product is coming only from the "processing" part in the production, and never from financing. Financing is pure costs and never produces profits to the finished product, processing, yes. Also, financing never promote quality, they push for profits that is the cause of lower quality. However, in any business quality is an essential ingredient for success. And only processing makes what is expected, quality.
Any business operated well can be profitable. It's important to keeping the business as simple and streamlined as possible. How someone conducts the day-to-day operations of its business depends on the operational structure. Must be clearly defined, flexible, and simple at the same time. Never forget, the most important aspects of a business is communication, in-side and out.
These sentences, I hope must or will be the starting moment of the well filled small jars, Gil.
Just an opinion.
Good Answers: 204
01/25/2010 5:12 PM
sorry I thought you were the OP.
"financing never promote quality" I totally agree.. shouldn't be that way, but...
Chris
01/26/2010 12:01 PM
Hi Chrisq288,
Some automation comes with the addition of a horizontal wheel containing funnels with a trap at the end and passing 90* to the other wheel. Another horizontal wheel containing the empty jars and turning opposite to the funnel wheel underneat the funnel wheel. The vertical wheel drops the powder into the funnel with closed trap at the end of the funnel. The second, underneat wheel receives the powder into the jar by opening the trap at the moment when the jar is under the funnel. All three wheels can move in a rhythm. The opening of the trap can be made by a fix stick pushing the trap to open at the right position and when the powder is in the jar, the wheel moves and the stick has no more contact with the trap, the funnel is closed to receive the powder again. Here we have to use hands to put the empty jars and take off the jars once filled.
Sorry, I have know knowledge how to make the design or graphic but I am sure, you, Chrisq288, can do and we start the improvement process again.
Question: What means PO? I am ignorant about it! Make me smarter! Thanks, Gil.
Just an opinion.
Good Answers: 204
01/26/2010 2:15 PM
Gil,
PS means "Post Script", which identifies a message occurring at the tail end of the main message... sort of a parting thought.
I see your trap doors, but don't think they would be necessary if the scoops have those 'pockets' I showed. but like I said, there is no substitute for a cheap prototype, as you can't model the behaviour of the powder; only guess at it.
Chris
PS. to give a GA means to press the rating button and vote 'Good Answer'..
01/26/2010 1:12 PM
Hello again Chrisq288,
Concerning Yusef's comments, I am with him. He descibes exactly what and how things happening in big companies. The difference is that he talks about big companies or corporations, and I just want to elaborate about a starting business as the "powder in the jar" dreamer wants and can succeed. When you are a dreamer and you want to realize this dream, you enter in a "niche market" or start a "niche business". I already started niche businesses but partnership was a big handycap, and I closed or stepped out before disaster.
My idea about business is simple, and is the following as I already did: Develop a system, which could be turned into a business that no one do at the moment and you don't want to do. Being to much to invest to start or you don't liked for you. Propose this idea to someone who can and wants to transform into a separate business. And, supply what this separate business needs and you are able to do, which gives you your business, affordable and pleasant for you.
You alone know and understand both businesses and if the other business is growing with or without your help, you grow with it. So, choose your first idea's business person as the best of the bests but not a friend or member of the family.
In the other hand, if my business is growing too much. For example, I need more than 10 or 15 persons, I split the company in two or three separate businesses. Each new business does specific things to satisfy the original business, which is still your customer.
I am believer in small organizations as simple and streamlined as possible where objects and communications are flowing freely, instantaneously, and without deviations. I respect others ideas but I stay in my world that I know, Gil.
Just an opinion.
Good Answers: 204
01/26/2010 2:21 PM
I think you would be a valuable asset in a small business! large companies would make you a bit crazy like me... lol.
I understand your point about 'accountants' and have certainly worked with cfo's who had too much power. but I agree with Yusef's insightful definition of titles, and 'ought to be' description.
Chris
01/26/2010 4:29 PM
Thanks for the good words, Chris!
Absolutely not, I don't want to work for nobody except myself. I have a small business and it's fine for me. Ideas, I sell or give away for free, depending the person is in front of my nose.
I talk about niche business or small organizations and Yusef explain clearly the situation in corporations. I was twice in a company included 36,000 and more people world-wide and when a small group was created the work was interesting but when the power is in the hands of people who are managers with MBAs and accountants, everything is getting worsth and impleasent, and the results are the same, lousy. My question is: Why organizations who want to make money give those people the power to achieve what's the final results? I have no other answer: People like ignorance to dominate! I hope one newspaper reporter read what we talk, and put her/his conclusions in the front page of a major paper. All the best, Gil.
Just an opinion.
Good Answers: 117
01/26/2010 4:23 PM
Good answer Gil.
03/21/2020 11:34 AM
Wish you good luck!
Good Answers: 117
01/26/2010 12:10 PM
"I need to design a machine that will drop powder into small 1/4 oz jars or medical pots for retail sale. I have decided to cheap fabricate something out of pvc and have a few ideas how the spill port should work."
A hopper over top a horizontal plunger. Every push of the plunger pushes out a measured quantity of material into a spill port. When the plunger pulls back, it refills, and rachets the bottle line forward. Easy to build even out of steel. Easy to automate.
Good Answers: 204
01/26/2010 2:06 PM
GA... there will be eventual wear and tear on the plunger and sleeve, but basically a neat and simple solution.
01/26/2010 9:04 PM
Hello
You can use a funnel and a measuring bowl of required size to fill the jars.
It would be quite simple operation.
Good Answers: 204
01/26/2010 2:10 PM
In order to use adhesives such as are used in typical pill and vitamin bottles, you need to contact a 3M representative.
I have a plastic bottle of powdered crystals. it came with a thin styrofoam seal, under the screw on cap. I believe they apply a thin adhesive layer to the lip of the bottle before applying the foam disk. the lid then applies the pressure to set the seal.
other sealing advice has already been given, and is valid.. get some used equipment. watch more episodes of "How It's Made"
Chris
01/26/2010 9:52 PM
Hello
Good Answers: 117
01/27/2010 9:46 AM
I tried that as an experiment....got ten funnels, ten containers. A bag of sugar and a measuring spoon. I decided to ignore set up time. step one...place containers on table. step two, place funnels in containers. step three, scoop sugar out of a bowl, strike off, and drop contents into a funnel. Move on to the next. Pick up the funnel and put it into a fresh container. The operations were fairly simple, and I timed it with my stopwatch for a couple of minutes.
The best speed I could do was about 12 containers in a minute. With practice, I might be able to fill two dozen in a minute, but there is also the time spent unpacking the fresh containers, spinning tops on, and packaging the results which would reduce my speed even further.
Fifty dozen in an hour by hand. Thats not too bad. A couple of days to build up an inventory. If you paid yourself (or that homeless guy you hired) fifty dollars an hour (wow!) the packaging operation would add only add a dollar a dozen to the manufacturing costs. Thats good enough for a start up. But then it would be sales which would determine if there is sufficient demand to speed this process. You won't be able to "replace" the worker with a machine though...the worker will still need to be there to run the machine, unpackage the bottles, move the filled bottles to the capping station, and keep the hoppers filled.
So the KISS principle applies yet again! Yeah, so, like, good answer!
01/27/2010 10:33 AM
Hello Yusef1,
Stop to tell people what to do, they will make too much money, and at the end you have to loan money from them. It's catastrophic for the initiator of a process but it happens the most.
Excellent suggestion!!! Again, I would like to hear from the dreamer of the project, how happy is with all these comments for his future business.
Wait for an answer, Gil.
Just an opinion.
01/27/2010 8:24 PM
Hello,
You can fix the position of the funnel and you can provide the movement to the jars to be filled. so you can reduce by two step. If the funnel is fixed your both hand would be free.
Thank You
02/03/2010 1:55 PM
Hi Amit,
Excellent suggestion! What I have to do with my two free hands? You see, when we want to teach someone something, we have to explain everything clearly because we are limited in brain operation. The food we eat every day doesn't supply all chemicals that is necessary to transfer neurons to neurons the learned sentences and catch everyone's ideas and apply immediately as were explained.
When we provide movement to the jars, we start to automate the system and this is a home business to start.
So, now I understand what I need to do with my free hands, move the jars! It's OK, I move them, stop and fill them, move them and fill them again. Perfect!
Thanks and I go to apply, Gil.
Just an opinion.
02/03/2010 2:20 PM
Hello Chris,
I visited the equipment maker. They have excellent high speed filling machines. I used a paint filling machine for decades with evolution around every 5 years. I still have a friend who is a mechanician and making equipment, and we, together, we progressively obtained the fastest and most productive filling machine after 25 years. You know what? This machine is a single head machine with two separated tracks to fill 28 gallon per minutes or 14 per head. One they I visited probably the biggest paint manufacturer and they told me during the visit that this filling machine, pointed with a finger, fills 90 gallon per minute. Holly cow! I was impressed, and asked how many heads you have on the machine. They answered in chorus, 12 heads! I have no more question. I took my small calculator and divided 90 by 12. The result was only 7,5 gallon per head. My machine filled 14 per minute! So, I was a genius! Cheeze, it's not possible that the biggest company is not competitive with my process or machine. Also, we took 12 gallons, weighed and tinted each. Variation by wieght was from low 5.5505 kg to high 5.6250 kg. Imagine the tinting strength of those two opposite weight gallons? Visully, they were very different to our eyes. My filling machines variations went from, for different paint, 5.7800 kg to 5.7950 kg and the tinting strength doesn't produced visible variation.
Without variations, the customer come back to buy more paint. With perceptible variation the customer can claim another gallon, don't come back and goes to another store to hope for better results.
I am not a mechanic but I like to think about equipment I or around me is used.
Thanks for the web-site, Gil.
Just an opinion.
Location: 3017 Ravine Trail, Carrollton, TX 75007, United States
11/17/2025 2:49 AM
You have already identified most of the right questions: filling accuracy, operator safety, packaging presentation, and future automation. Let me suggest a practical roadmap that keeps startup costs low but does not trap you when orders grow.
  1. Start with a very simple manual filling system
    • Use a small hopper and a volumetric scoop or plunger design that always delivers roughly 0.25 oz.
    • For powders that flow well, a horizontal plunger under a small hopper works very well: every stroke dispenses a fixed cavity volume into the jar.
    • Keep everything in food or medical grade material from day one, even if you are still “prototyping,” so you do not have to redesign later.
  2. Think about product and regulations before the machine
    • If the powder is food, cosmetic, or medical, check local regulations for GMP, labeling, and tamper evidence before buying or building equipment.
    • Your choice of jar, seal, and label is often driven by those rules, so it is safer to finalize packaging format first, then design the filler around it.
  3. Jar closure, tamper evidence, and labeling
    • For low volume, hand applied twist caps are fine. You can add:
      • Induction seal or pressure seal liners under the cap.
      • Shrink band around the cap for visible tamper evidence.
      • Branded custom labels and stickers to carry ingredient details, dosage, safety warnings, and barcodes in a professional way.
    • Later, you can add a small semi automatic capper that simply grips and tightens the caps as jars pass under it, but the closure type should be something standard that existing cappers can handle.
  4. Operator safety and powder control
    • Your idea of a small ventilated enclosure is good, but keep it as simple as possible at first:
      • Local exhaust near the fill point.
      • Smooth internal surfaces that can be wiped down quickly.
    • Avoid PVC in any contact or near contact surfaces. Use stainless steel or approved plastics that do not hold static and are allowed for food or medical contact.
  5. Packaging and outsourcing as a bridge
    • For early stages, it may be smarter to focus on proving demand and brand rather than owning the whole line.
    • Contract or custom packaging shops already have fillers, cappers, and labelers. You can start by outsourcing filling and only bring it in house when volumes are stable and justify capital expense.
    • This keeps your initial investment focused on product, branding, and sales instead of machinery that might not match your real future volumes.
  6. Plan automation as a series of small steps
    • Stage 1: Manual filling with a simple volumetric scoop or plunger and hand capping.
    • Stage 2: Same filling principle, but with a simple indexing mechanism moving jars under the outlet.
    • Stage 3: Add a small capper and basic labeling machine.
    • Stage 4: If demand is truly high, upgrade to a used professional powder filling line that uses the same jar and closure format you started with.
In short, you do not need a complex machine to begin. Start with a safe, repeatable manual method that uses compliant materials, prove that the market really exists, and let the filling equipment slowly “catch up” to your sales instead of trying to solve the high volume problem before the first jar is sold.
Good luck with bringing the idea out of your head and into the market.
biz expert
03/19/2026 12:26 PM
Thanks for such a detailed breakdown — this is really practical advice. I like the idea of starting with a simple volumetric approach and focusing more on consistency rather than over-engineering the system early on.
The point about finalizing packaging and regulatory requirements first really stands out. It’s easy to overlook that and end up redesigning everything later.
Also agree with your view on outsourcing in the early stage — makes a lot of sense to validate demand before investing heavily in equipment.
Overall, this roadmap feels realistic and scalable. Appreciate you sharing this.
Register to Reply 46 comments
Amit Jain (2); Anonymous Poster (2); artsmith (1); bioramani (1); biz expert (1); BuzzardBait (1); chrisg288 (9); cwarner7_11 (1); edward beetz (1); Frank Designs (1); Gil Becker (12); Greg Bjorg (1); GW (2); jack of all trades (1); michael.clark (1); user-deleted-1105 (1); welderman (1); Yusef1 (6); Zoomer (1)
