Previous in Forum: NPSH for submerged pump   Next in Forum: Evinrude problems
12 comments
Hydraulic testing for piping system
01/23/2010 6:58 AM
Hi All,
I have design and fabricated as piping system. Pipe sizes are 1/2" and design pressure is 200 barg. As per AS standard I have to carry out hydraulic test for 300 barg for 30 min. My hydraulic pump only helps to bring the pressure to below 100 barg. I would like have some advise or suggestion to achieve the hydraulic pressure of 300 barg.
Thanks and Regards
Re: Hydraulic testing for piping system
01/23/2010 11:29 AM
Simple and obvious: get an other pump able to rise the pressure to over 300bars!
01/23/2010 6:34 PM
Another suggestion is to plug all the ports, FILL IT COMPLETELY WITH HYDRAULIC FLUID, and then use a nitrogen cylinder at high pressure to pressurize the system through a nipple and a pressure regulator. Be sure to install a regulator with exhaust and/or a valve to depressurize the system. Nitrogen is used because it is cheap and avoids system contamination. If you do not fill with fluid and try to pressurize with gaseous media, in case of failure, it can explode. Also, be sure to conduct the test in a safe way, ok?
Humm... suspicious you are...
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
01/24/2010 12:09 AM
AND if the pipe DOES fail, the nitrogen cylinder will completely empty your system before you have time to blink your eye!!!!
What you should be looking for is a small porta-power hand pump and a check valve. Fill the system completely with hydraulic oil then connect the hand pump and very carefully give the system half a pump (ish) through the check valve and watch the gauge rocket up to your test pressure (be very careful not to pump too much as the pressure increase will be very rapid if the system is adequately sealed). Then watch for any leaks or pressure drop.
This is called a hydrostatic test and if your pipe work does fail, you will only notice the pressure drop and a perhaps few drops of oil!
Good luck with it!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
01/24/2010 2:21 AM
Hi Bee,
I have a hand powered pump, it is helping to bring the system pressure upto 100 barg, If your suggeting pump (small porta-power hand pump and a check valve) can go more than 100 barg to my test pressure. Could you please give me more information about this pump.
Regards
01/24/2010 4:10 AM
Hi msmroomi
Yes, SPX Power Team make a hand pump with max pressure of 10,000 psi and so do Enerpac. I expect that you could go to any tool hire company and hire one for the afternoon.
Remember that the hand pump fits to portable tools like jack cylinders etc with a special hi pressure screw fitting (male and female) so you will need to hire (say) a small cylinder as well and 'borrow' the fitting on the cylinder to fit your pipe system.
Make sure that you use a gauge that can take the full 10,000 psi AND DON'T use nitrogen gas unless you are very confident that there will be NO leaks or if you are prepared to get VERY wet!
01/24/2010 4:03 AM
I believe they make an pressure multiplier (intensifing) units, I google and this came up, can see if there are smaller ones..............or make one, if the pipe is flooded it does not take much.
p911
01/24/2010 10:39 AM
GREAT SOLUTION, I AM ASHAMED TO SAY I SHOULD HAVE BEEN ABLE TO COME UP WITH THE SAME SOLUTION AND DIDN'T. MAYBE I NEED MORE EXPERIENCE, I'M ONLY 60.
01/24/2010 2:14 AM
Hi All,
Nitrogen cylider is helping me to go upto 200 barg pressure, However my system test pressure is 300 barg. Is there are any way of getting this pressure?
Cheers
Good Answers: 27
01/24/2010 10:51 PM
Just forget that you ever heard about using gas - sort out the hydraulic hand pump. (as stated by others)
I have no special talent. I am only passionately curious. Albert E
01/24/2010 10:27 AM
Tim Hawley Master Mech.
Hello msmroomi,
300 Bar is equal to 4,351 PSI. Before testing this high pressure you must have a pump output more then capable to meet the requirements. All pipe and fittings must be rated above this pressure value including your regulator and pressure gage. YOU MAYBE AIMING FOR A LAW SUITE, if you are not careful with all components to meet your desired output.
Perhaps this link will help you calculate the required pump, motor: horsepower and RPM required to fit your needs.
http://www.precisionfluidpower.com/fluid_power_formulas.htm
Good Luck,
Best Regards,
Tim
02/01/2010 3:13 AM
Hi All,
Thanks everybody for contribution,
Regards,
Engineering Fields - Systems Engineering - Member for some time now, see my profile.
02/04/2010 10:53 AM
msroomi
Do not forget that pressure testing can be extremely dangerous.
Any personnel need to be behind strong bunds/ walls.
CCTV to observe,.
Good instumentation at remote location
I assume that you have such facilities available.
Do not presure test and put yourself and others in jeopardy.
Sleepy
Register to Reply 12 comments
Anonymous Poster (1); Beej50 (2); bhrescobar (1); CONWAYMECH (1); crstn (1); Kaisan (1); msmroomi (3); phoenix911 (1); Sleepy (1)
