Previous in Forum: memcapacitor   Next in Forum: Higher Nb content in SA516 Gr.70N
9 comments
Is it possible to create XV Ice
01/23/2010 3:26 PM
I am currently working on a glass speaker project and aim to build the carcass out of glass with a 15-20 mm cavity. The cavity is to be filled with water and ice XV replicated, providing a thick dense barrier. How is it possible to replicate conditions in this manner to create this amorphorus Ice. The ice xv substance is created in laboratory conditions has been obtained from ice VI, by lowering its temperature to about 130 degrees Kelvin, around -143º Celsius, the mix was then subjected to a gigapascal, or 10,000 atmospheres, of pressure. What alternatives can be made.
Thank you very much for taking time to read this question all replys are welcome and appreciated.
FAB4440
Re: Is it possible to create XV Ice
01/23/2010 3:38 PM
United States - Member - Member in Good Standing
Good Answers: 61
01/23/2010 4:22 PM
Based upon what I'm reading, for it to exist ice XV must be maintained at very low temperature and very high pressure. It is also extremely dense. Which suggests to me that if it were to be placed into your enclosure and then allowed to warm up to say, room temperature, the speaker would probably explode with considerable force. This strikes me as a Bad Thing.
Have I missed something?
DrMoose
01/23/2010 5:23 PM
You present a few confusing ideas here.
The variety of states of any matter are stable only within the regions of pressure and temperature discovered for that state. So you cannot have liquid water and ice XV together in the same pressure and temperature. (Actually one can only briefly do this, because heat transfer does not happen instantly.) Ice XV was only recently realized in a laboratory anywhere, so it certainly cannot be easily made. The cavity you wish to fill with this extremely exotic ice must maintain the pressure of at least a gigapascal and warm up to no more than 130K or your ice will not be ice XV. So unless this will be extraterrestrial, like in the clouds of Neptune, you will have to chill and pressurize this in some fashion to meet these conditions here on Earth.
Lastly I've used a glass beaker many times. I have no idea what a glass speaker is or what kind of carcass with a cavity it will require. Several speaker cabinets use fiberglass for their walls, these do have cavity space intended to carry air that the speaker driver will affect. Some drivers do use fiberglass for the cone material. But while I don't think that this is what you mean, it is the best that I can come up with.
01/23/2010 6:30 PM
Definitely, it is impossible to understand what you tried to describe. Cavity filled with water and ice XV? Both together? What is the purpose of filling this cavity with a very dense material? Absorption? Reflection? I think there is a number of other simpler, less expensive and widely available options to consider, even if you wish to build a completely transparent device. As already said here, you may use fiberglass. With the correct resin, it becomes transparent. BTW, you stated "this amorphous kind of ice..." - all ice types are "amorphous" in this way, i.e., do not retain a specific structure at large scale (meaning, something like 0,1 micron... hehehe).
Humm... suspicious you are...
01/23/2010 7:06 PM
Only three are amorphous; the rest of the 16 are crystalline in some way or another. The densest is Ice X at 2.51, versus Ice XV at 1.30.
Snowflakes are larger than 0.1 microns, and rather clearly crystalline rather than amorphous.
I too would like to know more about what the OP really has in mind.
01/24/2010 8:04 AM
Thanks for the tips. The problem is that I am used to deal with steel. For me, amorphous and crystalline structures are a bit different things... I think I was caught by that hydrogen bridges...
01/24/2010 8:56 AM
"How is it possible to replicate conditions in this manner to create this amorphorus Ice." Let's just say that it isn't practical, now, outside the laboratory.
What property of ice xv makes it desirable for your application?
And, although I've been around speakers for a while, I've never heard the word carcass used in any context other than to describe something that is dead and useless. Please enlighten me.
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
01/24/2010 4:13 PM
I am curious and impressed by your manufacturing plant. Not many facilities can reach these temperatures and pressures. Please tell me more - I am fascinated.
01/26/2010 1:32 PM
Thank you all very much for your answers and for giving me a gentle cuff to the back of my head. The reason for the ice was to create a very dense material for the speaker. Quite rightly i completely forgot about heat transfer although that can be achieved. I was wondering if ther was more light to be shed. As i do work for a high audio outlet it is just as well i have an alias, and the fact that i attend LSBU, will try and find my way over to the laboratory...thanks for your time.
ps. is there material that morphosis to that of ice, as this is theme of the speaker which will be made of glass
Register to Reply 9 comments
bhrescobar (2); Chankley (1); DrMoose (1); fab4440 (1); lyn (1); redfred (1); Tornado (2)
