I need to set up a float system using two 11 pin relays and a timer and am not sure how the best way to wire. when float 1 is low (closed) I need to active #1 pump and mixer. When float goes high (open) I need #1 pump to stop and mixer to continue 20 minutes. After mixer stops if float 2 goes low (closed) I need to activate pump 2. Pump 2 may not activate while mixer is running! I am using 2 Omron MK3p5-S 11 pin relays and a Macromatic Tr-51622-16 off delay timer relay. I can think of 2 different ways to wire, is there a "right" way to do this?
