Previous in Forum: Thermocouple and thermocouple machines   Next in Forum: Alloyd Rolls
Frequent Pipe Leakage Problems
01/25/2007 7:15 AM
I am working in company manufacturing vacuum salt. We are facing frequent leakage problems in the company. Can you people please suggest the material to be used in the brine and condensate line. For condensate the temperature ranges from 100 C to 60 C for different lines. Also the plant is very old so standardisation of the lines has to be done.Can you guide me in this task.
Re: frequent pipe leakage problems
01/25/2007 7:30 AM
Try plastics for brine, either PE, PVC or ABS.
Try 316SS for condensate as plastics won't perform at the temperatures indicated.
Re: Frequent Pipe Leakage Problems
01/25/2007 10:42 AM
For 100 C plastics or PVC tend to look like spaghetti. Threaded CPVC is your answer.
I found a link to a CPVC specification your use. http://www.harvel.com/piping-cpvc-specs.asp
(KISS) Keep it simple, stupid
01/26/2007 8:56 AM
If you are using 316 Stainless Steel pipe, use Teflon pipe dope (or some other pipe dope) DO NOT USE TEFLON TAPE on Stainless Steel pipe as you will have leaks.
Engineering Fields - Piping Design Engineering - Environmental Contractor United States - Member - Born, raised and proud to be Texan Safety - Hazmat - New Member
01/26/2007 9:38 AM
I agree. If possible I would weld the pipe & fittings and make connections with flanges.
Believe none of what you hear......and only half of what you see.
01/26/2007 9:59 AM
You might want to look at Cured In Place Pipe (CIPP) that uses thermoset composites to wrap pipes. Contact me through our website at,
reinforcedpolymers.com
Bob
01/27/2007 7:46 AM
Hi,
I would use plastic pipes, even for condensates. Polypropilene can withstand up to 100 ºC.
01/29/2007 11:56 AM
If its the pipe corroding you could try super duplex stainless steel, it quite expensive though
Register to Reply 7 comments
Anonymous Poster (1); Euronium (1); mechtech (1); Mixerman (1); Pepper (1); PWSlack (1); TLGEngrCo (1)
