Previous in Forum: How to Design a Condenser   Next in Forum: Filter Ratings and Hydraulic Systems
Contra - Rotation Schematics
01/27/2010 2:39 AM
I'm an student on my way to earning my A&P license and a AS degree. i'm real interested in that plane you see in the breitliner watch advertisement, the one with the counter rotating props. i'd like to get a parts breakdown or schematic of that system. schools to preoccupied with there own curriculum and aircraft manuals are too expensive. anyone have any ideas on where i might look to get some information. thanks - Steve, skrug2010@live.com
Re: Contra - Rotation Schematics
01/27/2010 8:05 AM
http://en.wikipedia.org/wiki/Contra-rotating_propellers
http://cr4.globalspec.com/thread/45769, plus it denies other readers the chance of learning from, or commenting on, what has been written.
Good Answers: 183
01/27/2010 10:36 AM
Picture shows a possible transmission for 2 counter rotating propellers which get power from only one engine.
The principle is :
a- The number of external meshing has to be uneven and the number of internal meshing can be either even or uneven.
b- In the first stage rpm are increased and in the second reduced to initial value.
There are a couple of conditions to be respected:
- The gears have to be assembled and if parallel pairs Z2+Z3 are used which often the case for reduction of the transverse dimensions then for more than 2 also lateral conditions have to be considered.
If we assume that Z1/Z2= I and if the radial gap between Z3 and center line is Δ then we get a couple of equations leading to limitations in the choice of values.
The first limitation is that "I " MUST be >2.
The second coming from the assumption that The number of parallel paths is 3 leads to:
Δ/Z1 >0.5*(1-sin(60°))*(1+1/i).
Although according to Wikipedia there are 2 engines for 2 propellers I thought that for the student you are it will be interesting to know how such a transmission could be when only one engine (or motor) would be used. This can help you in other cases when you could be confronted with similar question.
01/27/2010 10:56 PM
thank you, i believe i understand your schematic. the last on the right, is it an inner cut gear? ( if thats what you call it).
Good Answers: 183
01/28/2010 5:30 AM
YES
Is it the only question?
01/28/2010 1:00 PM
This idea is used also in marine high performance systems. I think Volvo Penta is doing something along those lines.
Anonymous Poster (1); nick name (2); Not too Smart (1); PWSlack (1)
