Previous in Forum: How Much Does a Shaft Bend?   Next in Forum: Type of Mechanism in Back Hoe
Pipe Standardization
01/25/2007 8:27 AM
Can anyone please tell what the things to be taken care while standardizing pipes?
User-tagged by 1 user
Re: Pipe Standardization
01/25/2007 10:30 AM
I'm trying to figure out exactly what you are looking for. Do you have a specific application, because there are hundreds. I'll give you some. Piping comes with a specific wall thickness or schedule. There is type L and type M copper pipe. L has a thicker wall. There is black iron screwed pipe schedule 40 and schedule 80. There is also welded schedule 80 pipe. Engineers will always list a pipe schedule in the spacification. If you have a specification or application, we might be able to answer your question.
(KISS) Keep it simple, stupid
01/25/2007 11:31 AM
Do you need to specify a pipe from the standard?
Send the numbers, I'll be glad to help you.
Humm... suspicious you are...
Good Answers: 19
02/01/2007 10:24 AM
See my reply in Civil Engg on reply to comment by vdik subscribed to:
Natural gas transmission pipeline -Construction2-Valves where I've mentioned all on Natural Gas. You can go to the sites and find out on other medias.
Register to Reply 3 comments
bhrescobar (1); ducon (1); TLGEngrCo (1)
