Previous in Forum: Online Leak Repair Products for Crude Oil and Natural Gas   Next in Forum: Making Aluminum Parts Non-Conductive
Pickling of Duplex Stainless Steel
01/28/2010 5:32 AM
We picklie Duplex stainless steel with Nitric and HF. The solution is supplied to us as 26wt%HNO3 and 7wt%HF solution mixed in water.
We then further dilute the the above liquor 2 to 1 with water.
I am trying to calculate the pH and the chemical reactions but the combination of the acids is confusing me!
Can I do a simple titration on the above? Or is the effect of two acids going to screw it up?
I thought there would be some good info on the web, like an idiots guide. But it seems like a black art!
Re: Pickling of duplex stainless steel
01/28/2010 6:22 AM
It's going to be highly acidic. Why not just use a pH meter instead?
Beware - HF requires special glassware to maintain resistance against corrosion attack.
Re: Pickling of Duplex Stainless Steel
01/28/2010 5:00 PM
Sorry... I meant to say I am trying to work out the acid concentrations using pH. With the two acids in the mix, can this be done easily?
