Previous in Forum: CT Selection for Differential Protection   Next in Forum: No Load Loss Testing
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Alternator
01/28/2010 6:39 AM
How to calculate the Current Carring Capacity of the Diodes used in the rotating rectifier assembly of the alternator?
Re: Alternator
01/28/2010 6:58 AM
Look for a manufacturers name and part number on them and then look up this information.
Re: Alternator
01/28/2010 7:15 AM
actually we are manufacturing the alternator & stucked up with the diode rating.
we do want to keep the safety factor, but do not know what it should be?
Secondly these diodes are rotating witht he RPM @ 1500 / 1800, will this affect the diode rating?
Re: Alternator
01/28/2010 7:21 AM
Rotating a diode at 1800rpm should not affect its rating.
Engineering Fields - Electrical Engineering - New Member India - Member - New Member
Re: Alternator
01/30/2010 12:56 AM
Dear Mr. Vishram,
I am not an expert in this arena, but from my fundamental knowledge of electrical engineering i would wish to say that please check the excitation current required for the desired alternator voltage. even if you consider a higher rating of diode, it doesn't matter. after all diode acts like a switch. the electrical rating and dimensions also depend on the KVA rating of machine and the mechanical dimensions of alternator(may be i am wrong in this case). Also what type of cooling is considered?? since diode has to withstand the high temperatures inside the alternator.
Dear Forum member, Please give your feedback
Register to Reply 4 comments
PWSlack (1); shanbhag (1); user-deleted-1105 (1); vishram lele (1)
