Previous in Forum: Density of Molten Bitumen   Next in Forum: Tank Linearization for Volume Applications
Solenoid Valve
01/29/2010 4:35 AM
R/SIR
I WANT TO INSTALL A SOLENOID VALE FOR PULSUATING AIR OPERATION AT THE DISCHARGE OF CENTRIFUGAL BLOWER
BLOWER READINGS TAKEN WITH ANEOMETER ARE AS FOLLOW
M/S -33, FT/M-670, KNOT-66, KM/HR-119.5
PL SUUGEST THE VALVE WITH LINE SIZE FOR ABOVE APPLICATION
Re: solenoid valve
01/29/2010 5:26 AM
Please turn off Caps Lock, and state the line size coming off the blower.
Good Answers: 101
Re: Solenoid Valve
01/29/2010 8:48 PM
I think you'll need to install a muffler for your blower as well as enclose it in a sound-proofed housing so that you don't need to shout. Between the noise from the blower and your shouting we can't make out what you are asking.
Now what was your question again?
