Previous in Forum: Nitrogen Gas Pressure   Next in Forum: Exothermic Reaction
Maximum Temperature for GRE Painting
01/29/2010 8:52 AM
what is the max. temp. for GRE painting for oil tank internal painting?
and from where should i found its specifications?
regards
Re: max. temp. for GRE painting
01/29/2010 9:39 AM
Can't read minds.
"from where should i found its specifications" Get the specs from the paint supplier.
Re: Maximum Temperature for GRE Painting
01/29/2010 11:40 AM
what's GRE? graduate requirement exam? seriously, please define acronyms
01/29/2010 9:15 PM
GRE is the glass reinforcement epoxy painting
regards
01/30/2010 8:39 AM
Any oil base paint including epoxy should be painted in no less than 50 degree weather.Best would be 70 degree low humidity, I would also caution you about conditions in the tank. SCBA operative certified personnel trained in closed space work, And proper ventilation procedure for removing dangerous atmosphere from the very toxic fumes in the tank.
01/30/2010 8:50 AM
thank you
but when the painting be applied inside the tank how much temperature will it stand?
regards
01/30/2010 9:24 PM
Contact the manufacturer for more required details.
http://www.foxind.com/datasheet.asp?sheet=72
Best Regards, Tim
Register to Reply 6 comments
Anonymous Poster (2); lyn (1); mostafaalkholy (2)
