Previous in Forum: Maximum Temperature for GRE Painting   Next in Forum: Galvanic Protection of Metals
8 comments
Exothermic Reaction
01/29/2010 10:48 AM
Hi, I am trying to find an exothermic chemical reaction that I could get to reach a temperature of 160 degrees F. I would like for it to be with relatively safe chemicals. If not please indicate. Thank you for the help.
jb64713@appstate.edu
Good Answers: 299
Re: Exothermic Reaction
01/29/2010 11:03 AM
Mg + 2H2O → Mg(OH)2 + H2
Don't eat the Mg
Don't expose the H2 to flame
Don't eat the yellow snow (per Frank Zappa)
01/29/2010 12:02 PM
Or how about:
NaOH(aq) + HCl(aq) → NaCl(aq) + H2O(l) ?
Good Answers: 120
01/29/2010 11:00 PM
160 F is reachable with a mixture of concentrated sulfuric acid slowly added to water with stirring and goggles. You can boil the water, so be careful, this can be risky.
Sadly, any exothermic reaction to make 160 can also make 260 and throw boiling acid in your face.
What happens there is the hydration of concentrated sulfuric acid into the hydrated form.
You can also use an acid and a base, which combine to make a salt solution adn water, as in NaOH + HCl into Na+ and Cl- and H2O. In effect you burn hydrogen and get that heat and lose the heat cost of dissociation of the acids.
Anything like this can also be dangerous.
a bit more here
http://en.wikipedia.org/wiki/Exothermic
Per Ardua Ad Astra
01/30/2010 12:15 AM
Mix some lye (Drano) in water. Toss in a piece of aluminum. Do this in a well-ventilated space, not your garage and forget it, like I did...
01/30/2010 1:54 AM
Take a look at the handwarmer packets sold in sporting good stores. They contain iron filings and an oxidizer and can get really hot. Edmund
Good Answers: 94
02/01/2010 8:25 AM
As above, the hand warmer pack I have says it gets to 70°C (158°F).
Popular Science - Weaponology - Cardio-7
02/01/2010 9:58 AM
It would seem that no one understood your "relatively safe chemicals". There are many ways to achieve the temperture you require, but we first need to know: Are you trying to achieve this temperature in air, as in an oven or a room? Or in a solution? What kind of quantity is involved? Could you use a propane or natural gas flame, for example?
02/01/2010 10:04 AM
I would like something the size of a hand warmer. It needs to be self contained much like the hand warmers work. The reactions that give off gasses is not acceptable.
Register to Reply 8 comments
Anonymous Poster (2); aurizon (1); Cardio07 (1); Doorman (1); Nigh (1); PWSlack (1); SSCpal (1)
