Previous in Forum: Exothermic Reaction   Next in Forum: conductivity agent for coating
Galvanic Protection of Metals
01/29/2010 11:51 AM
What is the critical potential difference to initiate galvanic corrosion in sea water?
Re: Galvanic Protection of Metals
01/29/2010 11:58 AM
All non-zero potentials.
01/29/2010 12:00 PM
It depends upon the wetted metals only.
Platinum electrodes, for example, won't corrode in seawater, whetever the potential difference applied to them.
Don't expect the magnesium in the magnesium/steel system to last very long. Magnesium is often used as a sacrificial anode to protect steels (marine outboard engine propeller-shafts, for example) that are immersed in seawater.
01/29/2010 1:22 PM
Galvanic corrosion chart. Search for it on the web.
01/29/2010 1:54 PM
I could see the potential values in the galvanic corrosion chart. It is obvious that, the closer the values, the better the galvanic corrosion protection. The question is:
how big the potential difference is that could be critical or maximum in deciding material combination?
01/29/2010 3:43 PM
Any potential is too much.
Perhaps a look at the electromotive series will help.
Standard electrode potential (data page) - Wikipedia, the free
You will have to decide how much material loss over time you can tolerate.
01/29/2010 5:49 PM
Thank you all for the comments!
Register to Reply 6 comments
Anonymous Poster (1); lllqiqi (2); lyn (2); PWSlack (1)
