I am just proposing a concept. Basically I am an electronic engineer. I understand taht 4 stroke engines are still not efficient and hence teh world is looking for ways to reduce carbon emmission and improve effciency. I have discussed my ideas with a few very knowledgeable friends and find it plasuilble, but require huge funds and hence unable to try it out.
I will try to put down some thoughts here, but am finding it difficult to attach some figures / drawings- which may be I will do as we go along.
I look forward to very constructive comemnts and excuse me if there are major flaws- do point it out. I am aware that some companies are trying out fuel cells, hydrogen fuel, mini nuclear etc etc- but will this work at cheaper cost?
I was trying to understand the 4 stroke engine educational simulator. There is graph of pressure vs volume. I am reproducing the graph (not able to the animated graph). Energy delivered is given by the area enclosed by the curves b,c,d,e. Hence higher the compression and higher the pressure developed, greater will be the area.
PROPOSED 2^N STROKE INTERNAL COMBUSTION ENGINE
- 2x2 = stroke engine should be replaced with 2^N stroke engine.
- In my dream I had felt that we should introduce concept of digital technology in mechanical internal combustion engine. It is now possible.
CONCEPT OF DIGITAL TECHNOLOGY in IC engines - A CONCEPT OF PROGRAMMED PV CURVES
- In thought-1, I had suggested that the burning and exhaust chamber must have bigger volume and fuel intake must have a smaller volume. This is wrong. To ensure that the fuel is compressed before ignition, the burning and exhaust chamber must be smaller than the fuel intake chamber.
- Earlier I had said the IC engine is working in the analog world and electronic engineers understand the concept of digital to analog conversion. So we try to bring in this concept to improve engine efficiency.
- It must be noted that in the digital world every bit has a weight age though it is still 1 and 0.
- Given that in IC engine we can NOW introduce chambers with different weight age which means we have one with lower compression ratio, next with double the compression ratio and third with 4 times the compression ratio.
- At low speed or low throttle, only the smaller compression ratio engine is functional. The fuel intake valve remains closed to higher will remain closed. Though all cylinders and pistons are mounted on the same shaft, they are running idle- without any fuel being fed at slow speed.
NEW MEANING FOR THROTTLE & NEW MPFI RULES
- In the current technology increasing throttle means feeding more fuel into same chamber, same 4 stroke engine.
- This result in poor efficiency, as burning is improper and also the valves operate at higher speeds and exhaust gases leave at higher pressure etc etc.
- Now when we raise throttle, we enable a chamber with next compression ratio to come into operation, and with still higher throttle, still higher compression ratio comes into effect. So with 3 cylinders we can get 8 combinations as in digital technology and in idling only the least compression cylinder is getting fuel. One can have a finer variation with particular combination by gradually changing the fuel / air mixture as at present.
- Advantage of this is approach being – that the engine is efficient over entire range of speeds – unlike just between 40 and 55 kms as at present.
DO AWAY WITH MUFFLER
- Another concept to be added to improve efficiency is NOT to let exhaust gases directly to atmosphere. In the current technology - to avoid noise pollution people add muffler, basically to reduce speed and pressure of out going gasses.
- In the proposed technology we add an efficiently designed turbine (screw expander chamber) through which the exhaust gases pass through to enable extraction of energy into rotary motion. If need be the expander chamber can be heated to further burn gases – if they contain any unburnt fuel.
So even we talk of simple 2x2 = 4 stroke engine, all the cavities are not identical.
The area under the curve is enhanced enormously even for lesser compression to expansion ratio.
I will atach more pictures as we go along.
Basically can we split a 4 storke into 2x2=4 stroke
Can we add a low pressure turbine to extarct energy from exhaust gases?
When we add a few 4 stroke engines in parallel, why should all be of same capacity? Why not have different capacities (as have in digital to analog convertor) so taht higher power cylinders get fuel only at highewr speeds or when there is need for higher power (intelligent electronics will really help here) ?
