Previous in Forum: mobile phone charging characteristic   Next in Forum: DC Voltage Converter
Ferrite core
01/30/2010 3:50 PM
Hi to all
I have a small ferrite core and i want use it as a part of a switcher at 500kHz.
The data sheet shows that it has a flat initial permeability of 1500 from dc up to 200kHz.
Then the initial permeability drops very sharply if the frequency is higher than 200kHz.
Can that ferrite core be used at 500kHz ?
Thanks for help.
Re: Ferrite core
01/30/2010 6:40 PM
Do you have a link to the spec sheet?
Re: Ferrite core
01/30/2010 7:21 PM
Strictly speaking, it can be used at 500kHz. But you should linearly extrapolate from your data sheet to guess how much permeability will still be available at 500kHz. Without a link to your data-sheet, I cannot give you an estimate what will be a good nominal value. (Also I normally get paid when I do this. ) I would not be surprised if your relative permeability guess puts you very close to a value of 1, if not less than 1. This will mean that your ferrite core will actually be nothing more than a ceramic bobbin to hold your wires. The good thing with this is that you will not have to do all of the other calculations to figure out at what magnetic flux density will the core saturate, since you will already be saturating this core. This will also ease your inductor stored power calculation ,for you won't have to consider the higher harmonic roll off effect turning your square wave into a sign wave since the fundamental frequency will be outside of core's designed range. The draw back of doing this is that since you will be actually using the permeability of free space, you will be transmitting your power very well out into free space. So don't expect to get all of it back.
So now that I've shoveled enough to hopefully dissuade you, allow me to sum this up. Yes, you can use this core at 500kHz. But you're not going to like it.
Re: Ferrite core
01/30/2010 7:39 PM
What is the initial permeability?
Is that the value of the permeability at the point where the hysteresis loop cuts the horizontal axis( where B=0) ?
Re: Ferrite core
01/30/2010 9:55 PM
Of what, free space or a vacuum (μ0)? Well that's defined as 4π * 10-7. (π is supposed to be pi.) If you're asking about the particular ferrite core material, like most materials that changes with the frequency of the magnetic field. At the frequency of interest, the manufacturer does not specify what should be the relative permeability. Whatever the permeability at DC or in the frequency band stated by the manufacturer almost doesn't matter. We have no idea how steep the cliff edge is so knowing the height of the cliff will not help identify what the permeability is at any frequency. We do know that the manufacturer does not recommend operation in these frequencies since no data is given for these frequencies.
No, magnetic hysteresis is the effect of some magnetic material to retain a magnetic field after being externally magnetized. Until one reaches a magnetic flux density known as saturation, the permeability remains the same. Technically the permeability changes just before saturation, but since this is nearly a positive feedback scenario once the permeability starts to drop saturation soon follows.
A good site on the magnetic properties of materials.
Re: Ferrite core
02/01/2010 11:08 AM
GA... for an excellent link
Re: Ferrite core
01/31/2010 1:38 AM
At reduced performance.
Register to Reply 6 comments
Anonymous Poster (2); Electroman (1); rcapper (1); redfred (2)
