Previous in Forum: Fuel Consumption Formula   Next in Forum: Fluidizing Pads
38 comments
Hydraulic Cylinder Calculation
01/31/2010 8:21 AM
Hi every visitor ! I am designing one Plate bending machine, it has 125mm Thk. M.S. plate upto 7000mm width bending capacity, this will be three roll bending machine which will bend a pre bended plate ends. Main top roll Diameter is 800mm, and bottom two roll diameter is 700mm, i am going to use hydraulic cylinder to push a top roll for 125mm Thk. Plate bending. as my knowledge i have calculate that top roll need total 4700 Tones (FOS is 1.5) push force for bend a 125mm thk. M.S. Plate. (7000mm Width) and i also calculate that, to get a 4700 tones push force, the 1600 tones force capacity Hydraulic Cylinder will be required. (Two Hydraulic Cylinder on Both ends of the Top Roll for pushing toward bottom roll) and now i am designing the Hydraulic Cylinder, that its internal bore diameter will be 700mm, Piston Rod Diameter will be 400mm, stroke will be 600mm, Now to take a 1600 tones output force , the pressure will be around at 6000 PSI. kindly correct me, by checking the above data, if you want me expand my data, kindly mail me at kkggmistry@yahoo.co.in
Re: Hydraulic Cylinder Calculation
01/31/2010 7:43 PM
First things are your numbers you are confusing--- PSI (pounds/square inch) and metric 700mm cylinders. While it is convertible stay with one or the other.
Second thing how does 4700 ton total equal 1600 (X2), more like 2350 tons on each cylinder.
700 mm bore at 6000 psi comes out to about 1788.48 tons. better than 1600 tons but still not 2350 tons.
deflection on the shaft has not been considered if you allow for this extra tonnage may be required.
Bin there, done that, then done that again and again and now I forgot where I was.Is this what it means to get old?
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
01/31/2010 11:23 PM
Hi Mike L
OOOh! I shall have to watch this one as I agree with your calc's although there may be some mechanical advantage somewhere that we don't know about.
As the OP's name suggests "it's a MISTRY" I think Toya said something similar too!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
02/01/2010 12:09 AM
The total 4700 tones of load is according to FOS = 1.5, while calculating the FOS = 1 this load becomes 3133 Tones, thats why i choose 1600 tones push force capacity Hydraulic Cylinders, The material i want to bend in this bending machine, has following technical specification : Tensile Strength : 320-440 N/mm^2, Yield Strength : 380 N/mm^2 material designation equivalent as ASTM (American) 1040
Good Answers: 183
02/01/2010 5:55 AM
I do not know how you determined the value because it is function of the distance between the two bottom rolls and of the radius you want to achieve (minimal value).
According to my computations the mentioned force occurs for a distance of 1450mm and a radius of the bend plate of 3800 mm in the middle.
With the Cs =1.5 and an efficiency of 0.95 at the ram level the diameter is 617mm for the 6000 psi you mentioned.
Is that coherent with your basic values for the computation?
I dare make a remark with respect to the mechanical values you give for the plate material: the elastic limit is higher than the lower ultimate stress. This is usually not the case. Are you sure of the values?
Good Answers: 97
02/01/2010 11:58 AM
I'd expect closer to 2800 PSI, specifics are untenable without knowledge of: hot/cold process? desired single pass arc capabilities?
More information required...
Good Answers: 183
02/01/2010 3:02 PM
I would be interested to know how you estimate the pressure to be closer to 2800 in stead of 6000.
From what he gave this was not possible without some assumptions and detailed computations. Since your results are so far from mines I am very interested to know why.
Good Answers: 97
02/01/2010 11:08 PM
I can only cite previous experience with pinch rolls.
One 27" actuator pushed by 2800 psi is equivalent to a pry bar about a half mile long.
I seriously doubt the 31" dia roll is sufficient
02/01/2010 11:15 PM
I'd be interested in the kind of pump that will deliver 6000 PSI continuous and at suffient volume to be reasonably fast?
Good Answers: 97
02/01/2010 11:21 PM
Fast isn't required for pinch roll machines...
02/01/2010 11:26 PM
I see your point
Good Answers: 97
02/01/2010 11:52 PM
The OP doesn't need a pump capable of 6000 PSI. The description is of 6000 PSI force, so the actuator would need only hold against this force created as the plate is driven through the pinch roll machine.
It's the motor doing this driving I'd like to see
02/02/2010 12:27 AM
Instead of having to choose between speed and force you can have both.
Scroll down to Hi Lo pump circuit on this page:
http://www.hydraulicspneumatics.com/200/eBooks/Article/True/44617/
chris@ade.net.au
Good Answers: 183
02/02/2010 1:17 PM
I may be wrong but for such a huge plate I think the bending has to be progressive so that they will need the pressure generator to go from one step to the other.
I also have doubts that the 800 and 700 mm rolls are stiff enough and think that a control of upper roll position (parallelism to the other rolls) will be necessary. Without this control the risk to get cones instead of cylinders is on my opinion real. This will impose due to pressure a pump/cylinder and instruments for position measuring. If the rolls are not stiff enough then even with this control there could be problems.
The motor for the rolls will not be -as power- very big if all of them are on roller bearings friction not too being so important power requirements will be low but the transmission will be of a very high reduction.
The flows being any way small there are pumps available up to 7000 psi. But coming back to the dimension and pressures you mentioned I made the following computations based on the model in the sketch. As you will see the forces are higher than it appears at first view.
Material propertiesMachine dimensions
σy=380N/mm²Elasticity limitD=800mmUpper roll
E=2.06E+05N/mm²Young Modulusd=700mmBottom rolls
Plate dimensionsL*=1500mmDistance between
t=125mmThicknessHydraulics rolls (*
estimated)
B=7000mmWidthp=600050002800psi
Conversion factors41.3734.4719.30N/mm²
psi→N/mm²6.89E-03η=0.95
lbs→N4.45
inch→mm25.40
ft→mm304.80
lbs*ft→Nm1.3558
Pressure evolution for Dc=685.80mm=27.00"
A=3.69E+05mm²=572.56in²
R (mm)100020003000400050006000800010000
τ=t*/t=(σy/E)*R/tRelative width of elastic zone
0.01480.02950.04430.05900.07380.08850.11810.1476
M=B*σy*t^2*(3-τ^2)/12
1.04E+10;1.04E+10;1.04E+10;1.04E+10;1.04E+10;1.04E+10;1.03E+10;1.03E+10Nmm
7.66E+09;7.66E+097.66E+097.66E+097.65E+097.64E+097.63E+097.61E+09ftlbs
sinφ=L/(2*R+t+d)
0.53100.31090.21980.17000.13860.11700.08920.0720
φ[°]32.0718.1112.709.797.966.725.114.13
cosφ= (1-sinφ^2)^0.5
0.84740.95040.97550.98540.99040.99310.99600.9974
Frtheor=M/L*(1+0.5*(t+d)/R)
9.78E+06;8.35E+06;7.87E+06;7.63E+067.48E+06;7.38E+06;7.25E+06;7.16E+06N
2.20E+061.88E+061.77E+061.72E+061.68E+061.66E+061.63E+061.61E+06lbs
Cs=1.0
Fr=Cs*Frtheor/η
1.03E+07;8.79E+06;8.29E+068.03E+067.88E+06;7.77E+06 7.63E+06 7.54E+06N
2.32E+06 1.98E+061.86E+061.81E+061.77E+06 1.75E+06 1.72E+06 1.69E+06lbs
p(Cs=1)27.8823.8022.4421.7521.3321.0420.6620.40N/mm²
4043.913452.683254.713154.753093.743052.002996.802959.62psi
Cs=1.5
Fr=Cs*Frtheor/η
1.54E+07 1.32E+071.24E+071.21E+071.18E+07 1.17E+07 1.14E+07 1.13E+07N
3.47E+06 2.97E+062.80E+062.71E+062.66E+06 2.62E+06 2.57E+06 2.54E+06lbs
p(Cs=1.5)41.8235.7133.6632.6331.9931.5630.9930.61N/mm²
6065.875179.014882.064732.124640.614578.004495.204439.43psi
Computations were made with a cylinder diameter of 27" as suggested. Results show the
resulting pressures are even at Cs=1 above estimated level.
I estimated the still elastic zone which is the reason for the springback but it is very thin and will not have a big influence.
Good Answers: 97
02/02/2010 2:00 PM
Nice...
The OP's description details two (2) 27" cylinders per/side or two cylinders at each end of the top roll.
I'm assuming because of lack of input this machine is comprised of three or four rolls. If three rolls the orientation will differ from your graphic in that two rolls will clamp the sheet with the top roll moving at about 35° - 38° angle towards a driven static and pinch roll.
Yes I was meaning the trans/motor relationship is interesting always.
Good Answers: 183
02/02/2010 3:37 PM
Is it this way you think?
The right system I saw for small dimensions and the left for bigger up to 4 m wide (conversion factors in previous text). The right has a disadvantage when forces are high since the friction between the "pinch" rolls has to overcome the horizontal component of F1 and this is no light stuff for a plate as mentioned. This could be the reason for a big motor and heavy transmission. The left version needs to offer ONLY the torque able to overcome the friction of all rolls in their bearings. I presume tis is the reason why I saw it for heavier parts to bend.
As usual I may be wrong since I detain not yet the truth, may some time in the future but not now.
Expect comment.
Good Answers: 97
02/02/2010 4:44 PM
Some of the large projects I've involvement in were all of the right side configuration, by large I mean 3" thickness x 31' A36 plate. In a three roll configuration F2 would be absent but in a four roll F1, F2 and the lower F would be actuated; this one the pinch roll is necessary.
Actually the rendition on the left we used for lite stuff bars, angles and strips etc..
Location: Buenos Aires - Argentina - Mechanical Engineer
06/16/2012 12:28 AM
Hi. My name is Sebastián and I´m working on the design a machine simmilar.
Reviewing the calculations shown here I think that an error exists in this expression:
Frtheor=(M/L)*(1+0.5*(t+d)/R)
I think it should be:
Frtheor=2*M/L*(1+0.5*(t+d)/R)
Becose "e" is (L/2)/(1+0.5*(t+d)/R).
Sorry to reopen an old issue, but did not want to miss this as it can create confusion.
Let me know if I'm wrong. Thank you very much, very good forum.
Greetings!
"Persistence prevails, like a stream that is temporarily blocked by boulders and then collects force enough to overflow onward."
10/16/2012 5:38 AM
May i know how to get the Dc = 685.8mm?
Thanks a lot!
Good Answers: 183
10/16/2012 10:56 AM
As you noticed my work was not considerd as "good answer" so please ask for explanations at other sources
02/03/2010 2:23 AM
I am confuse, many confusion, now my confusion about top roll diameter also, Re-calculating everything from the beginning.
Good Answers: 97
02/03/2010 3:56 AM
How many rolls total, how many rolls driven and dia of each roll, please?
02/03/2010 6:05 AM
Bottom Two roll have positive gear box drive, Approximately 3 m/min
02/03/2010 6:44 AM
This is technical data sheet from " J. IRIZAR COMPANY LTD." CANADA, i have downloaded from the net, this can also help.
Good Answers: 183
02/03/2010 2:12 PM
Is it the one you mean?
It looks very similar to the concept I assumed. It seems that both principles are used. On my opinion this concept requires less power for the rolls rotation.
Could you please mail your sketch with dimensions since as you have seen without dimensions it is quite difficult to check if your computations are or are not right.
Good Answers: 97
02/03/2010 2:45 PM
Do you think we're enabling him to misappropriate this design?
Good Answers: 183
02/03/2010 2:53 PM
I expect to see what he did and what he want s to do. In fact if he makes all computations by himself it is not stolen good as other do copying with the yard stick in the hand. I saw such copying work done by very serious people.
All the machines are limited to 3m width and max 85 or 100 mm thick, he tries to make one for 7m and 125 thick but he is not aware of the scale up generated problems. I made a short check and his concept is far from the values he should respect for good results.
Wait and see we can stop when we consider that he goes too far.
02/08/2010 12:06 AM
the scale of work that is proposed is quite large. Mistakes in the application are not uncommen. Sizing "up" does not mean x2 or x3 on all details.
02/03/2010 7:26 AM
Images were loading before, but now its unavailable, i don't know why?
02/03/2010 8:17 AM
Dimension Top Roll : Ø 800mm Bottom Roll : Ø 700mm Width : 7000mm Bottom Roll Supporting rolls :Ø 300mm Bottom Roll Center : 900mm (Adjustable 1000mm Max. To 700mm Min.) Rolling Speed : 2.5 to 3.5 m/min
02/04/2010 12:03 AM
02/04/2010 1:12 AM
how can someone manufacture any types of machine just to see its picture?? its tuff to copy a machine design, because there is no dimension, no details in the picture, i am not copying from that J. Irizar Bending machine picture, but i can say, my concept is also same as that machine which is in the picture, In that Irizar, bottom two rolls having one stand (Housing), but i am designing two different Stand(Housing) for each bottom rolls, this stands are movable with help of Hydraulic Cylinder.
02/08/2010 12:57 AM
I would like to share my this project to all of you, whatever visitors saying, i really don't mind that, this is i am posting, a foundation frame and Side wall base frame (non drive side). if someone need, CAD Drawing with dimension, feel free to ask.
05/31/2010 3:00 AM
DEAR KAUSHAL,
WE HAVE ONE SMALL FABRICATION UNIT, WE DONT EFFORD COSTLY READY MACHINE FROM ANY SUPPLIER, SO WE WANT TO DEVELOPE MACHINE AT OUR FACTORY ONLY.PLATE WIDTH IS 2000 MM, PLATE THICKNESS 16 MM,MATERIAL IS MS, PREPUNCHING REQUIRED.IF YOU HAVE DESIGN AND SKETCH AND WILLING TO SHARE YOUR KNOWLEDGE ,PLS SEND ON MY MAIL ID dsp1010@hotmail.com (3 roll plate bending machine, shell making machine)
01/05/2011 6:21 AM
kindly send the picture & cad drawing of drive side also
11/09/2017 9:34 AM
I would appreciate CAD drawings in AutoCAD .dwg Format.
Thanks on advance
06/16/2012 12:35 AM
Greetings!
Good Answers: 183
06/17/2012 9:19 AM
Hi Sebastian, you rae right there is an error unfortunately I cannot explain whare it comes from!
Thank you for looking in such a detailed way to the threads when you think that it took 2 years to have somebody to notice it, it says a lot about the interest of participants!
Congratulations.
Now you are partially right:
M= F1*e → F1= M/e with e= R*sinφ and sin φ= 0.5*(L/R)/a with a= 1+0.5*(t+d)/R
F1= M/(R*0.5*(L/R)/a) = 2*a*M/L
F= 2*F1*cos φ =4*M/L*(a^2-0.25*(L/R)^2)^0.5
The other component F2= F1*sinφ leads to a central section compression and thus modifies slightly the stress distribution and moment value.
If you have any other question related to your project do not hesitate to ask I shall be dekighted to answer as far as I can. Better you use the "private channel".
06/18/2012 1:24 AM
Hi nickname. Thank you very much for check this so quickly. Your work has been useful for me to check mine. In my case I have made the hypothesis of elastic-perfectly plastic material and considered resistant plastic module:
Wp = (B * t ^ 2) / 4
The internal moment is in my case:
M = σy * (B * t ^ 2) / 4
The difference is negligible.
An important difference happen with the force, so I began to investigate arriving at:
F1=(M/L)*(2+(t+d)/R)
Thanks again for your predisposition. Keep in touch.
Regards
Register to Reply 38 comments
Anonymous Poster (2); Beej50 (1); bolicat (1); bwire (8); ChrisEng (1); Kaushal Mistry (9); LSHKB1954 (1); MIKE L. (4); nick name (8); Sebastian1981 (3)
