Previous in Forum: Hydraulic Cylinder Calculation   Next in Forum: Hydraulic Press Design and Tonnage
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
Fluidizing Pads
02/01/2010 1:28 AM
hi all i wouldlike to know out of the 2 types which is the best type of fluidizing pad and whyis it to be used in ash silo for fly ash. 1. Fabric type & 2. Ceramic type. as per our requirements the type is ceramic but the vendor provided fabric type since that type has already been in use. anyhelp will be appreciated.
Varun Passi
Pathfinder Tags: Ash Handling Fluidizing Pads
Re: Fluidizing Pads
02/01/2010 8:00 AM
Generally, the fabric type is being used? i have not come across a Ceramic type..what type are you refering to, if you give more details, it might help be clearer
Re: Fluidizing Pads
02/02/2010 11:00 AM
There are many types of fluidizing "pads" on the market, depending on where you are. The two types I am most familiar with are 1) mesh screen rectangular pads and 2) bell-type cover pads. The choice has much to do with the nature of the material to be fluidized. If the material is light, fluffy, or easily fluidized, then the mesh screen type works best because it introduces a continuous flow of slightly compressed air into the bed of material to aerate it and allow it to flow more easily. If the material tends to pack, build up, or become difficult to move, then the bell-cover type (I've only seen steel construction, not ceramic construction) works best because as the air escapes it causes the cover to bang against the hopper wall, acting like a vibrator, to dislodge caked material.
Hot, or warm, fly ash flows very well and fluidizes easily so the mesh screen type pad works well. However, cool fly ash tends to become difficult to move so a rapper-type fluidizing pad, or "air cannon", helps to break up packed material.
Please send better description, or pictures, of the types you are referring to for better answers.
If you can't do it right the first time ... do it wrong, then let the professionals fix it.
Re: Fluidizing Pads
02/18/2010 6:43 AM
the prob is that i'm not sure what excatly is a ceramic type fluidizing pads. in a project specification it asks for one but the vendor is giving a fabric type which i feel is better. anyways thxs a lot for all the help. still any further info will be appreciated.
Varun Passi
Register to Reply 3 comments
Anonymous Poster (1); varunpassi (1); YesMAM (1)
