Previous in Forum: Connecting 110VAC to 220VAC   Next in Forum: Simulation of Grid-Tied PV System
MCCB Rating Calculation
02/03/2010 1:14 AM
please help me calculating MCCB rating for a power factor of 0.9 Load is 70 KW and voltage is 230/400 V +_ 10% and its a three phase supply
Pathfinder Tags: MCCB rating calculation
Re: MCCB RATING CALCULATION
02/03/2010 3:02 AM
→ British Standard 7671.
02/03/2010 3:12 AM
please can you elaborate the calculations?
02/03/2010 1:55 PM
What are you having problems with exactly, the information is clearly indicated in the electrical standards and local electrical regulations you should be working to?
Are you not an electrical (technician/electrician/engineer/consultant)? If not you shouldn't be performing this work, ESPECIALLY since you are talking about an industrial application and likely high fault current rating (70kW is not small).
Anyway, the information is also available for free off the internet
http://en.wikipedia.org/wiki/Circuit_breaker
Also try MCCB manufacturer websites for application notes and data sheets (its all there if you look).
Register to Reply 3 comments
jack of all trades (1); PWSlack (1); therock9211 (1)
