Previous in Forum: edta of boiler   Next in Forum: Material Code: ST35.8i
bell support
02/06/2010 12:38 PM
want to hang a 13Tons brass bell at the center of a 4.5mtrs span supported by RCC columns at ends. Which is stronger - a solid rod of 8" dia or a hollow pipe of same OD - what shud then be its wall thk.
jai
Re: bell support
02/06/2010 12:45 PM
Hollow pipe/bar is stiffer and failure is sudden, while a solid bar failure is slower and more noticeable
download this, its free and relatively simple to use. I used to use it all the time for a quick analysis.
p911
Re: bell support
02/06/2010 12:49 PM
You're making me very nervous with this question.
You intend to base your choice on how to suspend 13 tons of brass on the speculation of strangers. This is not something to play around with.
Re: bell support
02/06/2010 2:41 PM
GA
I have yet to see anyone attempt to give the op an answer.
You might be interested in: Columns, GC Columns, HPLC Columns
