Previous in Forum: HEat Stress Monitor   Next in Forum: PLCs
Level Transmitter
02/08/2010 12:41 PM
I need level transmitter that will work on ruthenium chemical reaction because at the moment we use FMR245 from Endress and Hauser so we have level glading that every two weeks we need to replace it due to the black staff that affect readings on levels. The level glading cost R2500 any help will be appreciated.
Re: Level Transmitter
02/09/2010 7:09 AM
The E+H FMR245 is a radar instrument that does not need to be wetted in any way. Is the high-high-level protection arrangement in the vessel working correctly?
02/09/2010 10:36 PM
I don't know what level "glading" is. Can you use another word to help us understand what "glading" is?
You'll have to help us because most of us will not know anything about ruthenium.
What form is the ruthenium in? Liquid? vapor? solid? pellet? dust?
What are the process temperature and pressure conditions where the measurement is made?
Where does the black stuff occur?
On the radar antenna?
What style antenna is it?
What material is the antenna made of?
Can the black stuff be removed? If it is removed does the radar unit work?
Is the ruthenium causing the black stuff due to its chemical reactions?
What is the tank made from?
Does that material chemically react with ruthenium?
