Previous in Forum: Level Transmitter   Next in Forum: Pressure Gauge of General Instruments Consortium Installation Procedure
PLCs
02/09/2010 6:11 AM
i m a starter in plcs ladder logic programming. i just wanted to clear the doubt that is it possible to on off an output without using two seperate contact input one to on and the other to off it. if its possible please help me how to do it.
Re: PLCs
02/09/2010 6:42 AM
It is optional. One way of doing it is with 1 rung:
1) examine on "start", or examine on "latch", endor, and examine on "stop", output "latch"
The other way is with 2 rungs:
1) examine on "start", set "latch"
2) examine off "stop", reset "latch"
Preference dictates the way to go. The preference here is to use the first option.
Re: PLCs
02/09/2010 6:52 AM
Can you explain a bit more carefully what you want to do?
Do you want to toggle an output alternately ON and OFF with successive pulses on one input? If not, then what?
As you've described it, one input could easily make an output turn on and off:
Input contacts made - output ON (not latched).
Re: PLCs
02/09/2010 2:00 PM
It is possible to do it with one input (input directly fed to output, input on = output on) or even no inputs (if using one of the PLC timer functions and automatic program start).
This is really basic stuff, even for a beginner. Have a look at the link below and on the internet for a basic overview of PLC functionality. http://en.wikipedia.org/wiki/Programmable_logic_controller
There are plenty of basic guides to help you (try a google search of "plc ladder logic tutorial").
Re: PLCs
02/09/2010 3:44 PM
The first three responses are all very good information. Here is one more link that may also help:
http://www.thelearningpit.com/
PLC tutorials, a glossary, a little bit of electronics... pretty good basic stuff.
Doorman (1); jack of all trades (1); JohnDG (1); PWSlack (1)
