Previous in Forum: Linear Movement of Heavy Pedestals   Next in Forum: Filter Rating for Cleanliness Level of NAS 3
12 comments
Erosion of Pump Casing and Impeller
02/09/2010 12:06 AM
Dear All,
i have facing problem of damage of impleller and casing of PFA lined pump.calcium chloride solution having concentration 20 to 50% contains acidity as 1%. during circulation of above solution at 120 to 130 degc pumps were damqaging.
how i can prevent the above damages?
Re: eresion of pump casing and impeller
02/09/2010 1:25 AM
Not sure about your acidity, but if you have excessive cavitation in your pump it will cause damage that may look similar to acidic pitting. The cavitation causes small voids of vacuum which collapse and damage the trailing side of the impeller. Check your pump for periods of low or no flow with the pump running, this would be a source of cavitation.
Drew
02/10/2010 12:29 PM
Thanks for prompt reply, we have provided required NPSH as mentioned by supplier but we have observed reduction in impleller diameter due to forien particale attack
Good Answers: 27
02/09/2010 2:03 AM
PFAPacific Film Archive
PFAProfessional Footballers Association
PFAParaformaldehyde
PFAPredictive Failure Analysis
PFAProtection From Abuse
PFAPerfluoroalkoxy
PFAPulverised Fuel Ash
(cement additive)
PFAParent-Faculty Association
PFAPopular Flying Association
PFAPeople for Animals
(animal protection)
PFAPlatelet Function Analyzer
(aka Platelet Function Assay)
PFAPrevention of Food Adulteration Act
(India)
PFAPublic Finance Authority
PFAPolyurethane Foam Association
PFAPolicía Federal Argentina
PFAPrinter Font ASCII
PFAPacket Flow Acceleration
(Peribit)
PFAPsychological First Aid
PFAProbability of False Alarm
PFAPublic Financing Authority
PFAPublic Facilities Authority
PFAPriority Funding Area
PFAPlease Find Attached
(email attachments)
PFAPlatelet Function Assay
(aka Platelet Function Analyzer)
PFAPublic Fishing Area
PFAParameter Field Address
PFAPrime Factor Algorithm
PFAProduction Flow Analysis
(computer integrated manufacturing)
PFAPhysical Failure Analysis
PFAPierre Fauchard Academy
(dental organization)
PFAPennsylvania Forestry Association
PFAPhiladelphia Funk Authority
(Lehigh Valley, PA band)
PFAPress Foundation of Asia
PFAPersonal Fitness Assessment
PFAProfunda Femoris Artery
PFAPolish Falcons of America
PFAProcess Flow Analysis
PFAPost Flight Analysis
PFAPolar Format Algorithm
PFAProfessional Financial Advisor
PFAPedestrian Friendly Alameda
(Alameda, CA)
PFAPlanet's Funniest Animals
(TV show)
PFAPerson from Abroad
PFAPaid For Action
(advertising)
PFAPistillate Flower Abscission
(walnut genotypes)
PFAPhysical Fitness Assesment
PFAPalm Fatty Acid
PFAPersonal Financial Analyst
PFAPoint of Force Application
PFAParticipating Field Activity
PFAPhase Failure Relay
PFAProvider Financial Assurance Audit
(UK)
PFAPrivate Facility Access
(Hekimian)
PFAPet Flat Animals
PFAPlanned Future Action
PFAPlain Film Abdomen
PFAPlanned Facility Account
PFAPer-Flow Accounting
PFAPremium Fund Account
(insurance)
PFAPoly Film Adhesive
PFAPulled from Air
PFAPublic First Aid
PFAPlease Find Attachment
(email abbreviation)
PFAPrimary Feed Antenna
PFAPedorthic Footwear Assosciation
I have no special talent. I am only passionately curious. Albert E
02/09/2010 9:52 PM
Not sure why this was marked off topic Kaisan, I would also like to know wtf FTA lined means.
Apart from that the question is unanswerable without knowing ALL the pumping conditions. Some of the conjecture will undoubtably prove correct, but with this information it is just that - conjecture.
02/09/2010 2:34 AM
At this temperature, the liquid may be nearly as hot as its boiling point. This would be another possible source of cavitation (low NPSHa). Or running too far to the right on the pump curve.
02/09/2010 4:50 AM
It sounds as though the liquid temperature is around its boiling point. Reducing the temperature may help.
02/09/2010 9:16 AM
But wouldn't boiling reduce vacuum cavitation because the voids would be filled with vapor and not collapse with the same force? I am not as experienced with pumping fluids other than fuel...and we like to keep that as cool as possible!
Drew
02/09/2010 9:35 AM
If the liquid is close to boiling temperature, stuffing it into the inlet connection of a centrifugal pump runs the risk of the impeller creating small pockets of vapour as low-pressure areas are created by its movement within the pump casing. When these pockets of vapour reach a high pressure area, the higher pressure makes them collapse. The effect is to make the pump very noisy, and the collapsing pockets can cause mechanical damage, including impeller and casing scour. "Cavitation" is the label that describes this phenomenon.
Lowering the temperature of the fluid, so that it works well away from its boiling point, will certainly help avoid cavitation, as will due consideration to pipeline design upstream of the pump.
It is for this reason that a steam condensate return pump, as found in process industries that are large users of steam as a heat transfer fluid, is a specially-designed beast. By requirement, it has to push condensate around close to, or at, its boiling temperature. Less-conservatively designed pumps will not last long in condensate service for this very reason.
Re: Erosion of Pump Casing and Impeller
02/09/2010 4:59 PM
Ca/CL.2 (calcium chloride) solution at 20% concentration boils at around 105 dgC. At 50% boiling point is around 130 C. This is a very tricky condition. What is your suction head??? your intake flow velocity??? At this vapor pressure there would be cavitation. Combined with a fairly corrosive solution and unsuitable wetted parts pump material, this could indeed be very damaging to the pump. I would suggest that you talk to the tech dept of Dow Chemicals and to some better known Chemical and Process pump manufacturers.
Good Answers: 109
02/09/2010 11:10 PM
GA Alexander. OP did not give suction head See the link below for explanation of vapour pressure and suction head and cavatation OP.
http://www.pipeflow.co.uk/public/articles/Net_Positive_Suction_Head_Or_NPSH.pdf
02/10/2010 1:09 AM
Quite likely you are cavitating and the high temperature mixed with acidity is not helping either. how viscous is the solution and what flow rate and pressure is at the outlet and does that conform with the pump's designed performance on the Data Plate, are there any pipe bends near the pump inlet. Is there a restriction or half closed valve in the suction line feeding the pump You may have to look at a different type a pump, possibly a rubber lined slurry pump or diaphram pump as they use in the mining industry. Contact your local pump supplier for available pump alternatives.
02/10/2010 4:34 PM
Send that question to the Belzona Corp. I had similar problems with a pump that went from acid to alkali (Ph 2-10.7) @ 180deg F and their pump kote product did it for me.
Register to Reply 12 comments
Alexander M. Berlin (1); Anonymous Poster (2); Basco (1); Drew K (2); Kaisan (1); kevinm (1); PWSlack (2); r_jain31 (1); Tornado (1)
You might be interested in: Wellhead Equipment, pH Transmitters, Centrifugal Pumps
