Previous in Forum: AMF Electronic Circuit Diagram   Next in Forum: Noise Reduction for Portable Generator
Simulating Light Energy Savings
02/09/2010 9:43 AM
Hello,
I want to do light energy saving simulation (based on daylight availability) where each luminaire consists fluorescent tubes (T5,T6 or T8) with a dimmable electronic ballast, which can dim the lamp output smoothly and uniformly.
I have to know luminary coefficient of utilization (which most of manufacturers do not provide in their luminary datasheets!).
Is this coefficient always unique or its value depends on dimmable level of luminary?
Re: coefficient of Utilization
02/09/2010 1:29 PM
It is the ratio of luminous flux on the surface considered to the total luminous flux given by the device.
So, the answer to your question would be "yes".
I had never heard this term before but, like magic, I did a Google search and, voilla! I had the answer in under 2 seconds. (don't you wish YOU could do that!)
Re: Simulating Light Energy Savings
02/09/2010 2:34 PM
Yes, that's right!
I read theah 100 times, but I did't notice "total flux"!
Thanks Mikerho!
02/10/2010 1:17 PM
I recommend not using a dimmable ballast (didn't even know they exist or work). Instead turn off and on tubes; i.e. most lights have 4 tubes, so when the sun light is high enough turn off a number of tubes entirely. This way you have the tubes running at their highest efficiency and will avoid having a lot of flicker which usually happens when the tubes are not run at full current. This is also easier to do because transistors/relays are cheaper then dimmers.
'Why' is not a valid question, and is more useful if restated as 'how'
02/11/2010 9:50 AM
It is often frist glance and can save more energy than dimmable electronics (maybe), but frequently switch lighting on and of can significantly reduce lamp life. Therefore exist a variant of the on-off control know as "differential switching".
Register to Reply 4 comments
Mikerho (1); NeshKo (2); sunnycanuck@gmail.com (1)
You might be interested in: Light Emitting Diodes (LED), Light Guides, Ballasts
