Previous in Forum: Lifting Hooks   Next in Forum: Air to Burn Bagasse
Pump Auditing
02/09/2010 3:02 PM
Which is the easiest method to know that at which efficiency point (Other that BEP or at BEP) the CF pump is running? i.e. how to calculate the efficiency of a running CF pump?
Thanks
Re: Pump Auditing
02/09/2010 6:09 PM
Look at the pump curve. Look at your amp draw. Look at the pump curve.
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
Re: Pump Auditing
02/13/2010 6:21 AM
May I have your permission to use this line while teaching class???? Great!!!
"Memorize the calculations, you look like a fool searching your notes while teaching class"
Re: Pump Auditing
02/13/2010 7:55 AM
I could not get you Mr. jcchiefeng !!!
Thanks
Register to Reply 3 comments
dhanesh.koshti (1); jcchiefeng (1); lyn (1)
