Previous in Forum: IS2062 Gr B Plate Flanges   Next in Forum: Flat Head MAWP
Importance of Oil Viscosity
02/12/2010 2:54 AM
NOW I CANT UNDERSTAN THE RELEVANCE OF VISCOSITY FOR GEAR OILS USED IN GEAR BOXES
AS I UNDERSTAND IT VISCOSITY VARIES ACCORDING TO TEMPERATURE AS TEMPERATURE DECREASES VISCOSITY INCREASES AND VISA VERSA
HERE IS MY PROBLEM
WE HAVE A SMALL GEAR BOX OPERATING IN OUTSIDE CONDITIONS SO I WAS WORRIED ABOUT THE CHANGE OF TEMPERATURE THE OIL IN THE GEAR BOX WOULD BE SUBJECTED TO SO CONTACTED THE GEARBOX MANUFACTURERE WHO REPLIED THAT THE OIL WILL BE OK FROM -10c to +40c (o�l or�g�nal v�scos�ty 220cst
from my calcs this temperature variation gives a viscosity change of 220cst to up to 10000cst can somebody therefore explain the importance of viscosity
Re: IMPORTANCE OF OIL VISCOSITY
02/12/2010 4:03 AM
first of all there is an operating temprature range for an oil where there is no or little change in viscosity..........
as viscosity decreases with increase in temprature the shear strength of oil reduces thats its importance in gear oil
nothing is impossible !
02/12/2010 5:54 AM
Sorry abc - there will be change in viscosity of oil within the operating range too.
Though the amount of change (x45) for 500C is a bit exaggeration (me think)
Usually as I remember, within operating range, every 200C temperature rise the viscosity halves. So the 500C drop (with the 220Cst at 40oC) will cause only x5 to x6 viscosity ie around 1100 Cst and not the another zero.
The extra viscosity will have problem in oil circulation through the system and I am not sure about the design and lubrication system, but those who know have replied- the OEM)
What is your actual temperature of ambient range?
Also when the gearbox runs, in case of thicker oil, the losses make it quickly heat up and it warms up considerably, and it really doesn't matter if the gearbox is continuously running. However in lower duty gearboxes, the thick oil as mentioned above may create some problem in lubrication.
We normally put a small heater in the sump (along with heat tracers in case the line is long) to bring up the temperature to a comfortable zone before either the lubrication system (if it is external) or the gearbox is energised.
BTW: Please turn the caps lock off.
