Previous in Forum: Standards for 11-KV Cable Trench   Next in Forum: Controlled Automation via Linear Actuator Help
Power Plant Alternators
02/14/2010 8:29 PM
why in power plant alternators rated at KV are used
Also posted in: also posted in Instrumentation
Re: alternators @ power plant
02/15/2010 7:13 AM
As opposed to what?
02/17/2010 3:20 AM
May be the OP wants to generate power im Volts or Milivolts ?
NOTE: it is KV and not KVA what OP is asking about.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Re: Power Plant Alternators
02/17/2010 1:17 AM
It's Simple Rule -
KVA = Sq Root 3 x Voltage x Current
If you Increase the voltage for the Same KVA output of the Alternator the Current will Decrease.
Power Plant alternators are suppose to deliver the Power through the long Disctibution Lines, High Voltage / Low Current Means Low Transmission / Distribution Line Losses.
Register to Reply 3 comments
Anonymous Poster (1); PWSlack (1); vishram lele (1)
