I am in the designing stage on a new tool. This tool utilizes 6 small
AC electric motors. These motors will have a gear attached, (32 teeth,
max. 1" Dia.)
Two of these motors will move a plate
(approx. weight >10 lbs.) along a RACK for 6 Ft. The motors will be
located on opposite sides of the plate. The force that will be exerted
against the plate as it moves forward will be 15 lbs @ dead center.
Max. motor size - 1" Dia. X 3" Long.
The other four motors have the same conditions except they do not have the 15 lb. force exerted against it.
