Previous in Forum: Interfacing Third-Party Devices with ASCII   Next in Forum: Converting Manual Rotating Knob to Remote Operation
11 comments
Push-Pull Amplifier
02/16/2010 12:36 PM
Hi everyone,can someone please explain to me the purpose of placing the 2 1k resistor and 170 ohm resistor in the circuit ??
http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/103771-push-pull-amplifier.html#post846306
Are they use to to decrease the crossover distortion??how they function to decrease the distortion if im correct?thanks for replying.
Re: push pull amplifier
02/16/2010 1:35 PM
This does look like a homework problem so I will not complete the analysis. But I will do some of the heavy lifting and add a hidden problem with this circuit myself.
I've added the drawing found at the link.
These resistors bias the two transistors so that these transistors operate in either AB class where both transistors are ON for part of the time or in B class where only one amplifier is ON at a time. (As you may guess an A class amplifier is when all transistors remain biased ON.) As a critical exercise to understand what is happening, calculate the voltage drop across the 170 ohm resistor if neither transistor were there. Compare that to the voltage level of two forward bias PN junctions of the two base to emitter connections. If the initial no transistor voltage drop across the 170 ohm resistor is less than the forward bias of the junctions then neither transistor is considered ON when an AC input signal is absent. If the voltage calculates to higher than the two junction voltage value then both transistors will be ON and the AC input signal will turn one transistor more ON and eventually the other transistor fully OFF.
Now if one uses just the simple fixed voltage value for the junction voltage, one will miss a critical error that will happen with this amplifier topology. Find the formula for the current to voltage relationship for a diode (the base to emitter) to find the root of the problem. If you, chopper, do this and ask the right question I'll tell you the simple solution so that you can design a useful AB amplifier.
Australia - Member - Igor...pull the switch!!!
Good Answers: 12
02/16/2010 4:27 PM
your an evil genius
CraziestOzzy
02/16/2010 4:36 PM
Aw gee. 'twernt nutin
02/16/2010 9:13 PM
are u saying that i should use 2 diodes to replace the 170 ohm resistor to provide the voltage of 1.4V to reduce the crossover coupling?
02/17/2010 10:23 AM
I'm not saying that you should do anything. You asked what the resistive network was doing. I told you the basic method to calculate what it is doing. You did not tell us what you wanted this to do, so I cannot say if this circuit is capable of doing what you're asking this current amplifier to do. Depending on how this circuit will be used in the total system, the configuration can work fine as it is. Even the problem that I alluded to may not be noticed with how this circuit gets used.
Now, you've noticed that this circuit is operating as a class B amplifier. I presume that you wish to stop the crossover effect that happens with all class B amplifiers. Replacing the 170 ohm resistor with two diodes may bring this circuit into AB operation but it certainly won't be very far into the class A region. But I do think you will want at least one diode, very strategically placed eventually in this circuit.
Did you ever look up the current to voltage equation for a diode that I mentioned? I like the one found at www.allaboutcircuits.com. The only significant error on that page is that they don't clearly define Is as the reverse saturation current. It's a very good site that can help with all of your designs.
Re: Push-Pull Amplifier
02/16/2010 9:21 PM
by the way, i replaced the q1 and q2 with darlington transistors. any special attention need to give to the transistors?
02/17/2010 10:44 AM
As far as using a Darlington transistor configuration, you'll find that you will have a higher current gain so you will have to redesign the biasing network and can then get a higher input impedance. You will also now have two diode drops per transistor to bias the transistors.
I didn't mention this earlier, but you don't need the two capacitors for an input. One going to either node will work just fine. Speaking of the input impedance, this capacitor and the input impedance make an RC high pass filter that limits the lowest frequency your amplifier can drive.
Good Answers: 54
02/17/2010 1:48 AM
Redfred is right, but I think your question means you're missing something more basic.
The resistors are used to "bias" the base of the transistor.
When the transistor Base voltage is at (or below) 0.6V it doesn't conduct between the Collector and Emitter. When the voltage goes a small bit above 0.6V current flows between Collector and Emitter. This is best seen on a graph of Base voltage versus Collector current.
So the resistor network biases the Base near this critical voltage, and the small voltage superimposed by the input signal (via the capacitor) is enough to start current flowing.
This can get very very complex, but the basic(sic) idea of biasing and adding an AC component is a good place to start (a text book will help a lot).
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
02/19/2010 2:48 PM
It is a Single supply Complimetary-Symetry PP Amp
Functions are shown on attached picture.
Note that upper Tr is PNP & the lower NPN.
Output is from Emmiters thru Cap
For detail read
CompliSymetri-push-pull-amplifier
02/19/2010 3:22 PM
No the upper transistor is an NPN and lower is PNP. The question is would one expect this to be in class A, B, AB, C, or D operation?
02/19/2010 3:35 PM
Yes Sorry for writing NPN & PNP incorrectly.
Class of amplifier will depend on biasing of transistors, Cross-over ponit selection & Pre-Amplifier class. Here it is single ended as requirements of the output stage is.
In that case a more sophisticated [in place of 3 series resistors 1K, 170R & 1K] BiasNW is needed.
Normally Class AB for Audio. NEC was the 1st to introduce it.
Thanks for correction.
Register to Reply 11 comments
chopper (2); CraziestOzzy (1); ffej (1); Haajee (2); redfred (5)
