Previous in Forum: Push-Pull Amplifier   Next in Forum: Sonar High Frequency Piezoelectric Device
12 comments
Converting Manual Rotating Knob to Remote Operation
02/17/2010 3:21 AM
how can i convert my old Technics sterio amplifier volume switch from manual to remote controled
Re: Convert manual volume rotating knob to remote operation
02/17/2010 4:00 AM
Not exactly what you were asking, but you'll find some related information/ideas here.
02/17/2010 4:27 AM
I was thinking 'String'
Good Answers: 918
02/17/2010 7:33 AM
Isn't that what kids are for?
02/17/2010 7:44 AM
Nah, they only ever turn it up....
02/17/2010 5:24 PM
Brilliant! OK, you'll need to turn the device so that the knob is pointing straight up and then make a couple of wraps of the middle of your length of string around the knob. You'll need string long enough so that you can then sit down in your favorite chair and still have both ends of string, one in each hand. Then, as you pull one or the other ends of the string, the volume will go up or down accordingly.
Re: Converting Manual Rotating Knob to Remote Operation
02/17/2010 7:17 PM
Please ignore #2 - #5, they're a bunch of f***ing idiots they're well-meaning simpletons they jus' joshin'. If you're serious about this - and you know a bit about electronics - and you have the manual skills required (or loadsa money) - and you can take a bit of ribbing from the kind of loonies that inhabit this space - then tell us a bit more about your aspirations.
02/17/2010 7:35 PM
OH Yeah!f***ing idiots
You're just jealous because the cat and I have a symbiotic relationship that allows us to come up with these strokes of genius.
Rotating Knob
02/17/2010 7:57 PM
Sit on it .
Re: Rotating Knob
02/17/2010 8:04 PM
"Sit on it".
I suppose you mean, "Sit on it, and rotate" which would accomplish the volume control function, but does not fulfill the "remote" requirement.
It would also tend to personalize the volume control knob, after the first sitting upon.
Ok, I'm done.
02/18/2010 3:44 AM
Nyah nyah nyah nah nah...jus count my GAs and weep...
(If you pick on me, I'll tell ER and set the Squirrel on you)
02/18/2010 3:41 AM
But seriously, I wouldn't try to convert a decent old amp to remote unless it has the circuitry waiting to be used (but not implemented) inside.
I would imagine modern amps with a remote are digitally controlled whereas an good old fashioned amp will be entirely analogue, (and vastly superior because of it)
I had written to this effect but didn't post it 'cos the boss walked in due to the pressures of work.
The work in seamlessly integrating digitally controlled pots etc would seem to be excessive compared to the cost of a new amp.
When I was a kid...I made a remote control for the light switch in the bedroom using fishing line, more sophisticated than string.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
02/18/2010 8:37 AM
If your old amplifier is setup with pre-amp out and pre-amp in, you might be able to find a remote-capable preamp.
Tom
Register to Reply 12 comments
Anonymous Hero (1); JohnDG (3); lyn (3); tdesmit (1); user-deleted-1105 (4)
