Previous in Forum: What's the Best 3D Software?   Next in Forum: Expanded Tubes in Boiler Drum
Page 2 of 4: « First < Prev 1 2 3 4 Next > Last »
Is IC Piston Engine Really Less Than 1% Efficient?
02/19/2010 12:55 AM
The majority of people who read the title of this article are going to go red with disappointment and anger ? Is this some kind of a joke. Some of the smartest minds in the world, millions of dollars and thousands of man hours have been spent in proving that the IC piston engine has an efficiency of at least above 20%. This is something like the gospel, we all take it for granted. But is it actually true ? And if it isn't, what does it mean for Global warming and our rapidly vanishing fossil fuel reserves ?
It all comes down to, as I have said before in some of my articles, a question of leverage. In order to understand this statement let us examine the manner in which an IC piston engine works: A fuel/air mixture is introduced into the cylinder and is compressed in a ratio of about 9 : 1 resulting in a rise in temperature and pressure. This compressed air/fuel mixture is now ignited. The pressure in the cylinder rises to 500 psi approx and the temperature to 2000 0 F. The total force exerted on the piston head depends on the area of the piston head. For instance if the diameter of the piston head were 2 ins. Then its area would = 3.14 sq ins. And the total pressure exerted on this area would be 500 x 3.14 = 1570 lbsf.
Coming back to the subject of levers. Thanks to Archimedes of 'Eureka" fame, most of us are aware that a 1 ft. long spanner used to turn a nut, will when a force of 1 lb is exerted on its end at right angles, result in a torque of 1 ft lb. being exerted on the nut.
Similarly if all other parameters remain the same and the length of the spanner were increased to 2 ft. Then the torque exerted on the nut would rise to 2 ft lbs and son on. If the length of the spanner were increased to 10ft. the same1 lb force exerted on its end would result in a torque of 10 ft lbs being exerted on the nut. In this sense the lever might be thought of as a force multiplier. Also note that in the case of a force of 1 lb exerted at right angles on a rod of 1 ft length and resulting in a torque of 1 ft lb might be thought of as being 100% efficient. i.e., power in equals power out.
In the IC piston engine the piston is attached to the crankshaft by a connecting rod. The connecting rod is in turn attached to the crankshaft through the crank throw. In order to translate the linear up and down motion of the piston in the cylinder into the rotary movement of the crankshaft it is essential that a lever be utilized. In the IC piston engine it is the throw of the crankshaft that takes on the role of a lever. Unfortunately the throw of the crankshaft has to be approximately half the diameter of the piston bore in length, if this were not so the piston would hit on the skirts of the cylinder as it traveled up and down. In the example given above of a 2 in. diameter piston the throw of the crankshaft would have to be approx. 1 in. One inch divided by 12 = 0.08 ft. The torque generated by 1570 lbsf would be 0.08 x 1570 = 130.8 ft lbs. Yet remember that it is only when the force is exerted at right angles that the full benefit of a lever can be realized. In the case of a piston moving down a cylinder it is evident that as the connecting rod moves down the cylinder its angle of attack is constantly changing, if we average out this angle of attack we arrive at an angle of approx. Sin 10 degrees. Sin 10 = 0.173approx. So that in order to arrive at the final amount of torque that is generated by an IC piston engine with a2 in diameter piston we have to multiply 130.8 x 0.173 = 22.6 ft lbs torque. Thus the initial force of 1570 lbsf that was exerted on the piston head results in a torque of just 22.6 ft lbs being generated or an efficiency of (22.6/1570) x 100 per cent. = 1.44 % . Hah ! you say you have lost your bet, the efficiency of the IC piston engine is more than 1% and the engineers probably have some method of increasing that figure to 20% or more.
Before we go down that road let us check with the figures given out by manufacturers. Since I am from India, I will use the figures published by the manufacturers of one of India's best selling cars the Maruti Suzuki 800. Here are some of the specifications:
Bore = 68.4 mm = 2.7 ins approx
Stroke = 72 mm = 2.8 ins approx.
37 bhp @ 5000 rpm
Area of piston head = 5.72 sq ins.
Ok! So 37 bhp = 37 x 550 = 20,350 ft lbs approx.
20,350 / 5000 = 4.07 ft lbs torque per power stroke approx.
Why, you ask is there so much difference amounting to almost a factor of 10 between the figures worked out using the initial effective pressure on the piston head and the figures given out by the manufacturer which are obtained using test equipment. Thus the figure obtained through calculations was 22.6 ft lbs while the manufacturers figure is 4.07 ft lbs. The answer lies in the fact that one of the design factors of the IC piston engine necessitates the opening of the exhaust valve at between 10 0 – 150 before BDC during the power stroke, if this were not done there is a good chance that the crankshaft would fracture as it comes to a halt at BDC. However, this also means that the pressure in the cylinder is reduced drastically during the power stroke. Engineers, therefore, use something known as the mean effective brake pressure to calculate the pressure in the cylinder during the power stroke. This mean effective pressure can be worked out by working backwards using the manufacturers figures. Remember BHP is the mechanical work output of the engine taken directly from the crankshaft, so there is not much room for really big errors. Thus: 4.07/0.112 ft = 36 lbsf. which in turn divided by Sin 10 =
210 lbsf. approx.
Using the new figures to work out the efficiency percentage gives: (4.07/ 2846) x 100 ( i.e. Torque / initial force x 100 ) = 0.14 % efficiency approx. Although there might be arguments against this figure , remember that a force of one pound exerted on right angles results in a torque of 1 ft lb being exerted, this gives an efficiency of 100% . Using the same method we have arrived at an efficiency of only 0.14 % for the IC piston engine ! Ok! Now let us try a different tack. 1 litre of petrol has a calorific value of approx. 3.6 MJ of energy. At each stroke 20 cu mm or 0.02 cc of petrol are injected into the cylinder having a calorific value of 37 x 20 or 740 J The figure given by the manufacturers works out to 4.07 ft lbs torque per power stroke. 4.07 ft lbs = 5.291 J approx. Therefore the efficiency calculated as a function of energy in to work out equals (5.291/720) x 100 = 0.71 %.So either way it appears that the IC piston engine has an efficiency of below 1%.
Next we have to ask ourselves, can we sustain this kind of wastage. Imagine going into a shop and ordering a soft drink and then throwing away 99.5% of it and drinking only the remaining 0.5%. It would be a complete outrage !
It is true that the IC piston engine has served mankind admirably over the years. It has enabled us to cross continents and to brave alike both the desert snds and the inhospitable wastes of the polar regions. It had even enabled us to fly. But ask yourselves at an efficiency of just 0.5% is it really worth it !
Lastly, is there an alternative, yes there is!! The question is why is it not being followed up.
This discussion was "closed" on 03/16/2010 1:18 PM. No new comments are allowed.
Message from admins:
This thread has run its course. Time to walk away...
Re: Is IC Piston Engine Really Less Than 1% Efficient?
02/20/2010 3:48 PM
At the risk of being repetitious, here is the first reply to this thread:
"I have some doubts about the torque figures used thus far, and about the consistency of measurement units. Let me suggest a few grains (or shovels) of salt...."
For instance, engines typically have torque specs quite a bit higher than 4 lb-ft! And there is no such angle as sin 10°!
That still just about covers it. However, there has apparently been a glitch in the system. I am supposedly subscribed to this discussion, but have received zero notifications since reply #1. (When I picked "Subscribe" again, it said I was already subscribed.)
In reply to #67
02/20/2010 10:36 PM
Have you looked in your email spam folder (assuming the type of email you use has one)? Perhaps the problem is not with CR4 not sending you a notice, but in receiving the notice.
J B
United States - US - Statue of Liberty - Who is John Galt?
02/20/2010 5:20 PM
I don't see what the problem is when you consider that the 37bhp @ 5000 rpm is the WOT performance of the vehicle as it approaches top speed. That's when the acceleration is falling off, and the air resistance is consuming most of the work being produced. Sure it sucks! But who drives like that? (oops... that's the wrong kwestion)
Too many things being considered here to try to analyze the entire system down to one number. The energy is leaving the system as losses that are hard (not impossible) to measure. Ever stand next to even a small vehicle as is whips by at 120kph? You'll know where the 'energy' went.
I'd've written a shorter post, but I didn't have the time.
#86
02/21/2010 4:11 AM
In your posting near to the end, you sated that the amount of petrol being used was0.02cc for every fourth cycle. but you have not multiplied your figures by 4 because the engine dose not fire for every stroke. This is why these engines are called 4 stroke engines, unless it is a 2 stroke, then it would fire every stroke.
Also it would be interesting if you could take this calculation one step further and tell us how many miles to a U.K. gallon this car moves.( 1 U.K. gallon =5 liters).
In reply to #86
02/21/2010 5:52 AM
1 UK Gallon = 4.546 Liters. Being off by .546 liters may not seem like much but when you are talking about 4.5 liters it's over 10%.
J B
02/21/2010 4:18 AM
Hogwash...
It's a dead giveaway as soon as you mention levers and piston dimensions.
To measure efficiency the system can be considered as a black box.
It's simply useful energy out/energy in.
#88
In reply to #87
02/21/2010 5:14 AM
That's what I have been telling shouting screaming. Nobody listened. Finally a cat had to second me .
In reply to #88
02/21/2010 11:10 AM
Register! Once you get rid of "Guest", many of us will pay more attention. I commonly skip over guest entries, and I'm fairly sure there are others like me.
In reply to #96
02/21/2010 5:24 PM
I think that was me. Sometimes I grab the nearest computer & comment without remembering to log on.
Last night was a bit hazy - if it wasn't me, then I probably meant to say it but Guest got in first. Apologies.
Whatever, that's what I said way back.
Good Answers: 11
#99
In reply to #87
02/21/2010 4:53 PM
Thanks Del, I was completely lost in all the units, angles and ratios, but I can cope with energy in to work out. GA
horsepower measures work, ponypower measures pleasure!
#105
In reply to #87
02/22/2010 8:07 AM
Why don't you get back on your space-ship and blast off into space using your plasma jet or whatever. Down here on earth, we still need levers and other mechanical components
#106
In reply to #105
02/22/2010 8:22 AM
Finally I did lots of research on the subject raised by you. I located some good web site links.
http://www.fueleconomy.gov/FEG/atv.shtml
http://jagadees.wordpress.com/2007/10/20/ic-engine-efficiency/
www.evworld.com/library/energy_numbers.pdf
http://www.kajul.org/EnergyBlogEN.php?Art=5
I once again am putting down my computation where I know the mistake is in taking air: Fuel ratio in volume rather than mass.
People may criticize, argue, use bad language etc etc Ultimately it appears that efficiency is not more than 15 % as per published data itself. The world needs a better solution- may be even dump IC engines. Today many are working on tinkering and making 10 to 20%(on the 15%) improvements- which is not worth the money spending. We need a disruptive technological approach.
Let me recalculate incorporating Air: Fuel ratio.
1. Piston displacement = 796 cc. Hence petrol intake = 796 cc.
2. Manufacturer also states that the compression ratio is 9:1.
3. Recommended Air to Fuel ratio is about 14.7 to 20 to 1 by mass and not by volume.
4. Hence Fuel intake is 796 x 1/(1+20) = 37.9 cc.
5. This is assumed to be a 4 stroke engine. Hence petrol is drawn in once in every 2 revolutions.
6. Further some people are confusing stroke to revolutions !!
7. A stroke is equivalent to just 180 degrees or half a revolution in a 4 stroke engine. Hence in a 5500 rpm, fuel is drawn in 5500 / 2 times in a minute.
8. It has 3 cylinders.
9. It generates 39.5 bhp at 5500 rpm.
10. Hence 37.9 cc x 3 cylinders x (5500 rotations/2) in one minute = 0.312675 x 10^6 cc of petrol is consumed in one minute or 0.312675 x (10^6)/ 60 = 0.0.5211x (10^5) cc per sec. = 0.0.05211x (10^2) liter
11. Taking petrol has 33,000 kilo J per liter (got this from website), 0.05211 x 10^2 liters of petrol is consumed in 1 sec. Hence 33 x(10^6)x 0.05211 x 100 = 171.97 x 10^6 joules of energy is input.
12. Output = 39.5 bHP. 1 bHP = 745.7 w Hence output = 39.5 x 745.7 w in one second = 2.9455x (10^4) Joules.
13. Hence output x 100/input in %= 2.9455 x(10^4) Joules x 100/171.97 x (10^6) Joules. = 1.71% only !!!!!
14. So efficiency figure has moved up just about 2%.
15. The error may be in taking air to fuel ratio based on volume and not on mass.
16. Web site search gives an indication that petrol engine efficiency is around 15% Fuel to wheel only. This further deteriorates.
17. I as electronic engineer never had thought this to be as low as 15 % granted mistakes in calculation. I think world needs a better engine (need not be Internal Combustion type) which does not degrade the environment.
In reply to #106
02/22/2010 8:32 AM
M S DIVEKAR, I don't mean to be insulting, but reading your posts is really giving me a head-ache.
"3. Recommended Air to Fuel ratio is about 14.7 to 20 to 1 by mass and not by volume.
4. Hence Fuel intake is 796 x 1/(1+20) = 37.9 cc."
cc (cubic centimetres, cm3) is a unit of volume. What you have stated at 4. would only be true if the fuel were the same density as air.
Please re-read the replies you have had from others regarding this matter.
#110
In reply to #108
02/22/2010 10:22 AM
No doubt about what you or I have said. I do not have info about air: fuel ratio.
So our calculations are wrong I admit. But People keep on arguing without pointing out mistake with back up data- which is annoying too. I definitely wish to know how much of fuel is consumed per second - for that very specific condition of Maruti Car 796 cc chamber size, delivering 39.5 BHP at 5500 rpm as claimed by the manufacturer. Bore size = 68.5mm, stroke length 72 mm, Compression ratio 8.7:1, I can give whatever data published in the manual. But I am trying to understand. DD James calculated using bore size etc and came to conclusion that eff was less than 1 % I have taken a different route. People can find mistakes - but let us and the whole world know how exactly in reality some one is getting 15% efficiency.
I do not want unnecessary arguments- I want facts and figures. Why should people flare up? That is not a solution. Ultimately I have found that cars are still not very efficient and the world needs a new engine. I am a scientist- I work towards a solution, by understanding current situation / technology (loop wholes in this technology) - that is all. Even after pointing out so many mistakes no-body can show me how we can make a car with 50 to 80% efficiency. I am looking for that answer.
#112
In reply to #110
02/22/2010 11:15 AM
Mr Divekar,
I believe I have the answer. I have built a working model of a new green engine which substantiates almost all of my expectations. It would be a pleasure to explain the working of this engine to you.
In reply to #112
02/23/2010 5:49 AM
Somehow I missed this post earlier. It sounds like you'd like to explain the working of your engine only to Mr. Divekar. Virtually all of us here would be very interested in knowing about your engine. Please describe it!
Good Answers: 247
#179
In reply to #110
02/24/2010 3:09 PM
Hi MS,
You say: Why should people flare up? That is not a solution.
A reason people flare up when presented with extraordinary claims by charlatans are many. First, such claims, if widely believed, support pseudo science, of which there is already too much. As pseudo science gains a stronghold, society suffers. Well- intentioned people have lost a great deal of money (that might have gone to uses that would benefit society) by investing in pseudo-science scams. Pseudo science, to the extent that it is believed, promotes gullibility and squelches analytical and critical thinking. This too is bad for society: we need more critical thinking, not less, because as a world we face some very serious problems.
Invariably, charlatans will resort to insult when logic fails to support their point. This demeans and devalues discourse.
As is obvious to anyone with a basic understanding of engines, the original poster's claim that engines are less than 1% efficient is completely wrong: a simple calculation of the energy output of an engine vs the energy value of the supplied fuel shows that the 25% efficiency figure that has been used as a rule of thumb for old-tech engines is correct*. So, when the math is so completely wrong, engineers are understandably offended -- we make our livings with math, and don't like to see mathematical garbage presented as valid. It is as if someone walks up to a brain surgeon and says: "An axe is just as good as a scalpel; why do you insist on the silly idea of using a scalpel?"
The same is true regarding physics, the underpinnings for much of what we do. When we see physics trashed, we can find it disheartening. In my daughter's school, her physics teacher is just barely adequate to the task, and science education has generally gone downhill in the US, so many of us are understandably sensitive to seeing pseudo-physics presented as physics.
My personal interest is in keeping the signal-to-noise ratio relatively high at CR4, because then it is a useful, fun site. If instead it is populated by pseudoscience promoters, the site loses its value to me -- there are already plenty of pseudo science sites around, and not enough sites that are focused on sound science.
Some of us are also concerned about fraud and scams, promoters of which show up at CR4 periodically. To the extent to which we fail to denounce fraud and scams, we tacitly permit their existence, so again, you can see how this could be an emotional issue.
That is a noble quest. Electric cars are in that range, if you ignore the energy efficiency of the generating method (which would of course be a mistake, if one were concerned about environmental issues and resource depletion.) If you came to this thread looking for efficiency answers, this is not the right thread: its premise is completely wrong, and the thread is not about improving efficiency. Instead, it appears to be about promoting a fallacy, and we can only assume the intent is to promote the original poster's engine in ways that only he can understand -- for many of us, this kind of thing makes us run the other way.
If you want a discussion of this, a separate thread would be a good place to start. But the short answer is this. The Maruti engine (if modern) can be expected to be 30% efficient at peak output. Fortunately, for fuel efficiency, it is small, so it is relatively highly loaded, keeping efficiency nearer to peak than would be the case with a large engine. However, sometimes your car idles and produces very little usable power (it's not making the car move) but consumes fuel, slowly. Under this condition, the cars fuel efficiency is effectively 0 (depending upon how you measure efficiency), and the engine's efficiency in driving the alternator (and loads like the water pump that are best considered parasitic) is perhaps 5%. At low loads, efficiency is somewhere between peak and 0.
If you search for BSFC (brake specific fuel consumption) charts for automotive engines, you will find that efficiency varies with load. The basic idea of hybrid vehicles like the Toyota Prius is to keep engine loading high, by using a relatively small engine, and by charging batteries at times when loading would otherwise be low (and then using that charge to aid acceleration because the engine is "too small" alone). By using such techniques, specialized valve timing, and many vehicle optimizations, the Prius, despite being much larger and heavier than a Maruti 800, gets similar mileage, and better mileage around town.
Vehicle efficiency depends, of course, on many things beyond engine efficiency. But that, and engine efficiency in general, is a topic for a different thread.
* One of the simplest ways to ascertain the truth of the 25% figure is to look at the fuel consumption charts available for most commercial (generator lawn mower, etc) engines. These can be easily found on the web. Just calculate the energy input (via BTU value of the fuel consumed) and the energy output (in, for example, hp-hours) and you will have your figure -- which for most of these engines, crude as they are, varies only slightly from 25%. Doing you own math will serve to verify the widely held "common knowledge" figure of 25%.
Good Answers: 18
#180
In reply to #179
02/25/2010 5:50 AM
Hi Blink,
I really liked your S to N ratio analogy. That is really cool!!
If only some people would listen more and pontificate less what great strides might be made towards gaining a clearer understanding of what has already been achieved and therefore help educate towards what paths might be available for solving the challenges that lie ahead. CR4 is one such forum if used appropriately.
Although IC engine technology has been advancing spasmodically, (I choose my words carefully) there now appears to be some really serious science being devoted in improving efficiency in the realms of the high speed light weight automotive product. It will be interesting to see how the '5 stroke' unit comes along and laser ignition looks very impressive. These are physics/applied engineering based initiatives similar to the solid first principles approach so ably demonstrated by the likes of Rudolph Diesel over a century ago.
Best wishes,
Massey.
If it ain't broke,leave it well alone .........until it comes looking for you!
Good Answers: 247
#190
In reply to #180
02/26/2010 2:26 PM
Thanks!
I recently came across a thread in Physorg, regarding using oxyhydrogen (known to the ill-informed as Browns gas, HHO, etc) to "clean up" coal burning powerplants. In that thread the S/N ratio was about .5. In a Popular Mechanics thread re a test of an "HHO" booster (in which it was shown the the unit had no effect at all, just as theory would predict) the S/N ratio was perhaps .3. for every 10 bad posts there were about 3 pretty good ones (this is more gut feel than actual count).
Fortunately, the S/N ratio on CR4 tends to be pretty high, especially if you include the witty-but-not-strictly-on-topic responses.
#201
In reply to #180
03/03/2010 7:20 AM
Massey,
First admit that your first post really sucks!! Then you can do what you like.
Good Answers: 37
#202
In reply to #201
03/03/2010 9:01 AM
Dear "Guest" - as far as I can determine, Massey's first post (to this thread) is #11; it sets out what I believe are completely factual numbers and conclusions. They clearly indicate that the claim in DDJames' original post is wrong. Many posts have shown the corrections to DDJames' bogus "math" and failures to use proper units, in addition to quite bizarre ideas of how much fuel is used (not all of those are from the OP, though). Massey's first post got 3 "Good Answer" scores; the ONLY thing I can find wrong is transposition of a comma and a space - nothing whatever to do with content. Until and unless you, DDJames, or someone else can set down clear, comprehensive, CORRECT, complete, and convincing examples to the contrary, the efficiency of IC engines remains at 25 - 35%, nowhere NEAR "less than 1%". Instead, egregious errors are rife in the posts of the one-per-centers, and have been pointed out time after time; none of these have undergone a full set of corrections acknowledged by the one who posted.
This thread has a surprising number of Good Answers and Almost Good Answers for a long one (a very short thread may have only a single response, and if it gets a GA, that's 100%, so a long thread with high percentage is unusual). I don't recall seeing a single one given to any of the one percent believers. There is a reason.... As Massey said, Q.E.D.
" Ignorance and arrogance have more in common than their last four letters. "
#181
In reply to #179
02/25/2010 12:37 PM
I have made it clear manytimes that my field is not mechanical or automotive. You must be aware that I had earlier started a discussion on 2^ N Internal combustion engine with much less mathematical background of IC engine efficiency. Through this current thread I got lots of insights and maths behind poor efficiency of Internal Combustion engine. My quest will continue to improve fossil fule based engines. as the world is now seriously concerned about carbon foot print.
When James claimed that the eff was less than 1% i got suprised. My idea of entering discussion was to extract data for my dream project (engine with eff more than 70%) and - I did get what I wanted - I tink. But I ma still not aware of what causes this huge difference in Fule generated HP & what comes out of the shaft.
Regarding Amrerican Education system- I too feel Indian education system also has degraded. It is 40 years since I finished my engineering and today's engineers know much less. Eeven as electronic engineer - I got exposed to all branches of engineering- at least a bit. This not so with current crop of engineers- who do not have multi -disciplinary exposure. But I still feel American higher education system gives more scope for innovation than the Indian system. At lower level- we drill subjects into the brain and few are able to absorb it- no creativitivty here (so they do not become torch bearers). n this context read "The period of greatest gain in knowledge & experience is the most difficult period in one's life."- I suppose that is why American current generation has plenty of richness given on platter to them and Indian / Chinese are hungry to achieve more !!
What I like about this subjet of IC engine is - I feel so far mechanical engineers and automotive engineers have given the world a 20% efficient syetm. Inventors designed the engines - but professionals who ran organizations for decaeds- earned aft salries - and did little improvement thereafter - I suppose. This is one of teh erasons at teh copenhagen Summit develoepd nations are being taken to task - for having degarded teh environment and pushed smae inefficient cars into our countries too- and now we are being asked to clean up. (Anyway thanks - because my brain has some food for thought) To reduce carbon emmission levels drastically within say 2 to 3 years-we need disruptive technologies- not small tinkering here and there. This is a multi-disciplinary approach and now electronic engineers must lead and mechanical / automotive engineers must support- as fresh thing ideas must come in. Electronic engineers with software, microchips can alter engine chaarcteristics easily . Question is - should MPFI be suitted to engine or engine be designed based on a target efficicency and target VI chaarcteristics in mind etc etc. This is too much philosophical- not part of this thread.
Well thanks anyway- because - I got what I was looking for. Just reproducing catchy slogans from your own site
"You progress not through improving what has been done, but reaching toward what has yet to be done." -- Kahlil Gibran
"If we all worked on the assumption that what is accepted as true is really true, there would be little hope of advance." -- Orville Wright
In reply to #181
02/25/2010 1:31 PM
Do read up on the Carnot cycle and related items. It has been pretty well verified as the theoretical limit on efficiency for heat engines, for a very long time.
I'm fully aware that English is not your first language, but your English is much better than many on CR4. You could make it better still by using a spell-checker. If the spell-checker does not work in your browser, then write your posts in 'Word', or whatever other word-processing software you use, spell-check there, then copy the text from the word processor, go to CR4, and paste the text there.
Dick
#109
In reply to #106
02/22/2010 10:17 AM
Hi M S Divekar
I don't know if this will help:
Stoichiometric ratio = 14.7 Kg of air for every 1kg of fuel.
Then a square engine with a 3" bore and 3" stroke will have a volume of
3" = 7.62cms
Volume = 3.81 2 x 3.14 x 7.62 = 14.56 x 3.14 x 7.62 = 347.32 cc
1 cc of air weighs 0.00125gms therefore mass of air in cylinder = 0.00125 x 347.32 =
0.43 gms therefore weight of fuel needed = 0.43 / 14.7 = 0.029gms
1 l of petrol weighs 720 gms, 1cc of petrol weighs 0.72 gms . 0.001 cc = 0.00072gms
So 0.00072 x 40.2 = 0.029 gms = 0.04cc
The 3 x3 piston engine needs 0.04 cc approx. for every power stroke.
#113
In reply to #109
02/22/2010 11:22 AM
First let me thank you James for that real input. There was no point in going on finger pointing as many have done unnecessarily.
Let me compute again using some of the data given by you specifically for 796 cc Maruti engine.
· Mass of air in 796 cc = 0.00125 grms/ cc x 796 = 0.995 grms
· Mass of fuel – assuming 14.7 : 1 rato at this condition of maximum power = 0.995/14.7= 0.0677grms
· Density of petrol = 720 grms / 1000 cc = 0.72gr/cc.
· Hence 0.0677 grms of petrol = 0.0677/0.72 = 0.094 cc.
· Fuel contains energy in terms of 33,000 KJ/ liter.
· Hence for 3 cylinders rotating at 5500 rpm, we need 0.094 cc x 3 x 5500/2 = 775.5 cc in one minute or 775.5/60 = 12.925 cc in one second.
· Hence energy input = 12.925 X (10^-3) liters x 33 x (10^6) Joules / liter = 426.525 X (10^3) Joules in one sec
· Max power delivered is 39..5 hp at 5500 rpm
· Output = 39.5 bHP. 1 bHP = 745.7 w Hence output = 39.5 x 745.7 w in one second = 2.9455x (10^4) Joules.
· Hence efficiency = 2.9455x (10^4) x 100 / 426.525 X (10^3) = 6.90%
· If Air toFuel ratio is 20 : 1 instead of 14.7, efficiency will be 9.39% for this specific model of car.
· I wonder whether the exercise was worth it.
· I think mechanical engineers – who made me- an electronic engineers do all this calculation – should find some other solution. Junk the IC engine first.
In reply to #113
02/22/2010 11:32 AM
It's often a good idea to have a quick look over one's calculations to make sure everything looks "reasonable".
" ... 775.5 cc [of fuel] in one minute ..."
Does that look reasonable to you? 46½ litres in one hour?
#118
In reply to #115
02/22/2010 11:58 AM
I think you did not read through the whole thing carefully. In a cylinder of 796 cc, fuel drawn in at a time is just 12.925 cc in one second when 5500 rpm/60 revolutions have been completed !!! It is 775.5 cc or or 0.775 liter in one minute when engine is running at maximum power of 39.5 hp.
Why do you jump to wrong conclusion too fast !!
"I try to view the challenges in my life not as annoyances, but as confirmations of fortitude." -- Oprah Winfrey
"I know the price of success: dedication, hard work and an unremitting devotion to the things you want to see happen." -- Frank Lloyd Wright
So I wish to see this IC engine junked
In reply to #118
02/22/2010 12:46 PM
Come ON! THINK!
13cc per second * 3600sec/hr gives you a fuel consumption of 46,800 cc/hr, or 46.8 liters per hour. 46.8 liters is well over 12 gallons! A three-hour trip would require a 37 gallon fuel tank, and if you arrived, you'd be on empty!
This is a very small engine at 0.8 liters displacement (796cc rounded off). At this rate, a 4 liter engine would use 46.8/.8*4=234 liters per hour, or almost 62 gallons per hour. A three hour trip would require a 190 gallon fuel tank!
Admittedly, you aren't going to be running the engine at maximum power the full time, so these numbers are exaggerated, but with such a small engine, trying to keep up with today's freeway traffic would require a large fraction of that power, and therefore a large fraction of that amount of fuel.
#117
In reply to #113
02/22/2010 11:49 AM
I really feel you are taking things too far to prove an non-existent point.
Being an electronic engineer does not condone making mistakes in calculations and units.
It has been earlier also pointed out that just check up the consumption with actual, and see whether they approximately match or not.
@15Kmpl - usual 800CC car of old model (newer ones have 20+ KMPL). Say @40KMPH - one liter will last 15/40*60 = 22 minutes. = 1320 secs
This will be @39 BHP = 39 * 1320 * 746 = 38.4 MJ ?
So the efficiency = 100% ? (38.4/39 = 0.985 = 98.5%)
But we all know it is not.
Where is the fallacy?
BTW: I am not mechanical engineer either, nor automobile or things similar. (That's why i took the 0.02 of DDJ on face value)
In reply to #113
02/22/2010 11:58 AM
1. The displacement of engines is normally given as the total of all its cylinders, so you must divide by the number of cylinders to get the displacement of one cylinder, or NOT multiply by the number of cylinders later on.
2. Anyone suggesting elimination of a technology must suggest something he/she considers better. What is your suggestion? It must be something that can carry 2-5 people plus their 'stuff' in comfort in any weather for 300-500 miles, renew its energy supply economically in 5 minutes at a relatively convenient location, and repeat...
#122
In reply to #119
02/22/2010 1:14 PM
This is what I said long back - number of cylinders (and valves) are added to improve the conversion efficiency and not to increase the fuel intake.
OP might be aware of the fact but Mr MSD is totally on a single point agenda-
BTW: As a first step has he bothered to junk his car?
- I really wonder which of the HHO cars he is advocating for.
We didn't junk the incandescent lamps even at around 9% efficiency till we got tubes at around 20%
So for ICE to be junked at around 30% at least we need a 40-50% efficient engine? Of course the hightech ends like GTE are ruled out due to complexities and start up time.
In reply to #105
02/22/2010 8:24 AM
What Del is suggesting is a very normal and simple approach. Just remember, there's more than one way to skin a cat (sorry Del...I couldn't resist). There is nothing wrong with doing a detailed analysis of every component in the system, but that can be time consuming and more prone to error(s).
J B
#111
02/22/2010 10:46 AM
Hi this is for M.S Divekar
Then a square engine with a 3" bore and 3" stroke will have a volume of :-
(3" = 7.62 cms)
So 0.00072 x 40.2 = 0.029 gms = 0.4cc
Taking this a bit further. 39.5 bhp @ 5500 rpm. There are 5500/2 or 2500 power strokes per minute. 2500 x 0.04 = 100cc petrol/min
100cc = 1/10 l therefore 100cc = 3,300,000J : 39.5 bhp = 29455.15J
Therefore efficiency = (29455.15/3300000) x 100 = 0.89% . Is there an explanation for this result ? Some help.
#114
In reply to #111
02/22/2010 11:32 AM
39.5bhp = 29455.15 joules Watts.
100CC petrol per minute- convert into per second and you will have the answer.
And as I said the answer is still too much (about 53%)
We do not get that efficiency in the non CC (combined Cycle) Gas Turbines, except in the larger ones we manufacture.
There is still something wrong about the data.
And as far as I know, the critical Fuel Air ratio (14.7) is at the ignition stage - ie when the air is compressed at about 9bar. There the density is obviously a bit more. Though due to the temperature the density will not be as high as that of room temperature compressed air.
#128
In reply to #114
02/22/2010 8:07 PM
Guest you go from gloating to quite clever to deceitful. Go away till you can put a name to your posts! Please!!
In reply to #111
02/22/2010 11:33 AM
"I did NOT rigorously check all your math, but "39.5 bhp = 29455.15J" can't possibly be correct!
the bhp is a unit of power, while the J is a unit of energy. Energy is the product of power and time, so the power must be multiplied by a time. since the previous paragraph mentioned fuel in cc/min, that time might be one minute. Now what conversion factor did you use to convert from bhp-min to Joules?
#120
In reply to #116
02/22/2010 12:12 PM
This calculation is correct. 2.9455 x 10^4 watts for 1 second also means 2.9455 x 10^4 Joules as 1 watts ec = 1 joule
It has been thoroughly checked. No mistakes. I am not looking for minor improvements in eff. I am looking for a new engine with better tahn 50 to 70% eff. We are no where near this.
"Do not follow where the path may lead. Go instead where there is no path and leave a trail." -- Ralph Waldo Emerson
"Determine that the thing can and shall be done, and then we shall find the way." -- Abraham Lincoln
"Mystery creates wonder and wonder is the basis of man's desire to understand." -- Neil Armstrong
In reply to #120
02/22/2010 1:23 PM
OK, I took the time to verify those numbers. Yes, the numbers are correct, but the units are NOT.
Any value of power can NOT equal any unit of energy. The equation should read either:
39.5 bhp-sec = 2.95 x 10^4 Joules (an energy equation)
or
39.5bhp = 2.95 x 10^4 Joules/sec (a power equation).
BTW, the result can not have more digits of precision than the least precise original value.
Also, try using a spell-checker. It would help you to avoid such things as "watts ec".
#130
In reply to #116
02/22/2010 9:05 PM
d.k warner
OK! If you still feel like quibbling: Lets convert to seconds:
39.5 bhp = 29455.15J/min = 29455.15/60 J/s = 490.919 J/sec
AND 3,300,000 J/min = 3,300,000/60 J/s = 55,000 J/sec
Therefore efficiency = (490.9 / 55000) x 100 = 0.89 %
Personally I think it's time for the "Pants on the ground" song.
P.S. I think you should follow it up more rigorously, it's an important issue that affects all of us!
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
In reply to #130
02/22/2010 10:20 PM
AND 3,300,000 J/min = 3,300,000/60 J/s = 55,000 J/sec DDj,
What ARE you talking about?
I've been reading all this "mullarky" from the beginning, and thought you would have grasped the sense of it before this.
Where did you get the figure 3,300,00 J from? What is your understanding of it?
Stu
"Nothing, is as it seems." Dr Wally.
#133
In reply to #131
02/22/2010 10:48 PM
Horsepower (HP) is the name of several units of measurement of power. The most common definitions equal between 735.5 to 746 watts. The horsepower is not recognized in the International System of Units (SI).
And here
So, horsepower (abbreviated as hp) is a measure of power, as is Watt (We come full circle, from Mr. Watt and horses to Horsepower and back to Watt!).
Now, let's for a moment talk about ENERGY. Work and heat are two forms of energy. If you rub two pieces of metal together and work at it, they heat up! Or if you take a metal bar and put it end-to end between two heavy objects and heat up the rod by a torch, the rod will expand and push the object apart. These two examples show that work and heat are forms of energy and are convertible to one another. Electricity delivered to our homes is also a form of energy.
Energy per unit time, as mentioned, is power. Units of power in common use are horsepower (hp) for work, Btu/hr for heat, and Watt (W) for electricity. As you expect these units are related. It is due to historical precedent that terms other than W are used. In the metric system, we can express all the above in Watts.
In any case, by referring to table of conversions, you will see that one horsepower is 746 W and 2545 Btu/hr.
To summarize:
Power can be expressed in terms of horsepower, Btu/hr, or Watts. Energy, which is power multiplied by time, is expressed, correspondingly, in lb-ft, BTU, and Joules.
In particular, 1 W = 1 Joule per second. I BTU=1055 Joules.
I thought that this is supposed to be known to everybody- to compare the figures when both are on same unit.
If you divide BHP - or Watt by time then it is ML2T-3/T = ML2T-4
And I am not aware of any physical quantity with this dimension. Things are getting out of hand. There is a way of proving everything but not through wrong mathematics.
#151
In reply to #131
02/23/2010 6:56 PM
Try to follow the thread Stuey, don't make like an expert if you can't read!
In reply to #130
02/22/2010 10:34 PM
It's hardly quibbling when your values are just plain wrong!
I suppose it could be called quibbling when I say you have too much precision in your results (39.5 is given to 3 digits of precision - no matter how precise your conversion factors are, the answer should not have more than 3 digits of precision).
But I quote: "39.5 bhp = 29455.15J/min = 29455.15/60 J/s = 490.919 J/sec", and that is just plain wrong!
The conversion from horsepower to Watts is 1.000 horsepower = 745.70 Watts (more precision available on the conversion factor, but there is no need). Since A Watt is defined as a Joule per second, we can then say that 1.000 horsepower=745.7 Joules per second. Multiplying 39.5 hp by 745.7 (J/s)/hp gives 29455.15 J/s, which must be rounded to 3 digits of precision: 39.5 hp = 29500 J/s or 2.95 x10^4 J/s.
Since you used J/min instead of J/s, your result for this step is off by a factor of 60! Any subsequent calculations dependent on this value will be wrong by the same factor.
In the next line, you say "AND 3,300,000 J/min = 3,300,000/60 J/s = 55,000 J/sec". Now that is a true statement, but What does it have to do with the efficiency calculation? In post 124, MJB shows (I believe correctly) a theoretical fuel consumption of 0.117 liters/min of fuel having 33MJoules/liter of energy content. Then your theoretical fuel energy input is 0.117 l/min x 33MJ/l =3.86MJ/min, or 3,860,000 J/min. Divide by 60s/min, and you get 64,400 J/s or 6.44 X10^4 J/s.
This gives a theoretical efficiency of 2.95 x10^4/6.44 x10^4 = 0.458, or 45.8%.This is in agreement with mjb's final efficiency, and as he stated, it is almost certainly too high.
Good Answers: 119
#124
02/22/2010 2:46 PM
This is getting really silly. Please stop with the bad math and unit manipulation. We are not here to do basic homework problems, but I'll post this anyway. Given the OP's original engine data...
There is NO real problem with the internal combustion engine. It is the CHOICE OF FUEL used in the engine. There are no simple alternatives, but given a carbon neutral, sustainable and renewable fuel source, there would be no reason to denigrate this marvelous piece of modern engineering.
#134
In reply to #124
02/22/2010 11:03 PM
Excellent job done BUT, BUT let me know how volume per cylinder is 254.57 cc. I am getting
· . It must be noted that bore dia is 68 mm, stroke length is 72 mm. Hence volume per cylinder is = pi x d^2 x s = pi x 6.8^2 x 7.2 cc = 1045.9 cc. Now there may be other issues which restrict the volume to 796 cc as declared by the manufacturer. Hence it is 796 cc per cylinder and not for all cylinders put together.
Hence 45 % efficiency is also divided by 3 and hence is near 15% only.
Good Answers: 119
#135
In reply to #134
02/22/2010 11:30 PM
Basic math/geometry PLEASE!!
Radius or Diameter?
Volume of cylinder= (Pi x R^2 x H)
OR
Volume of cylinder= (Pi x D^2 x H) /4
I recall seeing a statement that this is a 3 cylinder engine with a 0.8 liter (total) displacement rating. My table numbers seem to support these numbers. This is not difficult math!
#136
In reply to #135
02/23/2010 12:25 AM
OK. You are right- I goofed up. So the efficiency is near 46% but again why did you or whoever scale it down by 50% again? Any reasons?
"Curiosity has its own reason for existence" -- Albert Einstein
"Nothing great was ever achieved without enthusiasm." -- Ralph Waldo Emerson
"Let me tell you the secret that has led me to my goal: my strength lies solely in my tenacity." -- Louis Pasteur
Good Answers: 119
#141
In reply to #136
02/23/2010 2:20 AM
I am considering the practical example of an IC engine as used in a personal transportation vehicle. Mechanical losses in the drive train and rolling resistance will consume several horsepower. If 37 hp is available at the crankshaft, I estimate only about 20-25 hp will be available to move people (and the air). Remember, at sustained highway speeds the primary energy use is just overcoming air resistance (drag). If you look back at my 1000 mile trip post #49 , this was a REAL example which indicated typical energy conversion around 22%.
On wiki alone, there are numerous pages describing heat engines, their thermodynamic efficiencies and theoretical limits. Suggest starting here...
http://en.wikipedia.org/wiki/Internal_combustion_engine#Energy_efficiency
If you are just looking at IC engines alone, the shaft horsepower is what you want. Published energy conversion efficiencies can range up to about 45%. If you are debating the pros/cons of IC engines, these numbers can be useful. If you are planning to design a mass-market engine for practical use, I would start by using use a more conservative efficiency value.
#147
In reply to #124
02/23/2010 10:58 AM
I decided to verify my calculation vis-a-vis the table given by you. Pl see some discrepancy I noticed.
I am just quoting from the table given by you.
Fuel mass per stroke = 0.065 grams / power stroke.
Fuel density = 0.72 grams/cc
Fuel volume per power stroke = 0.047 cc/ power stroke as given. But = 0.065g/0.72g/cc= 0.0903 cc
Manf engine rating = 5000 rpm
Power stroke per rev = 0.5
Fuel use = 116.63 cc / mnt = 0.047 *5000 *0.5 = 117.5 cc. BUT = 0.0902 x5000 x 0.5 = 225.5 cc / mnt
Volume conversion = 1000 cc/ liter
Fuel use per mnt = 0.117 liters /mnt as given . BUT = 0.2255 liters/mnt
Theoretical fuel energy = = 33x 10^6 J/ liter
Time conversion = 60 sec / mnt
Theoretical Fuel energy = 64143.84 J/ sec or watts = 33*(10^6) *0.117/60 . BUT = 33*(10^6)* 0.2255/60 = 124025 J/sec or watts
Energy unit conversion = 745.7 w / hp
Theoretical Fuel energy = 86.02 hp as given = 64143.84/745.7 =, BUT = 124025/745.7 = 166.32 HP
Manufacturer's engine rating = 39.5 HP
Engine efficiency = 0.46 as given = 39.5/86.02. BUT is actually = 39.5/ 166.32 = 0.2375 or 23.75% ONLY.
So all the following computations carry this error. Hence efficiency is not 45 % but only about 24% or so. It is still better than 1 % we started with, but still far below my expectations of 60 to 80% at the shaft - as explained by you
"March on. Do not tarry. To go forward is to move toward perfection. March on, and fear not the thorns, or the sharp stones on life's path." -- Kahlil Gibran
"Keep away from people who try to belittle your ambitions. Small people always do that, but the really great make you feel that you, too, can become great." -- Mark Twain
Good Answers: 119
#148
In reply to #147
02/23/2010 1:10 PM
I welcome corrections where needed and you have spotted an obvious error. Well done!
About 24% efficiency is what I would expect to see in a production vehicle and is close to what I get in my own vehicle. Thanks for the correction. Updated table is below...
Efficiencies above 50% for small thermal engines is pretty unrealistic. You should review this topic more thoroughly. There are thermal engines constructed of exotic (high temperature) materials which can have higher efficiencies (near the theoretical limits), but these are not currently practical or economical for general use. As stated previously in this thread, LARGE thermal engines (ships, power plants, etc.) have higher efficiencies with some also approaching theoretical limits.
Good Answers: 37
#150
In reply to #148
02/23/2010 3:29 PM
GA from me. Thank you for simplifying the effort to determine which units belong where, what conversion factors are needed, etc.; very helpful.
I've done a quick-&-dirty calculation, choosing an engine which is more widely distributed, and for which it is a bit easier to obtain information. This is the Continental O-200 aircraft engine, which entered production in 1947, and was being built into the 1980s; it may be back in production now. One citation: http://en.wikipedia.org/wiki/Continental_O-200. A search will find you hundreds of other references. It is routinely run at a particular setting for long periods, and the fuel burn is well documented for various settings because a pilot MUST know how much fuel will be consumed in order to plan a flight; his/her life depends upon it.
The engine was/is rated at 100 horsepower or 75 kW. A very common setting is 75% power; in a Cessna 152 this results in a fuel burn around 6.5 US gallons per hour (and the speed conveniently comes to about 100 knots, making time / distance calculations simple!).
6.5 gallons/hour * 3.7853 liters/gallon = 24.6 liters/hour, or 24,600 cubic centimeters/hour. 24,600 cc/hr * 1 hour/3600 seconds = 6.83 cc/second.
6.83 cc/sec * 33,000 J/cc = 225,500 J/sec = 225,500 watts (= 225.5 kW) theoretically available from this fuel volume.
At 75% power, the engine develops 56.25 kW. Dividing 56.25 kW by 225.5 kW shows an efficiency of 24.9 %. It is likely a bit less; aviation fuel is probably has a little higher energy content due to elimination of the more volatile fractions to prevent vapor lock at altitude. If it has, say, 35,000 J/cc instead of 33,000, the apparent efficiency will drop to 23.5 %. (And "percent power" is nominal, rather than measured, so it may develop less than 56.25 kW. Setting is usually done based upon engine rpm; 75 % of peak-power rpm will yield less than 75 % of the hosepower because the torque AND rpm are down.)
Still, an efficiency in the low 20s (per cent) is realistic.
#153
In reply to #148
02/23/2010 7:57 PM
Hi! Its me again and I don't want to sound boring BUT it seems to me that while mjb 1962853 has converted fuel into J/sec he has left the horsepower calculation at 39.5 hp/min! So there is a huge difference in his result! Here are my results using the same cylinder bore and stroke dimesnions:
Bore = 6.84 cm , stroke = 7.2cm
Volume of cylinder = pi x r^^2 x h = 3.42 ^^2 x 3.14 x 7.2 = 264.4 c c
Energy density of air = 0.00125 gm/cc
Energy density of air in cylinder = 264.4 x 0.00125 = 0.33 gms
Stoichiometric ratio = 14.7 : 1
Needed density of petrol in cylinder = 0.33/14.7 = 0.022 gms
Density of petrol = 0.72gms/cc
Density 0.001 cc petrol = 0.00072
Volume of petrol in cylinder = 0.035 cc with density 0.00072 x 30.5 = 0.021 gms
Manufacturers figures = 39.5 bhp @ 5000 rpm
Volume of petrol used in 1min = 0.035 x 2500 = 87.5 cc
1 litre petrol = 33,000,000 J
87.5 cc petrol = (33,000,000/1000) x 87.5 = 2887500 J = 3872 bhp
39.5 x 745.7 = 29455.1
(29455.1 / 2887500) x100 = 1.02 % efficiency.
And again :
(39.5 / 3872) x 100 = 1.02 % efficiency.
Here is how mjb 1962853's results should look !
Volume of petrol used 1 min = 224.5 cc
Volume of petrol used in 1 sec = 224.5 / 60 = 3.75 cc
1 litre of petrol = 33,000,000 J
1 cc of petrol = 33,000 J
3.75 x 33,000 = 123 733.5 J = 166 hp/sec
AND 39.5/60 = 0.65 hp/sec
(0.65 /166) x 100 = 0.4% efficiency.
Also he is right 50% efficiency does sound unrealistic!
In reply to #153
02/23/2010 9:06 PM
Unfortunately, you don't seem to be as easily educated as Mr. Divekar.
A power ratio is just as valid when both intake and output are converted to horsepower (as mjb did), as it is when both intake and output values are both converted to Watts (Joules per second), or kiloWatts, or any other valid power units.
Your use of terms does not favor logical progression through the calculations. For example, I quote: "Energy density of air = 0.00125 gm/cc". The value 0.00125 g/cc is the density of air, not the energy density. As far as an IC engine is concerned, the air contains NO energy, and if it did, the value would have to be given in Joules/cc (or any other unit of energy/cc).
"Energy density of air in cylinder = 264.4 x 0.00125 = 0.33 gms". The product 264.4 cc* 0.00125g/cc does indeed give a result of 0.33g, but that value is neither Energy, nor density; it is mass. BTW, the abbreviation for gram, both singular and plural, is "g". "gms" means "gram-milli-seconds"
I'll skip over to your worst infraction: "87.5 cc petrol = (33,000,000/1000) x 87.5 = 2887500 J = 3872 bhp". You start with a volume (87.5 cc), have a couple of energy quantities in the middle, and end up with a power. Volume is NEVER equal to energy, and energy is NEVER equal to power.
87.5 cc petrol contains (33,000,000/1000) x 87.5 = 2887500 J of energy. You MUST include a time to convert energy to power, and you show none.
Once you use the correct terms for quantities, use (and show) correct units for all values, and use true equations, you just might find out that mjb was right, after he corrected his single error.
#164
In reply to #155
02/24/2010 7:10 AM
Hi! dkwarner,
I said at the beginning of this post that there would be a lot of red faces and a lot of anger and disappointment. Before shooting of about time etc., just have a look at mjb's post where he specifically quotes 33Mj/l ! Whats wrong with that? You can also see that he has given the fuel energy in Joules/ sec and has taken the manufacturers value of hp/min. PLEASE just check your facts before going off ! To give an exact quote from his post, so that maybe you'll understand. He says : 123734.26/Joules/or watts sec and then converts this into horsepower as 165.93 hp/sec (please note if it has'nt already caught your attention). He then proceeds to divide manufacturers figures for hp/min (1.e 39.5 bhp/min) by the theoretical hp/sec and comes up with an efficiency of 24% and according to him that is about right. These are the facts that you are going on trying to shove in my face!!!
Good Answers: 37
#169
In reply to #164
02/24/2010 8:35 AM
"These are the facts that you are going on trying to shove in my face!!!"
To repeat, but with a far more general meaning than you intended, and a bit more emphasis: These are FACTS that you are trying to shove in my face!!!
Oh - well then, no WONDER that we're having so much trouble getting through - clearly Your Mind Is Made Up. And you somehow think believe that you've stumbled upon a Great Truth, and that millions of careful measurements by tens or hundreds of thousands of engineers and others around the world have all been wrong - and all wrong in the same direction, and by about the same amount, remarkably - despite the fact [that bad word, again] that they've been able to use units of measure properly, that their work has been checked and re-checked, and that the results of their calculations have led to feats such as Voyager's non-stop, non-refueled flight around the world. If, as you contend, their engines were only about 1/20th as efficient as predicted, how far would they have gone?
Try doing your calculations ab initio and actually keeping track of every unit at every step (as I attempted to do when showing a simpler example using the Continental O-200, a variant of which was used on Voyager's flight). Until you can do that without having blatant errors, I'm betting on the 20+ % efficiency.
In reply to #164
02/24/2010 12:59 PM
I don't know why I even bother responding...
"just have a look at mjb's post where he specifically quotes 33Mj/l ! Whats wrong with that?" Nothing! 33MJ is the standard value for the energy content of one liter of gasoline (petrol), so the energy content is 33MJ/l. It would have been slightly more rigorous if in the comment column he had either said "Theoretical fuel energy content", or "Theoretical fuel energy/liter", but anyone capable of understanding his table should have no problem with that. Similarly, the Joules/sec is correct, although the comment column could have said "Theoretical fuel energy consumption", or "Theoretical fuel energy rate".
Now WHERE do you see him using "the manufacturers value of hp/min."? For anyone not using calculus, there is no such thing as hp/min. That set of units would imply a changing power level over time. He has to accept the manufacturer's value of hp (NOT hp/min), unless some independent testing agency provides a different value of POWER.
Normally, when I quote, I copy from the original and paste into the response, enclose the pasted text in quotes, and then convert the pasted text into italics: "He says : 123734.26/Joules/or watts sec" Perhaps that is what your muddled mind sees, but that is NOT a quote! After the value 123734.26, the units column has "Joules/sec or watts" A joule/sec IS a Watt, and both of those are units of POWER. The units you show "Joules/or watts sec" are both ENERGY units, and do not appear anywhere in his table.
"and then converts this into horsepower as 165.93 hp/sec" NO! He converts it into horsepower, period. The time is already included in the definition of horsepower (1hp=550 ft-lb/sec), among other possible definitions.
"He then proceeds to divide manufacturers figures for hp/min (1.e 39.5 bhp/min) by the theoretical hp/sec" NO! He divides horsepower by horsepower to obtain a ratio that has no units, and can be expressed as a percentage.
Yes! These are facts. If you can not accept them as such, then as Ron said, your mind is made up and you can't be helped!
#166
In reply to #155
02/24/2010 7:41 AM
dkwarner
I am giving you a chance to redeem yourself. OK, energy density of air was a slip up, it should have read plain 'density of air'. Take the final result. 1.02% at peak efficiency is the figure I come up with for the IC piston engine. mjb's figures come out as 0.4% efficiency. So there you have it. Like it or not and I suspect you don't like it !!
In reply to #166
02/24/2010 8:13 AM
"mjb's figures come out as 0.4% efficiency"
You have inserted an imaginary "%" indicator. Efficiency of 0.4 ≡ 4/10 ≡ 40/100, or 40%.
Elsewhere you mis-quote again, stating that they use a figure with units "horsepower/min" - in this case, you've imagined the "/min".
#170
In reply to #167
02/24/2010 9:50 AM
Right John,
This is supposedly an engineering forum, I have no other choice but to report mjb's post and ask the moderator to settle the issue once and for all. Is that amenable to you ?
In reply to #170
02/24/2010 10:26 AM
You can if you like, but if you just tell us the number of the post to which you are referring (I may have assumed you were looking at another, as you didn't cite the post in question), perhaps we can take it from there.
Oh, by the way, surely it's my post you should be reporting, if anyone's?
In reply to #166
02/24/2010 2:48 PM
What I don't like is people who can't use math and units correctly, pretending they can!
As John said, mjb never had a value of 0.4%! He had a value of 0.4 (period - no %). YOU added the %. In case you weren't aware, % is a symbol for "percent", which is a shortening of "per cent", and that means "per hundred" or "/100". when you convert from a ratio to a percent, you must multiply by 100!
When mjb was made aware of the one error in his original table, he quite graciously accepted the fact, and produced a new, corrected table (post 148),with a final efficiency result of 0.24, which is 24%. He then took the trouble to restate it all in slightly different format (post 172). If you can find any error in either of those posts, please point it out.
In going through post 172, the one item that confused me for a second was the line: "Manufacturers figures = 39.5 [hp] @ 5000 rpm [1/minute]". The "[1/minute]" is simply the correct mathematical units for rpm. A revolution is a pure number - hence the 1 per minute. It does NOT say nor imply horsepower/min.
You have clearly shown yourself as one who has his mind made up and can't be swayed by correct math or other facts.
Good Answers: 37
#157
In reply to #153
02/23/2010 9:34 PM
"Needed density of petrol in cylinder ..." HUH? Since you give a value in "gms", which I suspect you intend to represent grams ("g"), this would be mass, not density. In any case, you go through four steps, and conclude that 0.022 gms [sic] equal 0.021 gms [also sic].
You later come to the bizarre conclusion that the energy from 87.5 cc of gasoline / petrol equals 3872 brake horsepower, though there is no conceivable way in which BRAKE hosepower can be involved. (see http://en.wikipedia.org/wiki/De_Prony_brake to learn what the term means).
Then you have the term "hp/sec" - could you please explain what it means?
Good Answers: 119
#162
In reply to #153
02/23/2010 11:41 PM
Horsepower is already energy-per-unit-time by definition. You do not divide by 60. The per-unit-rate-of-change of horsepower or
d(hp)/dt
which does have units of [horsepower/second] is not used or needed anywhere in this series of calculations.
You really do need to study your units and how to use them. I made an error in the one table by not thoroughly checking my units, so mistakes do occur. However, you do not seem to understand the fundamental properties of mass, density, energy, and power. I'm not trying to be rude, but it is critically important to understand these properties before trying to analyze more complex systems.
IMHO this horse(power) is long dead, so I'm moving on to the next topic that catches my attention. Sorry, couldn't resist the parting pun
#165
In reply to #162
02/24/2010 7:28 AM
mjb
Just look at your table, that is exactly what you have done. You have given a figure of 224.97 cc /min . Since 1 cc = 33,000 J Then it follows that 224.97 cc = 7424010 J you have next divided this figure by 60 to get 123734.26 J/sec You have further divided this figure by 745.7 to get 165.9 hp/sec ! And to top of all your marvellous calculations you have divided 39.5 which is the manufacturers figure for hp/min (i.e 39.5hp) by your figure for theoretical hp/sec and have announced an efficiency of 24% !! Really great, further instead of admitting this mistake, you are spouting off about mistakes that I have supposedly made, just wonderful. Keep it up!!!!
Good Answers: 119
#172
In reply to #165
02/24/2010 11:26 AM
I welcome a site moderators input as I do not believe I have violated any forum protocols or been rude or insulting in any way. This is an Engineering forum and most here would have hoped this thread would provide some clear answers for you and other curious readers. Here is my last attempt to correct your calculations. If you are not able to check your work by properly understanding and monitoring the units, then it is unlikely you will ever get realistic answers.
Bore = 6.84 [cm] , stroke = 7.2 [cm]
Volume of cylinder = pi x r^2 x h = 3.14159 x 3.42[cm] x 3.42[cm] x 7.2[cm] = 264.6 [cc]
Density of air = 0.0012 [g/cc] (at 20 deg C)
Mass of air in cylinder = 264.6 [cc] x 0.0012 [g/cc] = 0.318 [g]
Needed mass of petrol in cylinder = 0.318 [g] / 14.7 = 0.0216 [g]
Density of petrol = 0.72 [g/cc]
Volume of petrol in ONE cylinder = 0.0216 [g] / 0.72 [g/cc] = 0.030 [cc]
** Volume of petrol used in THREE (x3) cylinders in ONE power cycle = 0.090 [cc]**
Volume of petrol used in 1min = 0.090 [cc] x 5000/2 [1/minute] = 225 [cc/minute]
1 liter petrol = 33,000,000 [J/liter]
225 [cc/minute] x 33,000,000 [J/liter] x 1/1000 [liter/cc] = 7,425,000 [J/minute]
7,425,000 [J/minute] x 1/60 [minute/s] = 123750 [J/s]
123750 [J/s] = 123750 [Watts]
123750 [Watts] x 1/745.7 [hp/Watt] = 166 [hp]
39.5 [hp] / 166 [hp] x 100 = 23.8%
39.5 [hp] x 745.7 [Watts/hp] = 29455 [Watts]
29455 [Watts] / 123750 [Watts] x 100 = 23.8%
And again...
Volume of petrol used 1 min = 225 [cc/minute]
Volume of petrol used in 1 sec = 225 [cc/minute] x 1/60 [minute/s] = 3.75 [cc/s]
1 liter of petrol = 33,000,000 [J/liter]
1 cc of petrol = 33,000 [J/cc]
3.75 [cc/s] x 33,000 [J/cc] = 123750 [J/s] = 166 [hp]
These are reasonable estimates which are supported by a large body of published theoretical and empirical work. I wish you good luck in your endeavors.
#173
In reply to #172
02/24/2010 12:40 PM
Aren't you wasting your time ? Difficult to convince one with single point agenda.
(In fact most of us are confusing the issue by going into different quantities)
Just go for energy balance equation
1 lt petrol = 1MJ heat or rather total combustion energy.
Then power = 39.5 BHP (with reservation - Engine rarely run at full power even on expressways or autobahns - I haven't seen even on the autobahns where speed limit is not there - the driver flattening the accelerator pedal)
Each stroke = cc petrol
So one lt petrol lasts ... seconds
Total Energy = KW
You get the efficiency.
I have left the mathematics long back on this post.
I am (and let us be) a bit more into where the help is needed- a la turbine expansion,orifice function even austenites or SF6 rather than wasting time here. There are alot of posts with genuine problems.
BTW: a guest can be reported and the post can be deleted but can not be censored (or the BB can monitor my IP Address? )
In reply to #147
02/23/2010 1:15 PM
Yes, you did indeed find an error in mjb's table. He multiplied instead of dividing. That makes it agree with the fuel intake of my post 104. The discrepancy between your 0.0903 cc and my 0.087 cc is from 2 factors: 1. I took into account the fact that the piston can not aspirate its full volume (I estimated 750 of the 794 cc - I have done no calculations to support or refute this estimate). 2. I used a density of 0.70 g/cc. The density of course changes according to the formulation. In fact here in California, both of our values are probably low, since they always include some ethanol, with a density of around 0.78 g/cc.
Congratulations for sticking around long enough to finally arrive at reasonable values!
Dick
Good Answers: 37
#152
In reply to #149
02/23/2010 7:22 PM
"I took into account the fact that the piston can not aspirate its full volume (I estimated 750 of the 794 cc - I have done no calculations to support or refute this estimate)." It is my understanding that the aspirated volume is precisely what is described by "volumetric displacement". The remainder (combustion chamber above the piston at TDC - Top Dead center) is not counted when designating engine size. It DOES come into the calculation of compression ratio when its volume is divided by the displacement of one piston.
In any case, your two values for fuel intake are only a few percent different; the main concept [the claim that IC engines are <1% efficient] is wrong by many times that amount.
In reply to #152
02/23/2010 8:19 PM
I'm definitely NOT an IC engine expert, but I am a physicist. Unless I am greatly mistaken, in a normally-aspirated engine, the only thing causing the air/fuel mixture to enter the cylinder is the difference in pressure between atmospheric and the cylinder. All fluids take time to flow. 5000 RPM is 83.3 RPS, so one revolution takes 1/83.3=0.012 seconds. There is no appreciable 'vacuum' in the cylinder until the piston has moved down significantly, so we have something less than half a revolution for intake. So the intake time is something like 0.005 seconds, with some variation depending on valve timing. 5 or 6 milliseconds is nowhere near enough time for the pressure inside the cylinder to equalize with the outside, so the pressure in the cylinder before compression must be less than atmospheric. Quantities of gasses must always be corrected for pressure, so the STP (Standard Temperature and Pressure) quantity of fuel/air mixture aspirated must be less than the displacement of the cylinder.
As I indicated, I don't know how much less. It will clearly depend on such things as valve size, valve lift, valve timing, cam shape, and both engine and atmospheric temperatures, so I don't think there can be a known ratio. If any of the engine experts knows an empirical value, I'd love to hear.
Your last statement is clearly the most important one!
Dick
Good Answers: 37
#156
In reply to #154
Re: Is IC Piston Engine Really Less Than 1% Efficient?
02/23/2010 9:14 PM
[I took my degree in physics, too, and never took an actual engineering course - but I contend that all REAL engineering is physics-based anyhow!)
Your numbers are correct, but there are several additional factors. Because air moving through the intake manifold has momentum, it can - and will - have rarefactions and compressions. When properly designed, the additional pressure will be adjacent the intake valve just as it begins opening; this will take place prior to top dead center, and end after bottom dead center. The additional duration, combined with taking advantage of pulsations and the momentum of the slug of air drawn in, may actually pack more air into the chamber than the amount you'd get when slowly rotating the engine and having valves exactly timed to TDC and BDC. The effect is usually more important on two-stroke engines than four-stroke ones. Similarly, the exhaust can be "tuned" so that there is rarefaction at the exhaust valve just as it begins opening (due to pressure pulses and the reflections from the end of the tube). The double-conical exhausts on two-stroke engines are designed to broaden the band where this phenomenon helps with power; four-stroke engines are less sensitive, but DO take advantage.
Of course, going to turbo- or supercharging, and adding fuel injection can improve things immensely. Using more valves increases flow as well; that's why my car has a turbocharged, five-valve-per-cylinder, fuel-injected engine (VW with 1.8T).
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
#159
In reply to #156
02/23/2010 9:38 PM
Ron, you're right...engineering is applied physics!
Speak softly and carry a big stick.
In reply to #156
02/23/2010 10:08 PM
You have several interesting points there! I gather you imply standing waves in the air stream. They undoubtedly occur, at least at certain RPM values, but it's hard for me to believe they are correctly tuned such that an antinode occurs at the right place and the right time, except at certain specific speeds.
Thanks for that last paragraph! I had no idea that my car had 5 valves per cylinder (2004 1.8T Passat). I did check it out, and by golly, you're right!
Dick
Good Answers: 37
#163
In reply to #161
02/24/2010 1:55 AM
I had two of the VW GTi 16-valve (4 valves/cylinder) cars before this one (2000 Jetta, stick, 183,000 miles, and I add 120 per day). I can remember helping my dad rebuild engines when I must have been 7 or 8 years old (I was more a parts-cleaner than anything else, but I watched what he did....and did a full rebuild when I was 14), so I've got 60 years of experience with IC engines.
There are at least a few engines built with intake manifolds which change effective length when the RPMs change, just to keep things tuned over a relatively wide range. Mechanically simpler ones exist; see US Patent 5551387 for example.
Good Answers: 50
#158
In reply to #154
02/23/2010 9:37 PM
Typically, for an engine in good mechanical condition, running at idle, 15 to 22 inches of Hg is an acceptable range.
Also, a "smooth" reading, without much variance, is as important.
In reply to #158
02/23/2010 9:58 PM
Measured where? I suspect you are referring to manifold pressure, but...
#125
02/22/2010 3:54 PM
Alright, my first posting here. I've read all this stuff going on. I used to be an engineering technician before I became a cop.
I smell it from all this far away. SCAM.
Yes, and I used caps for SCAM for emphasis.
You gave up way too easy for someone who was so passionate about his idea.
So, what's your play? How much do you want for your idea to save the world from itself?
Come on, son. Confession's good for the soul. Give it up.
In reply to #125
02/22/2010 5:16 PM
I assume you're referring to #112, where DDjames is acquiescing to M S DIVEKAR's onslaught.
I wondered about that ... is DDJ going to deliver a coup de grâce? Or is he going to give us all the opportunity to invest in the Glorious New Future? Or both?
I sit with bated breath.
[BTW - welcome to CR4 - enjoy!]
In reply to #125
02/22/2010 7:39 PM
You may well be right, although I haven't yet heard what the new alternative to the IC engine is, so what might be 'sold'.
I actually think it's more a case of 'a little knowledge is dangerous". A couple of people who have had just enough physics background to fool the truly ignorant into believing they have come up with something new..
... and I second JDG's welcome to CR4!
Dick
#129
In reply to #125
02/22/2010 8:58 PM
Welcome from me too.
Though DD wanted me to go away (he obviously does not like guests, who questions hosts) Still can not miss the chance to second (rather third) the welcome.
Come aboard and Enjoy.
#137
02/23/2010 12:32 AM
The table provided by mjb1962853 makes matters clear. I think we can close this topic. The efficiency is not as bad as less than 1% but may be 45% - but for some unknown reasons brought down to 26%.
May be another debate can be initiated (as this thread has gone too long) - as to how to improve this and take it to near 80% or more if possible.
"Challenge is a dragon with a gift in its mouth. Tame the dragon and the gift is yours." -- Noela Evans
In reply to #137
02/23/2010 12:39 AM
You apparently have never heard about, nor studied the conclusions of a gentleman named Carnot.
#184
In reply to #138
02/26/2010 12:12 AM
There is one supreme universal (Timeless) law - at least we Hindus believe in - CHANGE IS PERMANENT.
So all man made laws also are subject to change with time. Carnot's law - in implementation can be altered by programmability and electronics. I will not dispute PV /=T constant, but we can always find new ways of implementing it !!! I have that in mind. I understand Physics and laws- but only taking a fersh look - that comes under the Timeless law - CHANGE IS PERMANENT.
May be you can also be an inventor- if you take my words - do not simply accept. They invented long back - with certain assumptions. Question teh assumptions and you will find a new answer.
"Mystery creates wonder and wonder is the basis of man's desire to understand." -- Neil Armstrong from CR 4
"Education's purpose is to replace an empty mind with an open one." -- Malcolm S. Forbes- from CR4
In reply to #184
02/26/2010 12:54 AM
Okay, flap your unaided arms really, really hard. And really, really believe in it. Soon you will succeed in flying. Or maybe not.
#186
In reply to #185
02/26/2010 3:10 AM
I want to improve the efficiency of the Engine but i don't know how it functions? .
An earlier post also referred carnot's cycle.
What is the ideal carnot cycle efficiency? Simplest form is
η = 1 - Temphot/Tempexhaust
Assuming the Exhaust is at 500C ? Texh = 323
The Hot temperature ? 6000 ? Th = 873
η = 63% - and that is ideal
But you do not work in this condition.
nearest to the actual is the endoreversible which provides under same case η = 40% and that too is quite a bit optimistic since the assumptions do not hold true.
Note: carnots is ideal and no assumptions, it is only energy conversion. Better the two inventors study basic thermodynamics and the cycles.
Then, who knows we may really have one PMM1 ?
In reply to #137
02/23/2010 1:18 AM
MS,
who are you to close anything?
What's with all the quotations?
All the folk you quote actually knew something of which they spoke.
From all the preceding, it seems you don't. Not about reciprocating IC engines as least. - as to how to improve this and take it to near 80% or more if possible.
NOT me! I rather instruct people who actually want to learn something.
Only a dunderhead would make a statement like that. What do you think we all (engine designers, engine companies et al) have been doing for the last 100odd years.
When you get to know something of physics and chemistry you will know that there are some things that are never going to happen.
'Bye.
Stu
#142
02/23/2010 4:55 AM
Just to make some sense of this thread.
Question paper
All question are compulsory. Q9 contains 100% of marks.
Q9: Prove that 2/10 = 2
Music Student: Out of Tune
Art Student : There is no pattern.
Accountant: Cridit and debit don't match.
Philosophy : What can't be can't be.
Religion: It is not destined to be.
Medicine: If you have a controlled group of 10 and you give the medicine to two and placebo to the rest, then the two will .
Engineer: Too simple
2/10 = Two/Ten = Two/ Ten = wo/en
We know from A=1, B=2.. W=23, O = 15, E=5 and N=14
so WO/EN = (23+15)/ (5+14) = 38/19 = 2
QED
Moral: Engineers never bother about "what is the answer", they only ask "What answer you want".
In reply to #142
02/23/2010 5:08 AM
So which realm of incompetence is your daily engagement?
Stu.
#145
In reply to #143
02/23/2010 5:55 AM
Hopefully just a tiny bit better than that in which the members here are talking.
In reply to #145
02/23/2010 8:16 AM
No!
Which?
S.
#168
In reply to #146
02/24/2010 8:23 AM
Now you see, the things are getting funnier and funnier, yes MJB did slip up, but only in last column, it is not theritical fuel energy, rather theoritical fuel power.
0.225 lpm
33 MJ/l
= 33*0.225 MJ/min
= 33*0.225/60 MJ/sec
= 124 KJ/sec
= 124 KW
The thread has now reached the limit of absurdity. Even the guest can not continue here. I should have logged in. But then why unnecessarily.
Now you see what the engineer is trying to do? (unfortunately I am one too, but then not that much of one )
#175
02/24/2010 1:10 PM
It may be better if the admin closes this thread. It is really going nowhere, and any amount of maths is not going to convince the OP about the facts.
Unfortunately these threads will remain a part of history to confuse some young mind in future
02/24/2010 1:36 PM
So how do those big Diesel electric generators manage to get about 35% or more electrical KWH out of every 100 KWH of fuel energy?
Seems to me that if they do periodic lab test burns of the fuel to determine its exact combustion energy content (bomb calorimeter or similar testing) and the end result is that the in use gen set puts out 35% of that available as tested fuel energy as real measurable electrical power wouldn't that mean that they are probably right about their estimated engine and generator system efficiencies?
So does that mean that Massey 726 has over unity gen sets or more likely someone else can't do basic math?
As has been stated some time ago (energy out / energy in = system efficiency).
All of the mathematical theories in the universe are useless if reality does not agree with them.
Good Answers: 18
#187
In reply to #177
02/26/2010 6:14 AM
Hi tcmtech,
In the dying throes of this thread I would just like to conclude with some hard facts gathered from the plant which I manage.
Annual gas consumption: 58,000 MWhr
Electrical output : 21,500 MWhr
Heat recovered ; 22,750 MWhr
Therefore on a fuel input to useful work output basis the efficiency is:37.06%!
This is a genuine long term achievement which therefore covers all the various issues to do with changes in load, methane number, charge temperature etc.
You will note that I've also included the heat recovery element as the energy rejected from the exhaust gases, turbo intercoolers and jacket water circuits is passed into our District Heating system for use in a variety of building services.
We are audited on these performances as the plant qualifies under the best pactice CHP assessment scheme for carbon tax reduction purposes, therefore all inputs and outputs a measured through fiscally approved metering devices.
The overall plant efficiency is therefore 76.3%, again on an annualised basis; it would be higher if we could utilise more of the available heat in the summer months.
Hoping this is of interest,
Best wishes,
Massey.
In reply to #187
02/26/2010 12:17 PM
I will happily believe your numbers over many others!
Once again guys like you have proven reality does not bow down to theory!
Good Answers: 247
#189
In reply to #188
02/26/2010 1:55 PM
I agree, although with a small proviso:
Theory, appropriately applied and with valid math, usually comes extremely close to predicting reality. For example, I have predicted vehicle performance (and every manufacturer does this too) for clients based only on theory and math -- the vehicle itself does not yet exist. Any manufacturer can get within a couple percent of reality this way. Toyota did not throw some engine parts in a bag, shake it up, and have the Prius engine pop out.
This process, using appropriate theory and appropriate math to predict performance, led us to be able to send a rocket to the moon without having already been there. It's what enabled the Wright brothers to participate in the development of powered flight.
The problem with the central premise of this thread is not one of theory versus practice, it is one of completely ludicrous pseudo science in combination with completely incorrect math. There is little in DDJames presentation that is supported by the theories found in texts on combustion engines.
Real theory very strongly supports Massey's contention just as real theory strongly supports Honda's contention that their home co-generation units are 85% efficient, provided you have a use for all the hot water generated.
To be blunt, only nitwits and charlatans seriously argue that engines are less than 1% efficient -- there is no plausible theory to support such a contention.
Why believe Massey's numbers? Maybe he's making it up, and DDJames is telling the truth. The reason I believe Massey is because theory supports what he says.
Good Answers: 985
#183
02/25/2010 9:54 PM
Joe Walsh was right. You can't argue with a sick mind.
#191
02/28/2010 4:50 PM
OP might have a point. The torque figures for Maruti 800 are 59Nm @ 2500 rpm. This is not per second or per minute, therefore must be per revolution of shaft. Hp developed at this rpm would then be 59 x (2500/60) = 59 x 41.6 = 2458.3 W/s = 3.29 hp. But manufacturers use Torque x rpm x 1/5250 = 59 x 2500 = 147500/5250 = 28 hp.
Similarly 37.75Nm @ 5500 rpm = 37.75 x 5500 / 5250 = 39.5 hp. Why use rpm instead of rps ?
Good Answers: 37
#192
In reply to #191
02/28/2010 5:34 PM
Torque does NOT involve "per second", nor "per minute", nor "per revolution". The only purpose of the 2500 rpm is to tell at what engine speed it develops the peak torque. Horsepower peak will typically be at a bit higher rpm for most engines; it will NOT be "horsepower per second", nor "horsepower per minute", nor "horsepower per revolution". Any so-called math based upon such invalid units is bogus and wrong.
In reply to #191
02/28/2010 6:10 PM
Only 'point' OP has is to grind the point (ok edge) of his own axe. His maths is deeply flawed and his "physics" is nonsense.
Don't go there.
Good Answers: 247
#194
In reply to #191
02/28/2010 6:33 PM
Sorry. No, the OP has no valid point re this. For clarity on torque, try Hyperphysics.
Register to Reply Page 2 of 4: « First < Prev 1 2 3 4 Next > Last »
This discussion was "closed" on 03/16/2010 1:18 PM. No new comments are allowed.
Message from admins:
This thread has run its course. Time to walk away...
a+x=z (23); Alexander M. Berlin (1); Anonymous Poster (92); Blink (24); CrimeCrusher (2); cwarner7_11 (1); DDjames (49); dkwarner (39); HughMattos (1); JBTardis (10); JohnDG (28); Massey 726 (5); mjb1962853 (20); packrat561 (4); pantaz (1); redfred (24); Ron (20); saddlechariot (1); standarded (11); Steve S. (2); Stueywright (18); tcmtech (7); tick-tock (1); tomfranpat (1); Tornado (3); TrevorM (4); user-deleted-1105 (1)
Previous in Forum: What's the Best 3D Software?   Next in Forum: Expanded Tubes in Boiler Drum
