We have an Air compressor with soft starter with Type 2 coordination with PLC logics. It is observed that at time during starting, 2 or 3 semiconductor fuses blows off. When it survives, the compressor is running smoothly. The supplier had visited and confirmed that there is no mechanical loading during starting and all other parameters are healthy. The soft starter personnel visited and said that the ABB Altistart 48 is working obsolutely fine. The voltage in the PDB is 415Volts. Motor rating is 45KW. Motor rated current (In) is 74 Amps. During cold start, the current during starting is around 3 times (In). The semi conductor fuses are Bussmann Coopper 120Amps dual element fast acting. The soft starter personnel could not explain why fuses blows off occasionally.
