Previous in Forum: Arctic Submarine Laboratory - Public Invited to Last Library Presentation   Next in Forum: Rotating a Small Roller
Planetary Gear Tooth Count
02/22/2010 11:22 AM
I am trying to design by concept only a very basic planetary gear box. Without factoring in any load or torque equations, I am trying to determine ratios of gear size and teeth count to get 4 planets inside the internal gear. For example, if the internal gear has 78 teeth, the sun has 30 teeth, and the planets have 23, can I get four planets in the system?
Again, the sizes and pressure of the gears are not important for what I am doing. Does anyone have a resource for this?
Re: Planetary Gear Tooth Count
02/22/2010 11:35 AM
Check up the net there are several thumb rules for the number of teeth for the three (planets Vs Sun Vs Ring) for different types of combinations.
As far as I remember Roymech too has a page on it. Or try SDP-SI that also has one.
02/23/2010 8:29 AM
78 - 30 = 48 / 2 = 24 teeth for the planets. How did you get 23?
Further, what ratio do you want to achieve? Which of the three components is stationary?
Good Answers: 183
02/28/2010 12:58 PM
You can check yourself considering the fact that the distance between two neighbour planets should be > than the outter diameter of the planet + a gap.
Assuming not shifted profiles the distance is D=m*(Zs+Zp)*sin(180/n)/2
Dep= m*(Zp+2) The gap shoiuld be >0 in order to avoid contact.
There are other conditions for assembly but you do not ask for them and it is better for more complex aspects to look in a book about planetary drives.
As Floram writes usually the number of teeth of the outter gear is Zout= Zs+2*Zp which is not the way you seem to think.
Zout - number of teeth for the gear with internal teeth
Zs- same for the sun gear
Zp- same for the planet gears
The gap can be for instance (0.5...1) m, the smaller "m" the bigger j/m.
m= module of your gears
n- number of planets in same plane.
Register to Reply 3 comments
Anonymous Poster (1); Floram (1); nick name (1)
