Previous in Forum: L Angle Weight Calculation Formula   Next in Forum: Applications for Seamless and Welded Pipe
ER SS316L vs. SS316L Grade Filler Wire
02/23/2010 6:22 AM
Basically Im the employer of fabrication caomany, I wanted to know the difference between ER SS316L & SS316 L grade filler wires with its advantages/disadvantages over each other & perfomance for weld joint.
if possible please reply on my Email:-dhir.patil1@gmail.com
Re: Difference Between ER SS316L & SS316L grade filler wire.
02/23/2010 7:08 AM
http://cr4.globalspec.com/thread/45769, plus it denies other readers the benefit of the feedback.
02/23/2010 7:20 AM
There is no difference.
02/23/2010 8:27 AM
Just for clarification
E= Wire is suitable to be used as an electrode too ie it can carry the necessary welding current. In absence it is only a filler wire)
R=Available as both Continuous wire and Rods(which are used as fillers in GTAW).
309 - Grade of the base alloy
L = Low carbon
(Si) = Higher level of Si
(Mol) - Molybdenum added in the wire.
Note: For Tubular wires it is different nomenclature
Register to Reply 3 comments
Anonymous Poster (1); lyn (1); PWSlack (1)
