Would you please give me the answer for the following case
:If we change the size of connection tubes between hydraulic pump
and hydraulic motor to smaller size,is the motor power will be affected or
not?.
Yes definitely it will affect the motor , If you change the size of the pipe as smaller one instead of bigger dia. Hydraulic oil will get heat soon. and motor will take over load.
