Previous in Forum: Hydraulic motor   Next in Forum: Flow Through Given Orifice
hext exchanger
02/25/2010 3:08 AM
Help requested to calculate the efficiency of a single pass shell and tube heat exchanger
Thanks.
Re: hext exchanger
02/25/2010 3:09 AM
Is it lagged?
Re: hext exchanger
02/25/2010 4:21 AM
Without knowing which fluid is which: the efficiency is equal to [the change in enthalpy of fluid 1 multiplied by its mass flowrate] divided by [the change in enthalpy of fluid 2 multiplied by its mass flowrate]. If the answer is over 100% then that is nonsense as the principle of Conservation of Energy doesn't allow it, so take the reciprocal of it to give an answer less than 100%.
Good Answers: 18
Re: hext exchanger
02/26/2010 6:29 AM
Hi Guest,
You have chosen one of the few thermal interfacing devices with virtually 100% efficiency. PWS asked is it lagged 'cos if you put enough lagging around it you could assume that energy in=energy out.
It doesn't matter whether its 1,2 or even 3 pass the answer will be the same only the approach temperatures will improve.
S&T cofigurations are great when there is a great difference between the primary and secondary flow rates;as the difference reduces you should be thinking in terms of plate heat exchangers.
Good luck.
Massey
If it ain't broke,leave it well alone .........until it comes looking for you!
