Previous in Forum: Plumbing   Next in Forum: Heat Exchangers and Baffles
Unit of Hydraulic Resistance
02/26/2010 4:36 AM
hi,
i wanted to know,
What is the unit of hydraulic resistance?
and
If an electric system is related to hydraulic system:
Voltage drop will correspond to pressure drop.
Current will correspond to flow.
Then what will resistance correspond to?
Good Answers: 137
Re: Unit of hydraulic resistance.
02/26/2010 5:05 AM
It doesn't have a named unit. You could define it by analogy with electric current flow, but you would need to calculate pressure drop first, so it wouldn't be any help.
Also electricity obeys Ohm's law (for ordinary conductors) and current varies directly with voltage. For fluid flow, in most practical cases ΔP varies as Q2.
Valves, specially flow control valves, are often described by Kv (analogous to conductance, reciprocal of resistance), defined by
Kv = Q*√(SG/ΔP) where Q is flow in m3/h, SG is fluid specific gravity and ΔP is pressure drop in bar. (there's also Cv which is similar but in American units)
Cheers.......Codey
02/26/2010 5:07 AM
friction.
02/26/2010 6:27 AM
Pressure drop per unit length of pipe.
The Weisbach-Darcy equation can be used to work it out from first principles in the case of non-compressible fluids.
The electrical equivalent is voltage drop per unit length of conductor.
Good Answers: 137
02/26/2010 7:21 AM
Electrical resistance (ohm) is voltage drop per amp. You can divide by length of conductor if you want ohm per unit length.
And if by analogy hydraulic resistance is defined as say bar/(m3/h) there could be a problem as usually ΔP varies as Q2.
Also there's no problem using the Weisbach-Darcy equation for compressible fluids. Pressure and temperature have to be handled correctly, but then it's OK.
Cheers........Codey
Good Answers: 183
02/28/2010 11:46 AM
To be consistent with the ISO units it should be N*m^-2/(m^3*s-1)=N*s/m^5.
A specific resistance would be related to the tube length but a global resistance has not to be bound to the length. The Ohm is a global unit so that for similitude the hydraulic unit has as well to be global.
Years ago an American company supplier of miniature hydraulic resistor -Lee- used the "LOhm" which could be either read as Lee-Ohm or as Liquid-Ohm.
Anonymous Poster (1); Codemaster (2); nick name (1); PWSlack (1)
You might be interested in: Hydraulic Repair Services, Hydraulic Cylinders
