Previous in Forum: Unit of Hydraulic Resistance   Next in Forum: Flame Arrestor
Heat Exchangers and Baffles
02/26/2010 6:10 AM
How does the baffle cut & centre to centre between the baffles affects the heat exchanger design?
Also is it possible that the the pressure drop on the tube side can be reduced by changing the baffle cut or centre-to-centre dimension for the baffles without changing any other parameter from the cooler design?
Pathfinder Tags: baffles
Re: Heat Exchangers: Baffles significance
02/26/2010 6:12 AM
Baffles are a compromise. The more baffles, the greater the turbulence within the exchanger and the better the heat transfer. The downside is that the pressure drop goes up too.
02/26/2010 10:52 AM
Baffle cut and spacing will affect the pressure drop and heat transfer on the shell side. For the tube side, you will need to look at the pass partitioning in the heads.
Re: Heat Exchangers and Baffles
03/04/2010 11:49 AM
Baffle creat impingment, when steam hit the baffle it condenses releasing heat thus transfer heat.
p911
03/10/2010 7:27 AM
In addition to response from others baffle spacing also changes the unsupported length of tube, natural frequency and ultimately vibration design
With regards
R.SRINIVASAN VICE PRESIDENT PVD DESIGN ISGEC YAMUNANAGAR HARYANA INDIA
Register to Reply 4 comments
annamutha (1); phoenix911 (1); PWSlack (1); Tornado (1)
You might be interested in: Heat Exchangers, Bin Activators and Discharge Aids
