Previous in Forum: Steam Property   Next in Forum: What's a Better Spring Shape?
Flameproof Class 1, Div 1 Compliance
02/26/2010 8:03 AM
I am working on a project which needs the product should be of Flame proof and class 1 division 1 complience. My question is we are using an aluminium plate of 1/2" thickness. Rectangular slot (5.9"X0.4") with 2" depth is made within the aluminium plate. Heaters are placed in the holes which is drilled inside the rectangular slot and after placing the heaters, this rectangular slot is filled with potting material (sauresian cement,it is an heat resistant cement). The rectangular slot will be covered with cover plate and is assembled to aluminium plate by using screws. wires are taken out from the cover plate hole through 1/2" conduit to the other system.. I want to know wether the design of rectangular slot with cover plate holds good for flame proof,class1 and div1 standards or still we need to take any precautions before going for prototype. If you give me the suggestion it will be of great help. Regards Manju
Re: Flame proof class 1 div1 complience
02/26/2010 8:44 AM
The prototype device will need to be type-tested at an accredited testing laboratory before a certificate can be issued.
BASEEFA is the UK-based agency that does this (usual disclaimer).
Re: Flameproof Class 1, Div 1 Compliance
02/27/2010 6:50 AM
I understand that the slot is cut in aluminium plate to insert electric heater and this heater if part of either process vessel or any other process equipment handling hazardous chemical. Normally process equipment are provided with nozzle to insert heater. The heater to be inserted are certified for use in area classification. The arrangement being described is very crude method and should not be attempted because of 1. The plate is being used for screwing which does not indicate the meeting surface of the flange required for cooling down of explosion before it comes out from the flange. 2. The sealing after inserting heater is also very crude method. Normally cables are connected through cable glands. In case conduit entry is used, these are also threaded as per NPT. if the product is for development stage, kindly refer codes for enclosure of explosion proof equipment as these will require testing and approval for compliance to codes.
rc sachdeva
