Previous in Forum: Flameproof Class 1, Div 1 Compliance   Next in Forum: Power Generation and Renewable Energy
28 comments
Good Answers: 94
What's a Better Spring Shape?
02/26/2010 9:17 AM
The image below shows a part I am trying to create, it is in effect a square internal circlip. I have envisaged this as 2 square bars held apart by 2 wire form springs. I've drawn these springs with a simple loop but I'm wondering if there is a better shape to ensure that the arms of the springs remain about parallel when squeezed together by the square bars.
I need the wire forms to be as flat as possible & don't have much space to play with. The assembly shown is about 20mm square by 2mm thick & the central area must remain clear.
Can anyone suggest a more efficient spring shape?
Re: Spring shape help
02/26/2010 11:59 AM
Catsies likes springs.
Can I confirm, what you really want is the two square bars to push out away from eachother whilst remaining parallel and you want the central area clear?
I shall sketch away...
02/26/2010 12:10 PM
Maybe something like this?...bear in mind I like to see and 'beam' or 'leaf' type springs tapered, which is fine if they are stamped out or molded...
Any royalties to be paid in Tuna, excuse the wobbliness of the dwg...but it's not easy working a graphics tablet with these paws.
Topologically it's the same as your design
Good Answers: 58
02/26/2010 10:01 PM
Del, I'm suprised. This is an ideal application of a simple bow on each end, or recurve, or whatever, you're the bow guy. It's only 20 mm, nice little spring steel bow with the ends bent in to go into the holes. I think his design will bend down the wrong way. I presume he wants to keep everything in the same plane.
mike k
02/27/2010 2:46 AM
That's what I've done...Each vertical line in the pic represents a tapered limb ideally.
I didn't have the time to do a better drawing, and tapers aren't practical if the design is implemented with wire....
02/27/2010 11:16 AM
With beryllium copper flat stock, you can punch/forge, in one operation, any shape and vary thickness throughout its length. Then form and heat treat. One-offs would be expensive but volume lowers price and there are small job shops itching (subliminal command) to do it.
Nothing exceeds like excess.
Good Answers: 213
Re: What's a Better Spring Shape?
02/26/2010 11:38 PM
You could probably accomplish the same thing with simple leaf springs, perhaps with some pre-curvature formed into them. Squeeze the leaf springs together, and the two square bars come together. Release them, and the two bars return to their natural position...
02/27/2010 12:48 AM
A simple "square," with the corners including an angle of about 100°, and the side bulging a little.
02/27/2010 2:48 AM
Or 80o with the sides curving inwards...
02/27/2010 3:03 AM
Could be. I am envisioning a square hollow with a groove at some depth, into which the spring should expand, leaving a maximal open area in the middle. Some OP clarification, maybe with a drawing, would help. Your first design might be viable, but the OP's sketch had inward loops that would encroach toward the center of the otherwise open area.
Ain't guesswork fun?
02/27/2010 3:40 AM
I assumed it was only engaging in two edges (left and right in the pics).
Good Answers: 204
02/27/2010 1:17 AM
how about some variation on this? It could be either wire or 2mm flat spring. doesn't have to be square, but radius curves or sinusoidal.
02/27/2010 2:29 AM
How about a large internal circlip that engages in a slot on the inside of the bars. They are cheap and readily available. This leaves open a large circular area in the middle. Other designs seem to encroach quite a bit on the open area, reducing the diameter of a shaft passing through it, if it is a shaft passing through it.
More info on the application might help.
02/27/2010 10:14 AM
How about sliding tubes (one inside the other) surrounded by a standard round spring?
Good Answers: 22
02/28/2010 6:05 PM
What would be wrong with inserting a std round circlip?
Good Answers: 94
02/28/2010 6:58 PM
There's some good thoughts here.
Maybe the leaf spring would work.
I can't use the round circlip as I need a clear square area in the centre. The comment about my loops encroaching into the clear area is correct, I would have to make the assembly rectangular to compensate.
In use the 2 bars would be squeezed together using circlip pliers in the central holes, moved into place then released below a couple of tabs. This will retain a component underneath the circlip.
If I get a chance this week I'll have a go at making one.
Good Answers: 204
02/28/2010 7:39 PM
ya we need more design information to work with.. (or at least I do. )
Chris
03/01/2010 3:07 AM
What about the springs they use to hold a watch strap in position:-
Obviously you'd need corresponding holes in your square bars, and, may need a way to hold the whole assembly together. This meets your design requirement:-
"ensure that the arms of the springs remain about parallel"
The really good thing is that they're cheap as chips and readily available.
Good Answers: 94
03/01/2010 5:13 AM
That's a nice thought, wouldn't work for us unfortunately, the finished assembly will be in vacuum & those would be hard to pump out.
03/01/2010 10:35 AM
I don't think they're well enough made to form a seal.
Good Answers: 94
03/01/2010 12:05 PM
No they won't be sealed but any entrapped volumes slow down the pumping time.
03/01/2010 6:34 AM
D'uh!
Just dawned on me, you can make a square circlip, if the 'gap' is at one corner it should close nicely for fitting/removal as the ends of the gap are pulled together.
Sketch being done even as we speak..
Selective thinning of the material could help to induce flex where required to aid insertion/removal.
Gotta be a winner... give the cat Tuna...
03/01/2010 7:05 AM
You beat me to it! The only difference was that I would have drawn the corner angles at about 95°; i.e., sprung a little more open.
I don't know an easy way to machine a groove into the internal wall of a square tube. A drawing of the original concept, or a more detailed description, would help in understanding the constraints.
Good Answers: 94
03/01/2010 7:12 AM
There wouldn't be any groove, the construction of the assembly the circlip goes into would be a metal/ceramic layered construction with the circlip fitting under some tags. An angled face on the clip locks it into position.
My design is a bit sketchy just now but I will see if I can upload more detail by the end of the day.
Good Answers: 94
03/01/2010 7:08 AM
No tuna yet, I did think of this shape but it would flex at the corner opposite the circlip pliers making insertion a bit difficult.
I still like the leaf spring idea, if the springs were etched the shape could be optimised to make it bend in the best way.
03/01/2010 9:21 AM
I did think of this shape but it would flex at the corner opposite the circlip pliers YES making insertion a bit difficult.NO.
I don't see why it should make insertion any more difficult than a standard circlip? The inward force of the pliers should reduce the length of the two diagonals allowing it to fit.. (assuming you make the gap big enough, to make it close enough)
I could draw dotted lines on my pic, but my dotted pencil is bust
Good Answers: 94
03/01/2010 10:11 AM
I looked at replacing the spring in my original image with a leaf spring as per Del's suggestion but that has sort of morphed into this idea.
This shows it in the assembly.
The pale blue part is what I am trying to hold, the yellow tag forms the top of the circlip 'groove'. The clip also has to carry volts from the yellow tag to the face of the pale blue part.
03/01/2010 10:32 AM
So it's a retaining clip for the Dilithium crystal, all part of the warp core?
Good Answers: 94
03/01/2010 12:07 PM
Spot on- for the Scalextric Enterprise.
Register to Reply 28 comments
chrisg288 (2); cwarner7_11 (1); Jaguar (2); mike k (1); Nigh (7); OldTechNewToys (1); Randall (2); Tom_Consulting (1); Tornado (3); user-deleted-1105 (8)
You might be interested in: Flat Springs, Power Springs and Spring Motors
